Question about Refrigerators
NO WATER OR ICE AT DOOR OR IN ICE MAKER
MODEL SXD22S2L AMANA SIDE BY SIDE REFRIDGERATOR . I HAVE CRACKED THE FITTING AT BOTTOM OF FREEZER DOOR AND I HAVE WATER PRESSURE THERE. I HEAR THE MICRO SWITCH ACTIVATE WHEN I PUSH IN ON THE WATER DISPENSOR ARM, BUT I DON'T HEAR A SOLENOID ACTIVATE AND WATER DOES NOT COME OUT. I WOULD LIKE TO SEE A WIRING AND PLUMBING SCHEMATIC TO HELP ME TROUBLESHOOT. THANKS.
    Problem Solver:
  • 7 Answers
This is Gene's solution not mine, for a Ge fridge.
Assuming the ice dispenser works fine, the first thing I would check is the water filter, then the water inlet valve on the back of the fridge.
If the water filter is more than a year old it will cause restriction to the water flow.
Locate the water inlet valve on the back of the fridge. Remove the wires from the blue solenoid and check for 120V coming to the solenoid while the water dispenser lever is depressed.
If there is 120V then the water inlet valve has to be replaced.
Posted on May 03, 2008
I have a side by side refridgerator freezer. I have just connected the water to the ice make / water dispenser for the first time and just a short trickle of water flows into the ice cube maker - not
I would guess that you need to purge the air out of the lines and system for it to work correctly. You can hold down the water dispenser for awhile to help, but if you do nothing, it should purge itself over the next few days.
Jan 07, 2012 | GE Refrigerators
I have an Amana refridgerator, BRD18V13, and the ice maker stopped making ice. What's wrong?
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects theb you need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 23, 2011 | Amana Refrigerators
Whirlpool refridgerator is leaking water on the freezer side (side by side refridgerator) onto the floor. The ice machine was overflowing with ice and has frozen ice in the ice maker that won't budge. We...
WAS IT LEAKING FROM INSIDE THE FREEZER OR FROM BOTTOM OF FRIDGE? ONCE IN A WHILE YOU NEED TO TAKE OUT THE ICE BIN AND DUMP ICE OUT AND CLEAN IT. HOW CAN THE ICE MACHINE OVERFLOW WITH ICE WHEN THE ICE IN THE TRAY WON'T BUDGE? NEED CLARIFICATION. SOUNDS LIKE YOU EITHER HAVE A BAD ICE MAKER MODULE OR THE SOLENOID FOR THE ICE ON THE WATER VALVE IS BAD.
Jan 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Amana side by side fridge model sxd22s2l freezer/fridge not cold
they can get up to 305 degree F they can make brown spots on floor... yes they get very hot(is normal)
Aug 20, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Our Hotpoint side by side refridgerator, the ice/water not workin
It sounds like you have a failing relay/valve that wont stay open when current is passed through them, check there first otherwise your control board could have water/heat damage remove inspect and if necessary replace let me know how it goes :)
Jul 11, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Ice maker drips water
In most of theses cases the dripping is caused by the molding in the ice maker cracking and the water is wicked out. On some ice makers you can replace the complete molding but its usually easier to just replace the ice maker.
Nov 02, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana Refridgerator Freezer, French Doors
Most side-by-sides have a length of hose at the bottom of the freezer that send the water to the ice maker and water dispenser. take the back off so you can see this hose, there may be a kink in it, or a clog.
May 30, 2008 | Amana ACD2232HR Side by Side Refrigerator
Refrigerators Logo
304 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
