Question about LG WM-2277HW Front Load Washer
LG Tromm Washing Machine Won't Drain code comes up OE
  • LG Master
  • 43,501 Answers
Here is a tip that I wrote about the LG OE Code and the causes and fixes...
Here also is the complete list of LG Codes
heatman101
Posted on Nov 16, 2010
2 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: My LG Tromm front load washing machine gives me an
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Posted on Jul 30, 2009
I have a problem with my LG Tromm front load washer. It will wash seemingly normally up to the point it gets to the spin cycle. Then a motor comes on and the machine does not spin or drain. The display...
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!
Sep 10, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
An OE light comes on and the washer won't drain
I had something similar. It turned out that one of the option keys was stuck in an "in" position (did not jump back out after it was pressed) which disabled the functions of all the other keys. The lights in main dial came on but it was not possible to do anything else.
Jul 22, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washer machine erroe code oe
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly.A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
Clean and straighten the drain hose / clean the drain filter.
Jun 30, 2010 | LG WM2688HWM TROMM SteamWasher
Lg tromm wm2277hw rinse spin error OE
An OE error presents if the washing machine has not successfully drained the water in ten minutes. However, the OE error code does not always mean that the washer requires a service call. If periodic maintenance has not been performed on the washer, there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a LEVEL on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
Oct 26, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My washer isn't drying anything very well. getting a oe message lg tromm wm2277hm
the OE message means that the machine has not fully drained out all the water. you can try to re set on drain or you may need a service call. hope this helps.
Oct 15, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have an LG TROMM wm1812cw washer. Out of the blue the machine will not spin or drain. It has given an an error code OE
Sep 27, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My LG Clothes Washer has stopped mid cycle and is displaying an "OE" error code. How do I get the machine to finish the cycle?
oe means drain error (outlet error)
Poss causes:
drain hose kinked,
filter blocked,
pump impellor blocked.
Hope that Helped
Please Rate Me
George
Apr 29, 2009 | LG WM2688HWM TROMM SteamWasher
Tromm washing machine, front load from LG
Peace,
ngafm at your service!
Lets try this first!
Did you try to open the door when the breaker was off or only when you turned it back on??
How old is the washer?
I'm here all night if you want to write me back!
Bless You,
Please leave me a good rating in this site before you sign off!
Sep 03, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WM-2277HW Front Load Washer Logo
2,035 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
