Question about Kenmore Elite Oasis 27052 Top Load Washer
When doing a load, our Kenmore Elite Oasis Washer must of had an unbalanced load. It moved about 2' from it's original location and the drum dropped. Do I repair or just throw it out?
  • 15,935 Answers
It appears your vibration damper has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
OL code and fixing it?
The machine may have a defective overload sensor.
Jul 21, 2017 | Kenmore Elite Oasis 27052 Top Load Washer
Why dose my kenmore elit oasis he washer keep geting unbalanced with or with out a load in it
Possiable it has a broken yoke on the inner drum, Mine broke completely off. Lucky it was covered by Sears warrenty. Cost is over$1,000 to repair with out warrenty.This is a common problem with He Washers..
Sep 30, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite 110.2706 unbalanced load problems
I have the same problem with my washer though it is a Maytag. the part that grips the drum to spin it is stripping, (and not properly grabbing). Repair man said to just get a new but I'm sure if you find a dedicated enough repairman he may be able to replace that part. The repairman said to replace mine because it was over 8 years old.
Sep 08, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite oasis washer makes noise and unbalanced
If your washer start going to high speed and it make unbalance and bangin on the frame. there was a stator may need replace....good luck
Nov 28, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Oasis washer unbalanced load. Every load I do when it gets to the spin cycle, it shakes all over the place and says it unbalanced. I've tried reloading everything, taking things out, begging and...
I have the same problem, and the feet ARE adjusted right and it's on a hard floor, mine is a recent problem ...just started doing it about 2 months ago( EVERY single load!) .... Irritating......
Sep 24, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore Elite Oasis washer unbalanced signal seems to be very sensitive. Only after several tries of readjusting the load to get it really even that the washer will spin without stopping. I made sure...
If the washer throws an UL error code with out any clothes in the washer then the issue must be concerned with the mechanical alignment inside the machine or a bad CCU.
The most common problem which can cause this is some sort of mechanical hinderance which does not allow the basket to move freely.
The suspension system which holds the basket in its place might be faulty and causing the unbalancing. In this model i think there are plastic ring at the bottom of the basket . Even if they are worn out or moved out of position it may cause the UL error code you are facing
Nov 09, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore Elite Oasis starting to show "UL" and immediately stopped working. How do I fix this issue?
UL = Unbalanced Load
re-distribute the clothes and re-try.
Aug 24, 2010 | Kenmore Oasis HE 27082 Top Load Washer
My drum is unbalanced
Check whether suspending springs are damper of the wash tub in proper position.
Check your floor surface level and adjust the washing machine suitably.
Apr 06, 2010 | Kenmore Elite 45986 Front Load Washer
Constantly off balance
I have a kenmore elite oasis top loading washer about 3 years old. I took it apart and checked the springs and the rods and the plastic ends that hold the rods in place and all of them look fine. I run an empty load in the washer and it still goes unbalanced on the spin cycle. My water bill has tripled due to the fact that every load takes 3 to 4 washings. I need help please!
Jan 02, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis becomes unbalanced all the time
Its a tricky repair. there is a spring that sits on the base of the motor. You need to remove the pulley and plastic gears to gain access. This spring is slipping causing drum not to spin correctly. Remove it and clean properly with solvent . If broken replace. Reinstall and retry.
Sep 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
186 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
