Question about Jet 10" Xacta Saw Left Tilting Arbor Tablesaw 708661
TABLE SAW MODEL JTAS-10-1 SERIAL # 9031109 - Jet 10" Xacta Saw Left Tilting Arbor Tablesaw 708661
  • 3 Answers
My table saw jet model jtas-10-1 serial # 9031109 stock # 708510
Posted on Aug 22, 2010
Turn saw on and in less than 2-3 seconds circuit breaker trips
Probably a weak breaker in your fuse panel try different outlet
Nov 12, 2012 | Jet 708662PK/JTAS - 10XL30 - 1 with 30...
The table saw shutdown where is the restart button
Usually the reset for table saw is on the motor itself
Crawl under the table and check it out & check your motor name plate (use a digital camera to photograph the name plate so you can see it large on your computer and have a record of that information)
Look for oil caps at the bearing ends of motor, to see if your motor can be oiled using 3-in-1 oil
If your saw is shutting down, you may not have enough electricity for the motor
Look at motor name plate for volts amps or watts.
Now figure how much electricity your saw need using the formula Volts x Amps = Watts
Next, look at the circuit breaker and size wire
15Amp breaker = 1440+watts
You can figure the breaker load using V X A = W
Next look at your wire going to table saw
14 gauge wire for 15 amp breaker
12 gauge wire for 20 amp breaker
10 gauge wire for 30 amp breaker
You might benefit by running bigger wire to the saw. And adding some oil in the oil caps.
I oiled my table saw and then ran a dedicated 30Amp wire to it, and it runs real good for a 25-year-old craftsman.
Oct 20, 2010 | Jet 708663PK/JTAS - 10XL50 - 1PK 3HP 1Ph...
Jet saw Manual for a JTAS-10/12
Jet's Manual site is here. There are a number of manuals for Jet table saws there. I believe the exact manual you want is here though.
If this helped, please vote. Thanks!
May 25, 2010 | Jet 708663PK/JTAS - 10XL50 - 1PK 3HP 1Ph...
Saw kicked out on overload,reset buttion will not reset
did it trip your outlet breaker? check breaker with volt ohm meter. hope the motor didn't go to ground.
Jan 19, 2010 | Jet 708663PK JTAS-10XL50-W1 10-Inch Left...
I own a Jet Left Tilt Cabinet Saw Mdl 708663PK. The on-off switch seems to stick and does not always start the saw. The saw runs normally when it starts. When it does not start, the on switch depresses and...
I took the front cover off of the switch and noticed the portion of the switch the off button contacts was fully depressed and would not slide back to its proper position. I lubed (silicone) the slide portion of the off switch and cycled it manually to free it up and distribute the lubrication.
Feb 17, 2009 | Jet 708663PK/JTAS - 10XL50 - 1PK 3HP 1Ph...
Dual voltage motor on table saw
get a step down power supply form a ac supply store.
Dec 12, 2008 | Jet 708668PK/Model JTAS - 10XL50 - 5/1PK...
On/off switch
The contacts in the switch are burnt, replace them.
Sep 21, 2008 | Jet 708715PK/JTAS - 10X50 - 1PK 3HP 1Ph...
Jet 10" Xacta Saw Left Tilting Arbor Tablesaw 708661 Logo
480 people viewed this question
Top Jet Saws Experts
woodzowl307
Are you a Jet Saw Expert? Answer questions, earn points and help others
