Question about Kenmore Elite Oasis 27052 Top Load Washer
During the spin cycle, the tub makes a lot of noise and stops. It will not complete the cycle. I believe the tub is off track. How can I get it back on track without asking sears to charge an arm and a leg to fix it? Thanks, Ben
  • Kenmore Master
  • 12,061 Answers
Https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/68589b9b3ebd030c8525736100667580?OpenDocument
Please find above your service and repair manual.
Most likely you "Dogs" are broken, these can be replaced...See the service and repair manual.
Please have a look at this website below, you will see there that customers have contacted Kenmore, and they have had it fixed for FREE.So I suggest you try to first follow their example if you qualify.
http://forum.appliancepartspros.com/washer-repair/26832-kenmore-elite-washer-thumper.html
Posted on Aug 21, 2010
The spin cycle is very noisy. What could be the problem?
hi robyn.
A washer making a loud noise during spin cycle can also be caused by a faulty drive pulley. The pulley is what the belt (if applicable to yourwasher) rides on to spin your washers tub. The pulley can be made of plastic or metal. It could be simply worn out or just loose.27 Jul 2015
How To Fix A Washing Machine Making Noise During The Spin Cycle ...
https://removeandreplace.com/.../washing-machine-making-noise-during-the-spin-cycle-...
or try this link might help you.
washing machine spin cycle is very loud Google Search
Nov 18, 2017 | Washing Machines
The washing machine makes a lot thumping noise during the drying cycle. Sounds like it is bout to take off. A lot of rubbing during the wash cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Dec 12, 2010 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
I have a zanussi washer/dryer but lately its making so much noise !! its driving me nuts please tell me what it could be ?? thanks
Hi
Thanks for using FixYa. If your washer is a front load washer then check these things if it is making noise--
Bellows
The bellows is a rubber sleeve that seals the suspended outer tub to the stationary cabinet front at the tub opening. Its purpose is to provide a water tight opening into the tub that can be sealed by the cabinet door, yet allow flexibility for the oscillation of the tub during the wash and spin cycles.
Outer Tub Assembly
The outer tub assembly is supported by two suspension springs and stabilized by two air shock assemblies. A cement counter weight is mounted to the front of the outer tub by screws. A counterweight is molded into the rear half of the outer tub. These counterweights prevent excessive oscillation of the entire suspended assembly during an unbalanced spin cycle.
Spin Basket Assembly
The spin basket is constructed of stainless steel. The circumference of the basket is perforated to allow water to flow through it as it revolves. A heavy steel shaft is pressed into the spin basket support which is then bolted to the basket. The spin basket assembly is entirely supported by two ball bearings pressed into the rear of the outer tub. A large drive pulley is mounted to the free end of the shaft that extends through the rear of the outer tub. There are three plastic vanes mounted to the spin basket to aid in the washing action during the wash cycle. The rotation of the spin basket provides both the washing action during the wash cycle, and water extraction during the spin cycle.
High pitch "jet engine" noise--A certain amount of motor whine is normal during the spin cycle.
Rattling and clanking noise--
• Foreign objects such as coins or safety pins may be in drum or pump. Stop washer and check drum. If noise continues after washer is restarted, objects may be in pump.
• Belt buckles and metal fasteners are hitting wash drum. To prevent unnecessary noise and damage to drum, fasten fasteners and turn items inside out.
Squealing sound or hot rubber odor-- Washer is overloaded. Do not overload washer. Stop washer and reduce load.
Thumping sound— Heavy wash loads may produce a thumping sound. This is usually normal. If sound continues, washer is probably out of balance. Stop washer and redistribute wash load.
Vibrating noise--
• Washer is not resting firmly on floor. Move washer so it rests firmly on floor. Adjust leveling legs. NOTE: Some shaking of the washer is normal without moving across the floor. See INSTALLATION INSTRUCTIONS for details.
• Shipping bolts and foam blocks have not been removed during installation. See INSTALLATION INSTRUCTIONS for removing shipping bolts and foam blocks.
• Wash load unevenly distributed in drum. Stop washer and rearrange wash load.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 10, 2009 | Zanussi ZWD12270 Front Load Washer / Dryer
Washer sounds like off balance during spin
old duets have nut on rear pulley that becomes loose. remove rear panel and tighten nut. check while spinning by hand if pop is felt. if it rotates smoothly then you may need new shocks on tub
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Roaring noise during spin cycle
The roaring noise is from the drum bearing and it will only get worse with time until it fails completely. You will need to replace the rear tub assembly which is about $300 for the part. The rear tub assembly part number is 285984. It will take about 2 hours in labor.
Make sure you are using HE (high efficiency) detergent and only about 2 tablespoons per load.
Mar 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Loud noise during spin cycle
is it more like a roar or a train going by? if so your rear tub bearing is going out. very expensive have to replace the tub, basket, spinner ring and shaft and seals about 4 hrs for an exprienced tech to do took me 7 hrs to do for the first time. but it will be very close to $1000 to have done not much less to do it yourself.
Mar 09, 2009 | Washing Machines
Amana Washmachine (not all water removed during spin) ALW780QAW
you may have blockage in the drain pipe several feet from washer. if you can run spin cycle with hose in different location ex. tub,sink or outdoors. if this works run long snake down washer drain pipe to clean gypsum residual.
Jan 28, 2008 | Amana ALW780QA
MAYTAG Wahing machine model MAV6000AWQ
I believe your machine is equipped with a "snubber plate" under the transmission. A lot of Maytag top-loaders are. This is a white teflon ring that is used as the wash tub and transmission support and assists in dampening vibrations during the spin cycles. It's located on the inside case of the machine under your transmission. When the snubber goes bad they generally start to squeak. They cannot be lubricated and must be replaced. If you try to oil them, they will eventually disintegrate. The snubber costs less than $10 to purchase. I hope this helps.
Apr 04, 2007 | Maytag MAV3855A Top Load Washer
this is my experience repairing the maytag washer Atlantis mav series 9750 aww, I had to replace the spin bearing since it was making a jet engine noise when it was spinning out the water. its not an easy job for my 1st time taking this machine apart, you literally take it all apart to get to this bearing, but now I can show how to do it with pictures making it easier for you to do it. even if you have to replace something other than the spin bearing, this how to tutorial will show you how to get to most of the parts in this machine
tutorial located here tutorial located here https://sites.google.com/site/maytagwasherrepair/maytag-washer-repair
Jan 02, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
282 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
