Sometimes when i go to cut my tv on it clicks like it is comming on and then a few seconds later it clicks again and the red light flashes numerous times.. Have to unplug and replug several times to get the tv to come on....
  • rfazio417 Aug 21, 2010
    this is a 42PF9631D/37 philips 42" in plasma w/ambilight from 2006, does that matter any?
  • Televison & ... Master
  • 17,130 Answers
Possible that there is a solder joint problem in the main board. Since the TV comes on after you try to put the plug in several times, then this is quite possible. Use a good soldering iron to do this touch up job specially on high power components and on the suspected IC joints.
If you put the set On for some hours and then by tapping if the TV comes on then this fault is confirmed. Also please look for faulty capacitors, for capacitors that has leaked or reduced in value- look for bulged capacitor tops.
Please take care to attampt this job and not to tamper.
Hope this advice helps?
Posted on Aug 21, 2010
TV does not turn on? (Relay problem?)
The power supply could be failing intermittently. That's why it sometimes works and sometimes doesn't. Also, the relay could be erratic.
May 26, 2014 | Funai Magnavox 40" Class 1080p 60hz LCD...
I have a 2007 zx6r and it runs fine but the f1 light is flashing but as soon as you try to put it in gear it cuts out
Hi. There ae numerous forums/site for your bike's FI codes. Since I don't know what code your FI is flashing, all I can say is put the FI code into your computer google or yahoo search area, and you will get an answer. Yiur FI should flash a few times first, and that is the first digit in the sequence. A second later, it should flash again, and that is th 2nd digit in the code. an EXAMPLE is 2 flashes, pause, 3 flashes...then repeats. That will be a code 23. Trust me, you will find the FI code online. Good luck!
Apr 06, 2014 | 2004 Honda CBR 125 R
Power light is red and flashing. when we press the power button it sounds like it's trying to power on the light turns to flashing green for a few seconds and then the power cuts off and turns back to...
Flashing red light in Sony tv indicates that tv got some internal problem and went on protection mode to avoid further damage. Now it needs service/ repair.
Blinking red light also has an error code that has info about possible cause of problem, let me know how many times red light is blinking after 3 seconds ling pause and model number of your tv to provide you helpful info.
Thanks.
Feb 23, 2011 | Sony KDS55A2000 55" HDTV
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Jul 19, 2008 | Sony KDF-E42A10 42 in. LCD Television
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Philips 27PT6441/37
There is a install kit 483531057673 for this model when the set is dead. The kit will contain 7404 and the Horizontal Driver Transformer 5402 along with resistors that will limit stress on 7404 and includes complete instructions
May 03, 2008 | Philips 27PT6441 27" TV
Lamp problem or else?
You need to get the ballast repair kit #LSUC0002 and replace the parts to your ballast.
I have the exact same TV, did the above this past weekend, and the TV works like new.
You need to know how to solder though. It's not that hard.
Mar 14, 2008 | Panasonic PT-60LC13 Television
Televison & Video Logo
124 people viewed this question
Top Televison & Video Experts
Electro Med Services...
