Question about Mtd Arnold Corp 38" /42" Mulch Kits
Is the 38" Mower Deck for a Master Cut interchangeable with a 38" Weedeater Deck?
3 Suggested Answers
philwalker78
  • 608 Answers
SOURCE: vibrating 38" deck on MTD yardman mower
Hi, first replace the blade spindle bearings, if you had to hit them to free them up the bearings are shot. Secondly, replace the deck belt. Because you engaged the blades with a siezed bearing the belt will have a worn section where the v will be thinner thus causing the vibration as it passes through the pulleys. Regards Phil.
Posted on Jun 20, 2012
Testimonial: "Excellent answer,just about what I figured,except I wasn't aware the belt is probably damaged from rotating on a frozen spindle.Thanks a bunch,love this site!"
  • 530 Answers
SOURCE: Where do the springs connect on a bolens 38 inch mtd fiding mower deck
On the spring hooks
Posted on May 25, 2015
How to replace a belt on a murry lawn mower 38 inch cut
drop the deck and pull out from under the tractor . many have a diagram on the deck as to routing . then put back on tractor
Aug 11, 2015 | Garden
I have a poulan 38" mower. Something seems to be wrong with the deck. The left side cuts great, but not the right. The right side seems to beat the grass into submission. If I back up over the same path I...
check mower blades for blade upside down. you may be hitting grass with back of blade. match blade position to working blade side. or swap blades left to right and see if problem moves. if so, blade is culprit. also cold be a loose blade bolt allowing the shaft to spin without driving the blade. Do all work with engine off key out!
May 16, 2013 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
How to put deck belt on
need a diagram of how to put a deck belt on a 15.5 hp/38" cut 5 speed poulan lawn mower model number 9601200-3801
Jun 22, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
What size drive belt does a 38in deck require? just bought a mower with no belt? Thanks
it depends what kind of mower you have, i have a 38'' mower that uses a 14'' belt.
Jun 12, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Mower will not drive
Usually, that's an indication the the seat switch is not working. It's like getting off the seat without locking down the parking brake or getting off the seat with the baldes engaged, same result...engine dies.
Jun 02, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Need deck belt for older chaftsman mower
Try www.searspartsdirect.com and type in your model number. They'll let you know what is still available and you can order directly from them online.
May 18, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a mtd 13.5 horse 38 inch cut 6 speed its around a 2007 or a 2008 i need to se how all the belts go on the mower deck and drive
Most mower decks have the diagram on them, if not go to MTD.com and put your model number to see the diagram.
May 02, 2009 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Weedeater 12.5 hp 38
thats a ayp deck.
the 38 and the 42 take the same belt
Aug 29, 2008 | Garden
Weedeater brand riding mower
Weedeater Rider mowers were made by American Yard Products you can contact them for a parts list
Apr 16, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Mtd Arnold Corp  38" /42" Mulch Kits Logo
54 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
