Question about Kitchen Ranges
Thermador temperature - Kitchen Ranges
  • Bill Fraser-Harris May 03, 2008
    Sorry, I posted in another area by mistake. Thermador SEC302BP. Upper oven showed an F33 error code. Now does not reach temperature on any setting.
  • 3,422 Answers
Can you please give more details on your problem so that i can help you fix it?
Waiting for your reply.
Posted on May 03, 2008
  • Priya darshan May 03, 2008
    got some useful info for you CLICK HERE and check out the forum
    Thermador Main support number-> 1-800-735-5547
I have a problem with my Thermador PDC302/01. Oven temperature is way too hot and burns everything. It also takes forever to preheat?
-Sounds like the temperature sensor is effect. Check if it's not within specification then replace it.
-For me if it's too old I better buy new one instead repair.
Good luck
Jan 25, 2017 | Thermador Ovens
Thermador dual fuel oven temperature not accurate and the dials dont match temperature
Faulty thermostat it's the thin copper shaft in the oven that has a skinny tube running from it if you remove the oven knob you will find it goes back to the switch. Needs replacing.
Apr 21, 2014 | Thermador P304CS Gas Kitchen Range
Thermador temperature display start temperature
Send back for a replacement,obviously something definately wrong with that gauge reading 200 degrees at room temperature!!!
Jan 08, 2014 | Thermador PDR366ZS Dual Fuel (Electric and...
Thermador c272u double oven error code f33
over temperature. Check the oven sensor, if ok, replace the relay board for that oven (upper or lower)
Sep 16, 2012 | Thermador Ovens
Thermador Built in oven scd302 not heating upper oven, lower oven fine. Heating element not glowing red as the oven below it does.
Problem is usually either temperature probe or heating element.
Grab a multimeter and set it on impedance (Ohms).
Remove first temperature probe and then heating element.
If either probe or element is reading open (ohms infinity), then replace the part.
If both probe and elements are not open, then the problem is either wiring or oven electronic control. The most common fault resulting in no heat is the temperature sensor located inside the oven cavity.
May 31, 2011 | Thermador SECD302BPSS Electric Double Oven
The LED display on my Thermador dual-fuel range has become very very faint and very very hard to read.
Cannot Read Display or See Temperature Thermador RDDS30 can repair this failure for you. They back their workmanship with a two year warranty as well.
Contact them if you have any questions --
May 26, 2011 | Thermador Professional Series PO301...
Teperature i snot rising above 100, why?
Assuming your Thermador is electric, and it is only warming up a little, this is usually one of three things:
1. Heating element - with oven power disconnected, check that the elements resistance is in spec. Usually around 20 ohms.
2. Thermistor - this senses the temperature of the oven. Again, check the resistance. Depending on your model, it should be around 1050ohms at room temperature.
3. Electronic Control Board. These can be rebuilt quickly and reliably at Some are still available to buy online.
Hope that helps
May 21, 2010 | Thermador SMW272 Electric Double Oven
Set covection baking temp / Thermador MCES
We have the owner's manual and have uploaded it to our site for you here.
Dec 24, 2009 | Thermador MCES MCEB Convection Microwave...
Thermador oven display is dimming
replace the capacitors on the display unit. Just did this and it now works
Nov 29, 2007 | Ovens
Kitchen Ranges Logo
57 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
