Question about Whirlpool GSW9800PW Washer
Washer is not filling up at start of a cycle its going straight to the wash cycle
  • Whirlpool Master
  • 909 Answers
Very possibly you have a clogged pressure switch. Remove the cover and find a small clear pipe attatched to the outer drum. Carefully, pull the pipe off and by using another pipe of the same size, blow into it. You will find initially it will be partially clogged.By blowing as hard as possible, it will clear. Reattatch and test.
Posted on Aug 21, 2010
Spin cycle will not work will not refill with water. It acts like water is in the machine when it is empty. When you start the washer it does not fill with water it goes straight to the wash cycle
The pressure starter is faulty kindly replace the pressure starter even after replacing the pressure starter if problem exist may be main board faulty replace the main board
Jan 08, 2010 | GE WDSR2080D Top Load Washer
Water pump goes through the whole cycle with door open.
You can replace the lid switch to fix it. The best thing to do is sort your laundry first from all over the house where you left the items. Make a load sized pile and place in washer along with the detergent and then turn on washer. If the switch has been straight wired it will do this. The switch on mine is straight wired and I have no problems with it. The lid switch is on there to keep small children and arms from getting hurt and broken.
Jun 29, 2009 | GE WBSR3140DW Top Load Washer
Washer not going in cycles
Where you attached the new hose on the side of the tub, you must remove that hose and insert a small wire in the hole in the cup and clean out the soap scum. Re-attach the hose. Set the washer on spin and run a spin cycle. Then retry your wash cycle.
Make sure the new hose is not pinched anywhere.
Apr 24, 2009 | GE WJSR2070B Top Load Washer
Washer just started on fill cycle to start and continued filling
you have a hose that came loose to the pressure switch or the tub or you have a bad pressure switch
or the fill cup is blocked
Apr 22, 2009 | GE WJSR2070B Top Load Washer
Washer fills slow only in the rinse cycle
Need a model # to get exact part you will need at rinse most washer go straight cold so I would say water inlet valve if humming sound is present
Apr 28, 2017 | GE WBSR3140DW Top Load Washer
The Maytag top loader washer MAV7750BGW started to fill at the beginning of the washing cycle then stopped. Could not get it to do anything on any other cycle steps. Electrical supply OK. Managed to get...
It sounds like you have a lid switch problem. Check your the lid on your washer and see if it's not bent towards the middle. Often as things get sat on top, it will bend and not allow the switch to make contact. The washer doesn't do anything but fill when the machine thinks the lid is open. Try bending the middle of the lid back to where it is straight.
Jun 18, 2008 | Maytag Washing Machines
MY NEPTUNE MAH4000AWW WORK WHEN IT WANT TO WORK
Check for low water pressure. Clear screens in inlet valve. Do-not remove screens. This unit will turn off if not filled in specified time.
Nov 08, 2007 | Maytag MAH6700AWW Neptune Front-Load...
Calypso - water goes straight to drain hose-not drum
the hose may still be filled from last cycle. try to put machine in final spin mode where all water from previous wash will be spun out the drain hose. once a siphon is started it can only be stopped by introducing air into the drain hose.
Sep 16, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool GSW9800PW Washer Logo
32 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
