Question about Motorola Televison & Video
Have motorola src 300a remote and holding select and mute together isn't making led light up.tried with several new batteries. still works cable fine
2 Suggested Answers
SOURCE: Remote control problem
hold select and mute until led light flashes then use up arrow until tv shuts off. when tv shuts off press select to save
Posted on Feb 02, 2009
Ricketfish srs wow - mic is not working
  • Press the PWR button on the wireless receiver to turn the unit on. The headset has a sleep/standby mode feature to preserve battery life. The unit goes into sleep mode if there's no input for 3 minutes.
  • Twist the tip of the microphone so the sound holes face your mouth.
  • Position the microphone several inches away from your mouth so it does not overload when you speak. Try to balance the microphone position and the volume setting for optimum voice level.
  • Press the ALL MUTE button (the Rocketfish logo) on the left side of the headset once to make sure that the All Mute function is not activated. The LED on the wireless receiver will light red when All Mute is activated.
  • Make sure that the volume on the wireless receiver is not turned down or muted. The LED on the wireless receiver will light orange when Mute is activated.
  • Rotate the CHAT VOLUME dial on the wireless receiver to control the chat volume.
  • Make sure the USB cable is connected to both the wireless transmitter and your device.
  • Make sure that all connections are correct and secure. Sometimes a cable may appear to be connected but it may not be pressed in all the way.
  • Make sure that the wireless receiver batteries are installed correctly. See Question 19.
  • Make sure that the wireless receiver batteries do not need replacing.
  • Make sure that the microphone isn't plugged into the Line In port (or vice versa).
  • Make sure the headphone jack is pushed all the way into the port.
  • If you're using an Xbox 360
    • Make sure the wireless receiver is connected to the Xbox 360 controller using the supplied chat cable. On the wireless receiver, press firmly, so no part of the silver jack is showing. This tight connection helps to make sure the cable does not fall out during gaming.
    • Try a different Xbox controller.
    • Try recording a message to a friend by selecting My Friends, Send a Message, then Add Voice. If you can hear yourself, the chat problem could be a game issue, a problem on the recipients end, or some other variable not related to the headset.
  • Try testing the microphone by connecting the headset to a smart phone and make a test call or record a memo. If you can hear yourself, the chat problem could be a game issue, a problem on the recipients end, or some other variable not related to the headset.
If these steps don't work, then I would advise seeking replacement.
Jan 21, 2013 | Rocketfish Srs Wow Wireless Gaming Headset...
No sound on tv but volume is up
If you have an older style television and you have cable-then you have 2 remotes-somehow,the tv part went on mute but when you check your sound with the cable remote-it shows high level of bars which makes for confusion!Get out the old tv remote &select your menu then sound &take it off mute----You'll probably see see--sound off! Turn sound on and adjust your sound bars with same tv remote till just a bit more than 1/2 way up.That way you will not have to use cable remote to make it louder-much.In case,you forgot where you put your tv remote& only have cable one--think you can still get it off mute--byshutting down the cable part(which you have probably done several Xs by accident)---and then with cable light not coming on-right- only the tv light =try & adjust with cable remote by pressing mute button-should see MUTE go off!Then bring your cable button back into play and should be all set to go.If that does'nt work and your tv is still a tube tv might need a new part.But hope it was the simple problem.& that I managed to help you.Bye.
Aug 17, 2012 | Televison & Video
I need remote codes for a src-300a to a toshiba tv
One of these three codes should work: 0156, 0060, 0154
In addition, here are the commands to get your remote into programming mode should you require them.
  • Press the LED button and hold it down until the LED Flashes.
  • Press the REC button. The LED stops blinking at this point and stays solid.
  • Press and release the POWER. The remote is now in TV Code Scan Programming Mode.
  • Press the UP ARROW (above SELECT) button to scan through all the TV codes. When you reach the correct TV code, the TV will automatically turn off.
  • Press the SELECT button to store the TV code. The LED flashes rapidly then stops, indicating code has been stored.
Dec 26, 2011 | Motorola Televison & Video
Need code for cable box(motorola)and tv(rca) can
The RCA TV codes for an Innovage Jumbo Remote are: 000, 003, 004, 005, 007, 009, 011, 015, 048, 082, 092, 094, 096, 098, 101, 102, 103, 107, 113, 125, 129, 167, 179, 187, 188, 191, & 194.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
There are so many codes to try, you may want to try the auto-search function that I am going to describe below.
I don't see a code for a Motorola cable box, so I advise using the auto-search function for CABLE or SAT.
To have the remote try each CABLE or SAT code it knows one at a time, follow these steps:
  1. Turn on your cable box.
  3. Press the CABLE or SAT button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the cable box turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the cable box turns off, press the ENTER button to store the code and the LED will turn off.
To program the remote for your TV, repeat this process starting with turning the TV on, then follow the steps substituting the TV button for the CABLE or SAT button.
I hope that helps.
Nov 16, 2009 | Innovage Jumbo Remote Control
Need code-Innovage Jumbo remote for Motorola cable box & GE tv
The codes for a GE TV are: 000, 021, 053, 063, 115, 117, 120 & 134.
  1. Turn on your TV.
To find the right code for the Motorola box, I recommend auto-searching through the CABLE and SAT code lists.
I hope that helps.
Jul 18, 2009 | Innovage Jumbo Remote Control
Jul 11, 2008 | Televison & Video
Find a tv code for my prive soyo.
You can find the remote control codes for difrent brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
May 02, 2008 | Motorola Mobility DRC800 Universal Remote...
No code for Polaroid LCD TV
Code Polaroid 1250.
if it does not work try SEARCHING FOR CODES
If none of the codes listed under
“Device Codes”on the back of this
guide match your device, you can
search for a set of commands that will
work. Your remote will sample all the
codes in its system for that device
mode to find one that will allow you to
control your device. 1. Press and hold a device mode
key (AUDIO, DVD/VCR, or TV) for
at least six seconds. The LED for
each device key lights up, then
the key for the device you
selected remains on. 2. Press a function key (such as
Power or Mute). The following
function keys are valid for
Searching (Power is
recommended):
• Power
• Mute
• Play
• CH +
• Stop
The device key’s LED blinks
three times, then turns off. 3. Press (up) The remote will send
the IR command for the function
you pressed in Step 2. 4. If the device performed the
function you pressed, press OK.
The remote will now control the
device you selected in Step 1.
If the device did not perform the
function you pressed, repeat step
3. Press (down) to retry the previous
code. rmarti Colombia
Apr 05, 2008 | Motorola Mobility DRC800 Universal Remote...
Tv remote src350a motorola
Turn on tv press and hold the select button and mute. Hold until LED button lights up. Press up arrow, release, press and release. The light will blink each time you hold the button. When tv turns off press select to store the code. Changeing the stream press and hold mute and select release when light comes on. Press and release the A key. Enter 0 ro run stream one enter 1 for stream 2 and 2 for stream 3
Mar 05, 2008 | Motorola Televison & Video
Durabrand dvd code
hi go here for the complete usermanual, and try this following.
Searching (Power is
recommended):
• Power
• Mute
• Play
• CH +
• Stop
3. Press !. The remote will send
3. Press " to retry the previous code
I hope this helps
Please rate accordingly
Thank You
sserpentio
Dec 25, 2007 | Motorola Mobility DRC800 Universal Remote...
Televison & Video Logo
418 people viewed this question
Top Motorola Televison & Video Experts
Jaime Hernandez
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Motorola Televison and Video Expert? Answer questions, earn points and help others
