Question about Fujitsu 24C1 Air Conditioner
There is water dripping out of my fujitsu split air conditioner
    President:
  • 3,773 Answers
Sounds like the drain needs cleaning if not clean the unit complete
inside pan and coils with a coil cleaner purchased at your Appliance repair store or A/C parts and Repair shop.
Don't forget to tilt the unit back a bit off level.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 21, 2010
5 Suggested Answers
  • 43 Answers
SOURCE: I have two Fujitsu Split Air Conditioners which
I think the AC's are not levelled properly so their is a leaking or the water tray might be filled up
Posted on Jun 16, 2009
daddyo742001
  • 70 Answers
SOURCE: air conditioner dripping water
Try pouring some bleach in drain.
Posted on Jun 28, 2009
SOURCE: water dripping from internal unit
Hi
This can be due to three reasons. The water drain pipe is block. Which can be sucked clean with wet/dry vacuum cleaner. The drain pipe behind the unit is not sloping downward away from the unit. Or the coils of the internal could be iced up. If this is the case the unit should be switched of until the ice is completely melted and switch the unit on again. If the copper pipes leaving the the condenser unit outside is starting to freeze up, the unit is short of gas. Call a A/C company to refill the gas and search for possible gas leaks.
Posted on Jan 26, 2010
  • 64 Answers
SOURCE: Fujitsu split type air conditioner
Typically if you go outside directly behind the inside unit you will probably see a white colored tube, this is the drain and if you have a wet/dry vacuum you can clear it with that. The actual drain can vary but it makes sense to exit and drain asap.
Posted on Jun 19, 2011
Water is dripping out front of fujitsu air conditioner what would cause that
You could just have a blocked drain line, or it could be low refrigerant and bottom of evap coil freezing up blocking water flow. Most common is blocked drain line. Also very dirty air filter.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_70df8fb57a5e233e
Feb 23, 2015 | Fujitsu Heating & Cooling
Fujitsu split system
there might be a crack on the drain hose
Jun 01, 2013 | Heating & Cooling
I have a Fujitsu air conditioner, model # ASUI8CI serial # ACA010576. It drips water into the room from the right side. After switching off the air conditioner and wiping the water, I switch it on again...
chances are either the unit is not level or the drain hose is not pitched properly going through the wall when water is leaking is there water coming out of the hose outside
Jul 11, 2011 | Fujitsu 24R1 Air Conditioner
Water dripping from airconditioner inside the house
Water leak is the common issue in split a/cs. Due to coil,air filter, drain pan dust blocked, less rpm of blower motor, short of gas.
If service for the unit is more than 4 months, please do it first. And then check rpm of blower motor, if less replace capacitor.
Check gas pressure. Must be 60 PSI @ 98*F, of ambient temp. If less than that find leak and arrest and do gas charging. Thanks.
Jan 28, 2011 | Fujitsu 24C1 Air Conditioner
Water dripping from air conditioner
It's because of non-maintained air conditioner. Clean air filter, indoor coil, blower wheel and also drain pan. Insulate freon pipelines properly and tightly. After that run the a/c. If still water dripping. Check indoor f.motor speed. If less replace capacitor. If f.m. is o.k, check gas pressure. If less, there will be ice formation over the coil and water dripping will be there when it melting. If short of gas, check for leak and rectify. Thanks. Helpful?
Jan 16, 2011 | Fujitsu Heating & Cooling
Water leaking out of hose on a fujitysu split system ast24rga
Normally, an Air Conditioner removes water from the air and that water condenses on the coils of the inside section that does the cooling. The water condenses on the cooling coils just like moisture condenses on the outside of a glass of ice water.
This excess water drains out of the cooling section through a "drip tube" and is supposed to drain outside of the house, or a drainage system. Your "drip tube" has either not been installed (if it is a brand new installation), has separated and water is now dripping into the house instead of outside of it. Or it is clogged. This happens when algae builds up inside the "drip pan". If that is the case, you can purchase "algaecide" tablets which kill the algae that is clogging the drip pan and preventing water from draining out through the drip tube. These tablets can be found in many hardware stores, refrigeration supply companies, or even Walmart. You can put a tablet inside the pan. (You will have to remove the cover of the unit). You can often use a little bit of Bleach and that will act as an algaecide. Hope this helps,
Best, Mark
Dec 26, 2010 | Fujitsu Heating & Cooling
Water dripping from air con use
If the unit is mounted on an outside wall check the condensate drain that comes out with the line-set to the outdoor unit. If the pipping goes up into the attic than you have a small condensate pump that may have failed. The float in the pump may have stuck in the down position not allowing the pump to come on.
Nov 08, 2009 | Fujitsu 24C1 Air Conditioner
Air conditioner dripping water
Jun 28, 2009 | Fujitsu 12C1 Air Conditioner
Fujitsu wall mounted air conditioner.
 during Cooling and Dry modes, if the unit is used under conditions of
lower temperature (18C)  the heat-exchanger may freeze, leading to water leakage and other damage.
If the unit is used for long periods under high-humidity conditions, condensation may form on the surface of the indoor
unit, and drip onto the floor or other objects underneath. (About 80% or more)
Increase Temp to 20 and also run coil dry cycle,
Jun 03, 2007 | Fujitsu 24C1 Air Conditioner
Fujitsu 24C1 Air Conditioner Logo
541 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
