Question about Sharp AR-M450N Copier
Double vision the printer is printing a double of the image, the copy & then another one lighter & to the right. why is this happening & is something a non professional can fix?
  • 29 Answers
The problem is the cleaner blade is difective and it should replace.
Posted on May 06, 2008
Sharp mx-2310u printing double vesion of an image, the copy and the lighter to the right. how can i fix this?
Double print usually happens when Drum completed its life and Cleaning Blade unable to clean the drum surface properly, Replacing of Drum and Cleaning blade will gave you good copy quality, Don't forget to clean Charger unit
Aug 27, 2014 | Sharp MX-2310U Color Printer : 2310U
Image Faulty
there are paper guides on either side of the paper in the bypass.make sure thy are nice and snug right next to the paper.
Mar 07, 2014 | Kyocera Mita KM-1650 All-In-One Printer
Copy darker
go into the menu and look for copy/print settings. you should see an option to lighten or darken the copy. It should look like a ascending /descending slider. tap to the left for lighter or to the right for darker
Nov 27, 2013 | HP Officejet 5610 All-In-One InkJet...
Just got new Konica Minolta C224 copier. Prints from computer are perfect but when I try to copy something in color it prints page with thin even cyan or magenta lines. Lines are spaced evenly about 15 mm...
MAKE SURE YOU DO EXACTLY WHAT THE INSTALLATION MANUAL SAYES, INCLUDING DOING THE"Performing Non-Image Area Erase Check" I KNOW ITS A PAIN, BUT IF YOU DONT, YOU SEE WHAT HAPPENS
Aug 24, 2013 | Konica Minolta Bizhub C224 Color Copier /...
Copies have black streaks and "double printing" meaning that the image is repeated much lighter a few inches over
The two possible solution is that you need a new drum cleaning blade and maybe a new OPC drum with it or it maybe that the upper fuser unit is worn out or dammaged. Look in thos two spots. Good Luck
Jul 28, 2010 | Minolta DiALTA Di183 Copier
Double images, error 5100 when printing, copying
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions.
Jan 02, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Canon ir3300 - print but double image and missing a few line
HI,
how many copies do you have, when the last time did you change the drum unit or fixing film?
Try first to check the fixing film if you have double smudged and non fixated copies.
Nov 09, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Copy prints with image from previous page (lighter) as well. This is an older copier (Gestetner 2302Z)--is the fuser roller the issue/ Can I repair/replace myself?
To check if it is the fuser rollers turn off the copier before the paper reaches the fuser.Remove the 'jammed paper' carefully as the image will rub off and see if the double image is present.If it not then it sounds like the fuser.If it is there then will more than likely be the drum that is not cleaning.I do not suggest that you change this yourself.
Nov 01, 2009 | Office Equipment & Supplies
A copy with a lighter image of the copy on the page
Do printed pages come out better than copies?
If they are the same, you may try another toner cartridge (especially if it is a remanufactured or compatible toner), otherwise, you need your optics cleaned (mirrors and lens under the contact glass)
Mar 06, 2009 | Canon Office Equipment & Supplies
My HP printer 2420 leaves "ghost" prints on the pages.
This can be caused by one of two things.
1. faulty wiper blade on your toner so that the previous image in not being wiped off the drum.
2. worn fuser sleve.
To work out which it is you will need to do a half stop test: print off a normal document then when it is about half way through the printer ( unfortunatly you may have to repeat this to get the timing right) open the front cover. remove the toner cartridge. if you can see the ghosting on the page the it is the toner. if its not there then its a new fuser. to save on money and if your confident enouh you may be able to just chane the fuser sleve depending on the state of the fuser on a whole.
hope this helps
feel free to email me if you have any other questions:
pete@wedotoners.com
Oct 21, 2008 | HP LaserJet 2420 Printer
Sharp AR-M450N Copier Logo
154 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
