Question about Kitchen Ranges
I have a Dough Molding machine type NFZ-380. How can I remove its conveyer belt.
  • ahmedbam Aug 21, 2010
    I already requested a service manual from them, but they did not reply.
  • 2,926 Answers
South Star does not provide this info on there site, but they request you call or contact them. They also have a live chat on their site that will put you in contact with a person to help.
The site is; http://www.southstar.cc/en/show_pro.asp?pro_id=68
The company is located in China.
Posted on Aug 21, 2010
  • GetMeOttaHere Aug 21, 2010
    Understood. It seems this repair or diagram info is only obtainable from them or a service center in your area. Customer support from many China companies for many products is almost non existant.
Won't knead dough
Chances are that your drive belt is broken. With the pan and paddle removed from the oven and your machine unplugged turn it on its side so the bottom is facing you. Hopefully it has one of the removable metal panels on the bottom. If it does, remove that panel using a screwdriver. When the panel is off see if the drive belt that runs between the 2 pulley wheels is broken. If it is broken remove the old belt and look for a number on the side of the belt that looks something like this STS 60 S3M471 I sell replacement belts for bread machines. Contact me through my website breadmachineshelp.com if you are interested in replacing your drive belt. Thanks, Daryl
Again the website is breadmachineshelp.com or just email me at daryl441@msn.com
Mar 05, 2013 | Kitchen Appliances - Others
My sunbeam 0091 breadmaker does not knead. If I go to 8 which is knead dough cycle it comes makes noise but nothing else.
Yes. Hopefully your machine has a removable bottom panel. remove the panel and get your old belt off and make note of the belt code. It will look something like this: STS 60 S3M471 I sell replacement belts and you can visit me at breadmachineshelp.com
Mar 02, 2013 | Sunbeam 5891 Bread Maker
Change belts on polaris 380
open case then remove vertical tube then then remove paddle wheel assy then you have to remove wheel screws to change belts take pictures as you take it apart
Jul 29, 2012 | Polaris 380 In Ground Pool Cleaner
Codigo C7760 de una Kyocera kilometros 1635
C7410 C7800 C7810 C8010 C8030 Drum unit connector insertion problem • Absence of the drum unit is detected continuously for 1500 ms while there is no error on the copier. Broken external temperature thermistor wire • The input voltage is above 4.5 V. Short-circuited external temperature thermistor • The input voltage is below 0.5 V. Finisher* paper conveying motor problem • The paper conveying motor lockup signal is detected for 0.5 s or longer. Finisher* paper conveying belt problem • An on-to-off or off-to-on state change of the paper conveying belt home position sensor is not detected within 2 s of the paper conveying belt clutch turning on. Drum unit connector inserted incorrectly. Defective drum unit connector. Poor contact in the humidity sensor PCB connector terminals. Defective external temperature thermistor. Poor contact in the humidity sensor PCB connector terminals. Defective external temperature thermistor. Poor contact in the paper conveying motor connector terminals. The paper conveying motor malfunctions. Defective finisher main PCB. The paper conveying belt is out of phase. The paper conveying belt clutch malfunctions. The paper conveying belt home position sensor malfunctions. The paper conveying belt home position sensor connector makes poor contact. The internal tray is incorrectly inserted. Reinsert the drum unit connector if necessary. Replace the drum unit. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Replace the humidity sensor PCB. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Replace the humidity sensor PCB. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Replace the paper conveying motor and check for correct operation. Replace the finisher main PCB and check for correct operation. Adjust the paper conveying belt so that it is in phase and check for correct operation. Replace the paper conveying belt clutch and check for correct operation. Replace the paper conveying belt home position sensor and check for correct operation. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Check whether
Jan 19, 2010 | Office Equipment & Supplies
I am looking for an instruction manual for a bialetti pasta machine
For the manual or electric type?
If it's the manual type follow these steps.
Secure the machine to the counter.
Adjust the dial (usually by pulling it out and rotating it) to number one. Feed the dough through the machine. For thinner pasta keep adjusting the dial and running the dough through until you have the desired thickness.
Run dough through the other end...the one with grooves. On mine I have to pull the handle out and move it to another slot.
Hope this helps.
Sep 18, 2009 | Kitchen Appliances - Others
Need plastic timing belt drive pulley for Breville BB 380
I may have a machine you can use for parts. I have a BB380 which mixes the dough OK but trips the electrical core balance switch in the house when it goes to bake - so I was taking the pan out and bakeing it in the gas oven. But I got tired of resetting all the electric clocks in the house and bought a new machine. Would this be of assistance?
Jul 13, 2009 | Kitchen Appliances - Others
Remove the lower window molding on2000 durango
For the lower belt molding?
1.lower glass
2.Lift corner of weatherstrip upward and remove weatherstrip from outer door panel.
Apr 27, 2009 | 2000 Dodge Durango
Kneading paddle having problem kneading
Sounds like you might need a new belt. If it works ok with nothing in it but wont when the dough is in there
Feb 13, 2009 | Breadman TR875 Bread Maker
Belt replacement bread maker
Hi, guys! I had posted this problem a long time ago and tried to find a belt replacement but couldn't. One fellow online said he had used an o-ring and it worked, so I recently bought one and....BEHOLD! It works! And it cost me all of $1.49 at my local mom-and-pop hardware store. I got the biggest one I could find--it's probably about 8-9 inches in circumference. It didn't look like it could possibly work, but it stretches tremendously and you are able to fit it around the gear wheels in the bottom of the machine just fine. I've only used it once so far, and that was to make a soft pizza dough, so I don't know if it will have the power to knead a thicker, drier bread dough, but it definitely turns the kneading blade just fine. If you decide to try this, you'll need to find a small hardware store where they sell things like this by the part, rather than one of the mega-stores where you have to buy a gross of everything. I wish all the homemade bread lovers who hate to throw out a perfectly good appliance the best of luck with this solution!
--Molly from Little Rock
Dec 13, 2008 | Regal Ware K6725 Kitchen Pro Bread Maker
Seat belt repair
first for the switch in window
the window switch is easy to test you just gotta remove switch out of the door leaving it hang there is a way to test with a guaged wire with fuse on it
take the main power wire and touch to the other connectors on the main switch if the window goes down or up the switch is the problem
im suggesting this way first with fuse cause its easier then testing the windows motor inside the door frame the switches should just pop out of the panel with out haveing to take panel off
now the seat belts there are 2 style that are common to chevy
one is inside the molding of the drivers panel you gotta pop off the panels easily and gently to get at the seat belt retractor this will be bolted to the metal under the molding
the other style is in the seat which you gotta unbolt the seat under the top half it will need to be unbolted at the bottom top half of seat
when you pull threw the top section of top half of seat remember to tie a string to the end so that when you pull threw top half the string will be there so you can connect too new belt and pull back threw with ease make the string long enough to hang
now the bottom half of seat what i call the "**** seat" you remove the molding at bottom around the belt retractor this will be bolted to floor bolt also pull belt threw molding once molding removed
disconnect any electric wires
now saftey issue involved with seat belt removal is for a reason i dont know of the dealer ship always discharges the belts and air bags once removed i guess because of static electricity becareful when you remove belt and replacing belts cause static elec. can set them off
once your seat belt is removed place in card board box and take to dealer after complition of installing new belt they will discharge your seat belt for you and then you can dispose of it properly
May 29, 2008 | 2000 Chevrolet Suburban
Kitchen Ranges Logo
41 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
