Question about Lenovo IdeaPad Y510 Notebook
In My Laptop Lenovo Y510 Some Disc(DVD/CD) Are Detected and some not .With The Detected Disc I Can Do Everything Playing,Burning Etc But The Disc Which Are Not Detected (Means:When I Inset Those Discs ,Then Also The Computer Says "Insert A Disc") .I Had Tried All Possible Things Related to Software Like Deleteing Upper And Lower Filters,Uninstalling/Installing Of IDE Ports and DVD Drive . ETC Help!!!!!!!!!!!!!!!!!
    Sergeant:
    Champion:
  • 305 Answers
Sometimes the discs are corrupted. but usually if you wash the discs in warm soapy water going from the hole to the outer edge .(never around the disc) then dry with soft cloth they will work.
hope this helps.
Posted on Aug 21, 2010
Describe how you insert a dvd into a laptop
Hi Eunice, just want to clarify, for lenovo notebook if it doesn't have DVD drive you can use external DVD drive to access DVD CD. DVD external drive is just plug and play device once attached in your USB port, it will automatically detected and once detected you can use it already. Just install Burner application to burn some files if your DVD is capable of burning CD.
Jun 22, 2011 | Lenovo 3000 Y410 (59012354) PC Notebook
Hi.. My lenovo Y510 laptop mouse pad is locked, so kindly suggest to unlock the mouse pad. Thanks n Regards Ratnadeep Nath 09322136821
First of all check if the hardware is detected. Look in the Device Manager under "Mice or Other Pointing Devices". If it's not detected means there's a problem with your TouchPad.
Normally you won't need drivers for the touchpad. It should be detected as PS/2 Compatible device.
Apr 14, 2011 | Lenovo IdeaPad Y510 Notebook
I have lenovo Y510 with vista home basic installed. After some problem all veriface,power2go,shuttle centre and Easycapture did not worked. Then i installed vista from recovery cd. Now everything is...
download driver then download eyeline surveillance when it says add camera easycam pops up it works pass it on u have juss been school holla back
Aug 22, 2010 | Lenovo IdeaPad Y510 Notebook
Hello...i use a lenovo laptop and when i tried to burn a cd it says error while burning cd...this cd might not be usable
try this tip, nimmiti_lava
click start > run > type regedit
click HKEY_LOCAL_MACHINE , then click SYSTEM
then click CURRENTCONTROLSET, then click CONTROL
then click CLASS, then click the folder 4D36E965
delete the LowerFilters & UpperFilters on the right side of the registry
then restart the pc
Hope this helps...
Apr 12, 2010 | Lenovo IdeaPad Y510 Core-2 Duo: Y510...
I would like to replace my DVD drive for my lenovo Y410 laptop.
here is a ebay link.
http://cgi.ebay.com/Lenovo-3000-Y410-Y510-Y520-CD-RW-DVD-RW-Optical-Drive_W0QQitemZ400083848504QQcmdZViewItemQQptZPCC_Drives_Storage_Internal?hash=item5d26db0d38
Good luck and Happy Computing
Oct 23, 2009 | Lenovo 3000 Y410 Laptop
NOT ABLE TO BURN THE C.D & D.V.D
Y510 uses the slot loading DVD, right? It's not software problem... that Matsushita DVD drive on Y510 and Y410 are faulty... they work only for a few months then always have trouble burning. I've seen many complaints on Lenovo support forum... I'm having the same problem with my Y410 too... I had to use USB to install Windows 7.
Oct 22, 2009 | Lenovo IdeaPad Y510 Notebook
When i open my lenovo y510 in my computer there is no E:DRIVE/CD DRIVE
Were you the one installing your OS and programs? You CD drive might be located in another drive. It's not necessarily drive E.
May 27, 2009 | Lenovo IdeaPad Y510 Notebook
Lenovo y510 Dvd drive is not displaying
... and no drivers came with the drive either? Do you have the restore CD/DVD provided by Lenovo? I'm guessing this was a pre-installed OS and all files came on the HDD. When you installed Windows 7, you lost the path to the std Lenovo drivers... or wiped/formatted the HDD and lost everything? Can you pull the DVD drive out of the bay and see who makes it? Lenovo does NOT make DVD ;-) I'll bet it is a std Yeasu, Phillips or Samsung/Sony and with the model# and your OS info you will be able to get generic drivers for it
Good Luck
...As an example, my Top of Line HP has Sanyo drive ;-)
Jan 15, 2009 | Lenovo ThinkPad T61 Notebook
Unable to burn cd's
First of all you try to burn the cd with a valid cd burner, uninstall the already existing cd writer and try to install again.
In case of laptop you can try the company's own cd burner.
Else... The main problem occurs when the seating of the driver is not proper.
You can remove the driver yourself if you are comfortable with or else you have to give to the authorised service center to remove and reseat the driver again....
Aug 29, 2008 | Lenovo 3000 C200 Notebook
Lenovo IdeaPad Y510 Notebook Logo
85 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
