Question about Whirlpool ED2FHSS Side by Side Refrigerator
Fridge not getting cold, making clicking sound - Whirlpool EDSFTG
  • Whirlpool Master
  • 909 Answers
Basically, the clicking sound is the compressor trying to start. It has siezed and needs replacement. Unfortunately if you ar'nt a refr. technician, then you will need one. (all the tools etc).
Posted on Aug 21, 2010
Fridge makes clicking sound every 60-90 seconds..freezer defrosting, fridge not staying cold.
If the clicking sound you are hearing is from the back of the refrigerator near the floor then I believe the sound is coming from the start relay that is located on the side of the compressor.
Replace the start relay with a new one and you should be good to go unless the compressor has been damaged.
The start relay is easy to replace as it just plugs into the side of the compressor. Start relays are also often very inexpensive.
Make sure to use your model number and get the factory direct replacement start relay and not a 3n1 universal start relay.
Aug 07, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Tip
Whirlpool Fridge
I am having trouble with my Whirlpool Fridge single door fridge. The top freezer is getting too cold and freezing the food too much and the bottom of the fridge is not cold enough, changing the settings on the fridge only makes it worse.
I have just recently chenged the fan, so what could be the proplem and how can I fix it.
on Feb 11, 2008 | Whirlpool ER6AHKXPQ Top Freezer...
remove the rtc overload off the compressor and shake it,if it rattles thats your culprit,also if when its running and the compressor is quite warm to the touch,its only running on the start windings and isnt actually running right and will overheat and ruin the compressor,replace the rtc its cheaper than a new compressor
Jan 25, 2010 | Whirlpool ED2FHSS Side by Side...
Freezer Cold Fridge not cold, vents clear of obstructions. Vent at top left of fridge making a clicking sound, some cold air coming out of vent, probably not enough,Freezer control on 2 ,Fridge control on...
Need to defrost fridge completely for about a day then switch on again. Possibly door was left ajar on freezer, or auger motor iced up due to product being to close to outlet..
Sep 21, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Clicking sound and warm temps
Sounds like the compressor is frozen and won;t turn. a slight chance that it starter relay is bad, you will need to get a repairman to check it out.
Jul 26, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer not freezing food and fridge not staying cold enough
Check the compressor with a volt meter, if the compressor is getting proper voltage then check the relay. But this sounds like a problem with the compressor
Feb 12, 2009 | Whirlpool GB9SHKXL Bottom Freezer...
Fridge & wont get cold wont get cold, fans is on motor gets hot
check to see if compressor is running if not replace relay also make sure ur condenser motor is running
Jan 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Not cold and clicking sound
I HAVE THE SAME PROBLEM AS JASON
Aug 24, 2008 | Whirlpool GD5SHAX Side by Side...
Clicking Fridge
I used to have a whirlpool fridge, they are the ones who make kenmore too. It used to make a loud thud noise. It was the compressor turning off. sometimes it was loud enough to wake me up at night. It did this for years and I never had any problems with it. when I purchased a larger fridge I sold it to a friend and its still working today. If you can tolerate the noise I wouldn't worry about it unless it starts giving you trouble.
Nov 01, 2007 | Refrigerators
Whirlpool ED2FHSS Side by Side Refrigerator Logo
64 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
