Question about Panasonic VDR-D150EF-S DVD Camcorder
I want to finalize a dvd-rw to write to a dvd disk for viewing?
I am battling to finalize my dvd-rw and do not know the error message connect to dc cable? Is there another way to copy my information to a disk?
  • gabri09 May 05, 2009
    i have mine plugged in to power but vdr displays message "cannot finalise" this means i only get the first clip when i download the vro file
To finalize you must plug in your AC power supply. then finalize your dvd.
Posted on Apr 22, 2009
When i insert a blank disk i get cannot format disk message
sorry that you getting this message......... but the ch-dvd 300 is not a recording machine........it only plays recorded DVDs
May 08, 2011 | Cyberhome CH-DVD 300 DVD Player
I am trying to record from cable tv to dvd and also dub a vcr tape to dvd. i've tried both dvd -r and +r. do i need to format these disks first, also when done do i need to finalize and or make compatible....
DVD-R and DVD+RW and +R are automatically formatted. DVD-WR can be formatted in VR or Video mode Finalization is necessary for -rw and dvd-r, but only recommended for dvd+rw and dvd+r
Apr 30, 2010 | Toshiba D-VR600
Camera will not allow me to finalize some dvd's
If your camera finalized the same type (+R, +RW, -R, -RW) of disk previously, the problem may be the disk itself. Some 2% of the disks (no-brand and copy-brand disks even higher %-age) are faulty and either do not allow recording at all or fail at some point.
Dec 05, 2009 | Sony DCR-DVD610 DVD Camcorder
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
I want the pictures and video off my DVD-RW on to my computer
Yes, you must finalize to view the dvd in a stand-alone dvd player.
No, battery doesn't have to be charged but the camera does have to be plugged in to do finalizing.
After, finalizing the disk, and you are in fact using DVD-RW (re-writable) disks, yes you can un-finalize them within the Canon camera to record more video.
I have used the same 3 rewritable disks on my Canon over and over again to record many hours of footage.
Apr 30, 2009 | Canon DC210 DVD Camcorder
Dvd recorder
Hi Nickstart, start checking if the problem is related with the kind of Disk and test on different brands, disk types.
Even if a recorder is supposed to work fine on both +R, -R etc. , often you find out, that due to error correction methor, a device worksd well on one or the other type.
Your DVD supports the following DVDs -R, -RW, -RAM, all -R disks are supported both on 3'' and 5''.
On +R it just writes regular DVD +R, DVD +RW and mini DVD +R are not listed in DVD specs, therefore are not supported on writing.
When your unit records DVD +R it changes the format to DVD-V, The usint does not support DVD+RV.
I assume it works better with -R
I often get troubles with many DVD low price brands, try testing some good ones like Verbatim, TDK, Sony , Philips etc.
See also the manual here, at page 6 and 7 it also says: "Play may be impossible on some DVD-RW (DVD Video Recording format), +RW, CD-R or CD-RW discs due to the condition of the
recording."
Hope this had been helpful, test both a good brand DVD-R and a Good brand DVD+R.
If it still has problems when finalizing the CD, then it can be the usual lens problem, Or the DVD you are writing is too big in size and your player has problem on the final phase of DVD writing. If Data nearly takes all the 4.7 Gb allowed, there won't be enough space to finalize the DVD.
Sep 08, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
Cannot intialize/finalize mini-DVD in Canon DC210
The way to get it to finalize is like this:
1. turn it on
2. use cord.
3.move the on buttom to mode. it will show the recordings.
4. select a recording
5.press function butom. it will up bring several choices among "menu"
6. slect menu
7. it will give you all the chioces you need to title, finailize, protect and all needed to view the dvd
Any questions,
let me know.
OL
Jul 13, 2008 | Canon DC210 DVD Camcorder
Dvd do not record
The unit is saying that its an "Un-format disc" problem. Is this the only error code you are getting? Also, what types of DVDs are being used? As in, DVD-R DVD-RW DVD+R DVD-RW and what speeds? 1x 2x 4x 8x 16x?
Apr 04, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Play Back
Some DVD players can't read -R & -RW disks. When you finalize make sure it is in Video mode not VR mode so the recorded disk will be able to work in most other DVD players. Also some DVD players only read recorded disks rated up to 1x, 4x, 8x, 16x, or a combination of these speeds.
Nov 13, 2007 | Emerson EWR10D4 DVD Recorder
Panasonic VDR-D150EF-S DVD Camcorder Logo
293 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
