Question about HP Proliant BL460C G1 X5365 2G 1P Svr Server
Hi i get the following error when btying to bootin to windows ql2300.sys. I seen fixes but how do i fix if i cant get in to the os? p.s the server is running 2003 ent edition
  • 77 Answers
Seems like a driver error, you must've installed a specific update from Microsoft for that driver, before attempting to install anything. Hopefully, you have kept backups of what was in the server on an external hard-drive or on a file-hosting website.
Posted on Aug 21, 2010
Error in windows installation
Not sure if XP will recognise SCSI as the primary drives. Under Linux no problem but most Windows OS's were never designed to support SCSI since it is more of a server drive system not a common home PC setup. I am not a MS fan and have not used MS products for many years so things might have changed. Remember XP is no long supported by MS so you might run into more problems down the road. I loved XP and changed OS's once the Vista/7 garbage took place.
Jan 11, 2014 | SuperMicro SuperServer 7043M-6...
How to fix error 651 on windows 7
Error 651 is a well-known bug in Windows 7 which happen when you try to connect to the Internet using PPPoE connection. If you're one of the victims who met this bug, you should see the following error message: Error 651: The Modem (or other connecting device) has reported an error. These connections, however, would work just fine in Windows XP or Windows Vista PCs. Below are a few solutions that can perhaps fix the problem:
Windows 7 Fix: Error 651 Modem PPPoE Broadband Internet Connection
Fix 1: - Error 651 Modem PPPoE Broadband Internet Connection
Click here to download Registry Easy to automatically fix your PC errors and speed up your system.
Fix 2: - Error 651 Modem PPPoE Broadband Internet Connection
The root of the problem is believed to be caused by the RAS PPPoE file raspppoe.sys found in the folder C:\Windows\System32\Drivers. To fix this problem, we will have to replace the file raspppoe.sys with a new one. Try to copy the file from your friend's computer which has Windows 7 installed. Alternatively, you can download the raspppoe.sys file from this site (thanks to the author). After you get the file, before pasting it into C:\Windows\System32\Drivers, be sure that you rename the original file to something like raspppoe_ori.sys, so that if something weird happen you have a backup of your original file. Paste the new raspppoe.sys into the directory after you've renamed the original file. Try to connect your modem and it should work fine now.
Feb 21, 2013 | Computers & Internet
Hi i have HP Proliant ml 150 but i cant install server 2003 . how to install windows server 2003
Windows Server 2003 or Windows XP x64? They're the same operating system as I understand it. You must have 64 bit hardware installed on your computer to run a 64bit operating system.
What errors if any are you seeing when you attempt to install this OS?
Feb 16, 2011 | Computers & Internet
Fix error 651 on windows 7
In windows 7, when you try to connect using your PPPoE connections, you may be faced with the following error: Error 651: The Modem (or other connecting device) has reported an error.
These connections would work just fine with Windows XP or Windows Vista PCs.
Again, you are not alone, this seems to be a known bug in Windows 7 that is being worked at. However, you can workaround this problem.
The RAS PPPoE driver file "raspppoe.sys" found under c:windowssystem32drivers folder seems to be the root cause of the problem. Fortunately, we can workaround the problem simply by renaming the original raspppoe.sys file to something like "raspppoe_orig.sys" copying a working file from a Windows Vista system. If you do not have access to a Windows Vista system. click here to download raspppoe.sys file (unzip). This should help!
Jan 01, 2011 | Computers & Internet
?500 Internal Server Error? 100% 2003 Gateway 700S PC 2002 Windows XP Home Edition Late 8/20 or early 8/21 ?Guru? recommended I change my web browser from Internet Explorer to Foxfire Foxfire...
hi Fixing 500 errors - general
This error can only be resolved by fixes to the Web server software. It is not a client-side problem. It is up to the operators of the Web server site to locate and analyse the logs which should give further information about the error. Fixing 500 errors - CheckUpDown Please contact us (email preferred) whenever you encounter 500 errors on your CheckUpDown account. We then have to liaise with your ISP and the vendor of the Web server software so they can trace the exact reason for the error. Correcting the error may require recoding program logic for the Web server software, which could take some time. try sending email of your problems to support.microsoft.com.hope this helps sorry it sounds so complicated.
Aug 23, 2010 | Computers & Internet
When i plug the hard drive my computer wont detect. only the bios can detect.and i cant reformat it it says.a problem has been detected. i boot it from cd and after the windows setup it displays" a...
This usually happens when u fit any hardware to the system....The information which u gave seems its "Blue Screen of Death" or "BSOD" ........ if u have seen this screen only after u plugged in yr HDD, try with other HDD. Perhaps there might be an error with the HDD which u have plugged in.
Jun 13, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
Problem of video controller(VGA Compatible)
This is common on laptops that use the integrated ATI/AMD combined system drivers. Try downloading the Processor drivers and utilities package from amd.com and see if that fixes the problems with the video card.
Steven
Aug 20, 2008 | HP Compaq ProLiant DL580 G3 (364636HP1)...
System Crash
Hi
Intel 2200BG is known to cause this and similar errors when Wireless Application Protocol (WAP) encryption is used. The problem has been around since 2004 and new OS Drivers should fix this.
I recommend you download and install latest Windows Drivers (appropriate for your Windows Version) for Intel 2200BG Adaptor.
If this cannot be done, then setting your wireless to Wired Equivalent Privacy (WEP) encription (though less secure) will minimise these error conditions
NB: Google "w22n51.sys" for more info.
Regards
Mike
Mar 27, 2008 | Intel PRO/Wireless 2200BG 802.11g/b
Problem regarding ActiveX control
Do you have this problem in your server2003 sys or the client sys.
Jan 02, 2008 | Microsoft Windows Server Standard 2003 for...
HP Proliant BL460C G1 X5365 2G 1P Svr  Server Logo
74 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
