Question about Kitchen Ranges
I have a zoeller backup pump, water powered and it doesn't turn off. I strat the water supply, it works good, but when it drains the water and the float drops down - it still runs. The pump is model 503 and it is brand new.
  • Kitchen Ranges Master
  • 17,129 Answers
The cut off switch attached to the float switch is faulty. when the float drops, the switch should be activated with the float going down. Check the sensor to this which goes to the control unit. If the drive or the sensor amp on the water level controller is faulty , you will have to change after identifying the section with a simple voltage check.
If this is a new unit , then please avail the privileged warranty of the unit. get a replacement if you can talk to them and that would be the best than to open and tamper.
Hope my advice helps.Credit if you think so.
Posted on Aug 21, 2010
Testimonial: "Thanks for your advise, it helps. I thought that that may be te issue, but I was hoping that it is not for a simple reson that the sump pump is new."
Have a Zoeller 710 backup sump pump and keeps blowing fuse, whats the problem?
Make sure the impeller is as clean and clear as possible, anything clogging it and restricting its rotation will cause it to blow a fuse. If tis not turning easily and feely most likely the bearing is starting ti seize up.
Aug 13, 2014 | Zoeller Powered Emergency Backup Sump Pump...
My Zoeller M57 pump has stopped working. It won't even turn on...is there a reset switch or some other easy fix for this?
These Zoeller pumps are very good quality> I suspect that the float switch is not working, which is why the pump is not turning on.You may try giggling the float arm that is attached to the switch. You can also try spraying some WD 40 into the switch where the arm enters. Zoeller does have replacement parts for their pumps. Review their website for your pump parts.
50 Series Zoeller Pump Company
Apr 07, 2014 | Zoeller Sump Pump, 3/10 HP - M57
I have a Zoeller Water Ridd'r II Model 48 Sump pump. The pump comes on okay, but will nit shutoff. The float is not impededd, it's just laying on the bottom of the sump. Is this a defective...
If I undrestand your description, when the resevoir is empty, the float lays on the bottom of the resevoir but, the pump doesn't shut off, after water is pumped out? You have to look at this as opposite of a toilet tank filling with water. In a toilet, the water rises and the foat turn the water flow off. In a sump the water will rise, and the float will turnthe pump on until the resevoir is empty, then it will open the system and turn off the pump. If the float doesn't rise, the resevoir will overflow and the pump won't come on at all. If the float rises and the pump comes on but, the float does "not" drop, the pump will continue to run after the resevoir is empty.
http://www.zoellerpumps.com/ProductByCategory.aspx?CategoryID=3
This is Zoellers link. I don't see your pump but they do have a support link. If the float rises and falls with the height of the water, turns pump on, then drops "all the way" and pump doesn't turn off, the switch is bad not the float. Make sure there is nothing in the way of the float dropping to it's full down position.
Jul 03, 2011 | Home
Water does not drain,how do I access the pump
Hi jolanda03,
Remove the Top Panel, fastened by 2 screws at the back, Then remove the right Side Panel, you should see the Drain Pump attached to the sump. To test it, you could attach direct power to the two pins on it (Alternating current, so position of connectors unimportant). If it works, it could be either that it is not receiving power from the PC Board, or the sump is clogged inside (Filter).
Hope this helps, if it did please rate with 4 thumbs up. A testimonial would be nice too. :-)
Apr 21, 2011 | Dishwashers
Where can i buy a replace float road for a m98-b zoeller water pump
zoeller is a pump normally found only at plumbing and heating supply houses. they should carry or can order thge part for you
Jan 04, 2010 | Zoeller M53 Mighty Mate Iron Body, Poly...
Sump pump float adjustment
This really depends entirely on you. the higher the water level the less frequently it will run. most motors use more power to start than they do to run so starting less should save you money.
Nov 16, 2009 | Zoeller 10-0034 Switch-Mate Pump Float...
Hi, My Zoeller m53 pump is 9 years old and stopped draining water out, but once the float is engaged, the motor runs. So do you think I need to remove the bottom plate to remove the clot? I cleaned out the...
youn will need to change the pump if it is 9 year old, it had a good life but when they work in shalow water is one ting once you submerge it it doesn't pump, it has just lost it power and not worth taking it all apart and replacing the parts, the impeller is worn out and thats where it gets it's pressure from how it turns to pull the water out and force it thru the outlet,,
Jun 28, 2009 | Zoeller M53 Mighty Mate Iron Body, Poly...
Zoeller sump pump, outside in stairwell. Rainstorm, alarm goes off, i look out, does not seem to be running or maybe it was not sure, rain was slowing down so I silenced the alarm and went back to bed. In...
Sorry to say, but it does sound like the pump is fried. It should come on(run) when it's plugged in. The fact that the water surrounding the pump was hot is a good sign that the pump was way over-heated. Also, that oil in the water is likely from the pump. Oil is used in the pump for lubrication and to water proof the inside of the pump.
The only thing I can recommend is to see if the bottom of the pump has a removable strainer or plate, and if so, see if debris has gotten inside and bound up the impeller.
Jun 27, 2009 | Zoeller M53 Mighty Mate Iron Body, Poly...
Water backs up in the floor drain during heavy downpour even thou
the sump pump shold not be run into the sanitary sewer, but if your floor drain is hooked to a sump pump pit and it doesn';t pump the water before it gets to the drain tile it could come up in the drain,, to solve the problem get a pump that the float is lower in the pit,, suggestion zoeller cast iron submersable pump cost about 100 less the install price, great low profile pump, it keeps less waterin the sump pump pit so there is less mosture
Mar 11, 2009 | Invacare Supply Group Invacare Top End...
Rapid on/off switching while crock is drained below float level
check the check valve it could have mud or just debris on the flap,, take it apart and clean it out see if this doesn;'t help after that you might just want to change the pump if it is in a high volume usage, area
Feb 13, 2009 | Zoeller M53 Mighty Mate Iron Body, Poly...
Kitchen Ranges Logo
150 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
