I need a replacement remote for my LCD 2226E tv. My remote simply quit working, changed the batteries and will not respond to any key's Larry
  • 43 Answers
SOURCE: LCD TV Remote quit working
First thing, turn off the TV and unplug it for about 2-3 minutes. Remove also the batteries on your remote. Re-install the batteries on the remote and plug in your TV. Power on your TV using the remote. No luck?
Norcent may not be supported by a universal remote. If you just bought your unit new (maybe Best Buy who carries this brand) you are still covered by its warranty. Below are ways you can reach Norcent.
http://www.norcent.net/main/contact.asp
909) 305-2121
support@norcent.net
Posted on Mar 24, 2008
Erik Seattle
SOURCE: My Sharp Aquos TV has stopped responding to remote control(s)
Unplugging my TV for 15 seconds (longer actually - at least a minute) made the remote and the satellite TV remote both work again with the TV.  Thanks for the tip!
Posted on Apr 28, 2009
SOURCE: Need code for remote. New remote needs replacing.
Cable and Satellite content providers control the remote codes,
and we apologize for any confusion during the remote programming.
Please try the following codes 10019, 0178, 10178, 0030, 10030,
0835, 10835, or for Dish Network try 627, 659 or 505. For Fios
TV (Verizon), try the code 3264. These codes may not work on some
universal remotes. If there is another code listed for Element
Electronics in your universal remote control guide, please try that
code. Refer to the Remote Control Guide under your TV’s model
number for more information.
Posted on Apr 06, 2010
  • 94 Answers
SOURCE: remote quit working so I
defective IR sensor or main board
Posted on May 28, 2010
budmrtn
  • 11361 Answers
SOURCE: TV doesn't respond to the remote control...can't change channels
You have to find out if the remote is sending out the infrared signal to the TV remote receiver or not, you can test that by pointing the remote at the digital camera, you should see flashing light on the camera screen when any one of the remote button is pushed (digital camera can detect infrared light). If get the flashing light then the problem is in the TV remote sensor.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jun 15, 2010
My remote does not work
Remote Code for LCD Coby TV model TFTV2425 - Comcast Help and ...
forums.xfinity.com/t5/XfinityTV.../Remote...LCD-Coby-TV.../916553
Apr 14, 2011 - Remote Code for LCD Coby TV model TFTV2425 ... If your home entertainment device does not respond to the remote control after trying all of the codes listed for your ... I just changed to an hd box andcodes given by comcast did not work. Looked at my old remote notes and that is what I found and it works. Comcast DVR remote won't "select" an input from th...
May 26, 2011
Remote code for coby tvs
Feb 7, 2011
Comcast remote code for Coby tv/dvd
Mar 20, 2010
More results from forums.xfinity.com
Coby tv remote doesn t work Questions & Answers - Fixya
www.fixya.com > Forum > Tags > tv remote doesn t work
Dec 15, 2015 | Coby TFDVD2274 22 in. LCD TV
TV stopped responding to remote control
Unplug Tv from power source, wait 10 minutes and replug
Oct 12, 2008 | Toshiba 42HL67 42 in. LCD Television
The TV stopped responding to the remote control
tried with reset doesn't work, ok it could be the IR sensor at the front panel of the tv doesn't work. but before you replace it you need to ensure if your remote controller is working. have you tried to check the remote with camera trick just to know if the remote controller is sending light to the IR sensor of the tv.
Sep 23, 2012 | Advent LC-20H15A 20 in. EDTV-Ready LCD TV
My sansung remote quite working, replacement universal remote was programed to the tv but the tv will still not respond. What's next?
You likely don't need a new remote. Certainly not a Universal.
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
Try this:
First, fresh batteries, and clean battery contacts if needed.
Then, Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Please rate if Helpful.
Good Luck !!
Jun 18, 2011 | Samsung TV Remote Control
Will not respond to remote
is the remote your using is the original one....well try to check the battery and it's terminal sometimes it needed to be clean...check the infra red LED of the remote using a cellphone camera...focus the lens on the LED of the remote..press once any key if the light responds once its good but if you see blinking of lights your infra red LED needs to be replaced....but if your remote is good but still no respond on your tv..the tv problem may be from the remote receiver...try for a technical assistance for repair..nice day..
Feb 13, 2011 | Sharp LC-C4655U 46 in. LCD TV
I've gone through 3 remotes on my Vizio XVT553SV 55 in. LCD TV. The first one that came with the TV in the box quit working so I called and ordered a replacement. During the meantime, I went and bought a...
Ur universal remote have codes problems,low in batteries or replacement batteries have problems with codes.Re enter the codes again,for ur tv model.
Dec 09, 2010 | Vizio XVT553SV 55 in. LCD TV
Remote sensor quit working
The sensors do tend to go out on these tv's. You can call an electronics repair man to have them come to you.
It requires soldering the old and new sensor board for replacement.
Jun 06, 2009 | LG 42LC2D 42 in. LCD HDTV
42-inch Protron LCD TV Remote Doesn't Work nor Does a Universal Remote Replacement
Your problem is not with the remote but rather the circuitry designed to respond to the signals transmitted by the remote(s)
Find out what board has the circuitry that responds to the remote signals and replace that board. Got a better idea?.
If very expensive then you have 2 choices - deal with a remote less set or get a new one.
Mar 22, 2017 | Protron PLTV-32 Television
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
