Remove therostat lr1620 - Heating & Cooling
  • 828 Answers
Not enough information on water you want.
Posted on May 03, 2008
Lr1620 thermostat YORK
Yes, if you have the manual that comes with it just follow the wiring guide. If you don't have it the download the manual and follow the wiring and mounting guide.
Apr 13, 2014 | Heating & Cooling
Honeywell lr1620
I do not believe that LR1620 is a model number, you may need to find another number. Try this link to see if maybe it's your thermostat or not. The stamp LR1620 is actually on multiple thermostats. Hope this helps!
http://customer.honeywell.com/techlit/pdf/69-0000s/69-0107.pdf
Read down the PDF file till you see the instructions on setting the heat anticipator.
Dec 01, 2013 | Honeywell Heating & Cooling
I have a Honeywell LR1620 Thermostat that I am replacing with a Honeywell RTH230B. I se where all the wires go to on the new thermostat EXCEPT the blue wire that is attached to the "W2" terminal...
If your old t-stat had a W2 terminal with a blue wire connected, and your new t-stat does not have a W2 terminal, then you may have purchased the wrong t-stat. The old is a 2 stage heat where your new is a 1 stage heat. 2 stage heat means the tstat will engage 2 heat elements, then if it continues to get cool inside, the Tatar will engage w2 and the remaining 1 or 2 heat elements. If you want it like it was to begin with, you'll need a 2 stage heat 1 stage cool tstat.
Oct 10, 2017 | Heating & Cooling
How do i change the thermostat in my 96 blazer?
take bracket off throd body then take therostat housen off to change therostat then put back together fill with coolent run with cap off it water goes down then fill on up put cap on drive and watch gage make shur it dont run hot
Jan 31, 2011 | 1996 Chevrolet Blazer
Need coleman thermostat schematic: LR1620 ;T874R1368 Base Q674L
http://www.iaqwholesale.com/manuals/IAQmanuals/Honeywell/Thermostats/NonProgrammable/ManualNonProgrammable/T874/60-2485.pdf
Dec 02, 2010 | Coleman Heating & Cooling
Where is the engine therostat located, 1993 1.8 ltr,
to find the thermostat,just follow the upper radiator hose till it ends,which is next to the battery.the thermostat is located right under the metal part that the upper radiator hose is connected to.it has 3 10mm screws holding it in place.just remove these 3 screws and pull it off and bingo,there is your thermostat.i'm sorry but i can't help you with the location of the ecu.hope at least the information i gave you helps.good luck and take care, manny
Jul 02, 2010 | 1993 Toyota Corolla
Therostat
You want to????
Jul 13, 2009 | 1998 Jeep Cherokee
We changed the therostat and it still kicks the reset button?
Sound like the heating elements are shorting out. Need to replace them after draininbg the tank. First shut off the breaker. Be safe and good luck
Apr 23, 2009 | Water Heaters
Heating & Cooling Logo
236 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
