Question about Maytag Cooktops
My ignitor on my maytag CSG7000CAB won't start. Repairman said it was module . This has happened before and all I did was wiggle the little sparker and it started clicking. I need installation info on replacing module. Thanks
  • Maytag Master
  • 12,061 Answers
Http://www.ehow.com/way_5201258_maytag-stove-troubleshooting.html
Above is how to diagnose what it is.. Below is the place for parts.
http://www.ehow.com/how_5888159_replace-spark-module-stove.html
Below is your service and repair manual, it will show you in the manual exactly what to do, and the part number too, which you may get from the other site I gave you.
http://www.servicematters.com/maytag_library/docs/16010161.pdf
Posted on Aug 21, 2010
How do I convert my maytag CSG7000CAB gas cooktop
i NEED TO DO THE SAME TO MY MAYTAG COOKTOP DID YOU FIND THE ANSWER YET?
Mar 08, 2010 | Maytag MGC5536 Gas Cooktop
GE profile gas cooktop - sparker firing with knobs turned off?
replace your spark module
have you spilled liquid on the cooktop recently?
if yes let it dry for a couple of days and see what happens.
sometimes when you spill liquid on the cooktop it grounds out the spark module and it will continue to spark until it drys.
let me know if you need more help
Feb 15, 2010 | Cooktops
GE gas stovetop burner doesn't light
there are sparker modules on each burner behind the button, it may be that yours is failed, if you turn on other knob and you see spark at problem burner and still isn't lighting you have to make sure the black or grey tops are paced on perfectly, just give them a little nudge and you have to make sure area is perfectly clean for spark to take effect, spark will go for cleanest area on metal. so ensure area is clean and check burner top
Feb 05, 2010 | GE 30 in. Profile JGP979 Gas Cooktop
Suddenly I hear a constant 'clicking' sound from the Maytag csg7000 cook top which I am not using right now. It's like it's trying to ignite by itself. What could be a problem?
usually this is a problem with one or more of your ignitor switches, they are found below the selector switches, below the top, if you take off the selectors you might even be able to see them,
these are what sends voltage to you ignitor, from the spark module, one one goes bad, they all tend to spark, because light one light all....
http://www.appliancepartspros.com/part_details.aspx?part_id=4101545
this link wil take you right to the part i suggest,
as well as be able to order it
since this happens alot after a boil over i would start with one of the front two burners,,,, you can order one and keep replacing them with the next till the clicking stops
Nov 04, 2009 | Maytag 30 in. CSG7000 Gas Cooktop
Igniters on my Maytag gas cooktop do not spark
u nid the serviceman to replace the ignition coil,coz its hard to replace & expensive the parts,temporary use macth
Jun 27, 2009 | Maytag MGC5536 Gas Cooktop
My Sears cooktop electronic ignitors burners click periodically.
the spark module is grouning itself out. moisture will do this to it.
Jun 10, 2009 | Maytag 30" Built-In Gas Cooktop - White
Ignitor keeps sparking
Be sure to unplug the stove from the electrical power prior to testing.
Sparkers do go bad, so it could also be a defective one. Each sparker has a wire that pulls off the sparker element body. You can disconnect one at a time and test to see if the sparking stops.
If the sparking continues, then reconnect that one and disconnect another. Continuing with each sparker one at a time until you locate the one that may be causing the problem. The one that stops the sparking is the culprit.
If all the sparkers are sparking, the most likely cause is a defective capacitor in the spark modual. Spark moduals are not repairable. The entire part must be replaced. Replacements are available at the local appliance retail parts store listed in the phone book.
Another possibility is moisture during the cleaning process found it's way onto one or more of the switches. Excessively wet sponges or cleaning cloths allow water to get onto the switches, which will cause this problem, if applicable.
If this happens to be the case, then remove everything on the stove top and lift the lid, if applicable, since not all stoves have liftable top lids.
Remove any clear plastic covers on the valve stems, if applicable. Blow warm air over the switches using a common hair blow dryer. The idea here is to dry out the moisture, if there is any. Don't laugh....this hair dryer trick often works!...biggrin.gif
Another cause could be reversed electrical polarity. The plug end will have 3 prongs. It must be directly connected into a properly wired and grounded wall recepticle. Reversed electrical polarity over a long duration of time will destroy the spark module.
Do not use 2 prong extension cords to lenghten the existing appliances electrical wire. DO NOT bypass the grounding pin on the end of the appliances electrical cord. Doing either of these will also damage the spark module.
If you attempt to do any repairs, be sure the electrical power is turned off or the stove is unplugged. If you choose not to do the repairs yourself, contact the dealer's local service agency. Until then...unplug the appliance and light the burners with a match.
TIP:
The only positive proof any part like a spark modual is functioning correctly, is to carefully remove the part or parts you suspect to be the potential culprit, and have the local appliance parts store person run the required tests and or help make the final determination which part or parts are defective.
Retail parts dealers can also help determine what the possible problem may be. Bring the make, model and serial numbers. Appliance parts dealers carry replacement parts for all appliances and are listed in the phone book under appliances. Appliance parts dealers test and stock replacement parts for all appliances.
If you need further assistance, use the reply button to add any additional information or ask additional questions. Doing so will automatically move your question to the top of the forum list.
Regards & Good Luck. Sharp Advice. TCB4U2B2B Business Management Serivces. Web Site Host, Forums Monitor, Gas Appliances Topic Moderator & Multiple Forums Moderator. Energy Conservation Consultant & Natural Gas Appliance Diagnostics Technician.
Feb 20, 2008 | GE Profile JGP636 Gas Cooktop
Thermador 30" gas cooktop SGCS304RB
Do you hear gas? If so, take a needle and put it through each one of the small holes where the gas comes out.... Also look for a little "white-dust" where the sparker makes the spark. (located probaly at back of burner). If there is a white dust build-up scrape it off with something (needle) and give her another go...
Jan 21, 2008 | Thermador SGS36GS Gas Cooktop
Cooktops Logo
404 people viewed this question
Top Maytag Cooktops Experts
Harry Miller
Level 1 Expert
Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
