Question about White Sewing 1866 Mechanical Sewing Machine
My bobbin thread keeps balling up in a big rat knot. How do I get it to straighten out?
  • 399 Answers
SOURCE: I have a Brother SE-270D
its the problem of the timing belt in your machine its extra loosen or extra tightned or is slightly came out of its position or finally broken.
as the machine is proper just missing the proper speed as it should be .
it is running continuosly as you stated.
check the timing belt and make it proper if its worn out and needs replacement this is how its done
There is an adjusting screw on the right side of the machine head. Follow the motor bracket to the machine head and loosen that big old screw or bolt which will raise or lower the motor giving you slack to remove or replace the belt.
feel free for further queries
thanks
Posted on Sep 19, 2008
kent581
  • 87 Answers
SOURCE: Upper thread knots up with bobbin thread when sewing a stich
Thread test
Test your thread quality to start, thread your machine and LIFT the presser foot (this opens the tension disks). Pull your top thread straight back. If you feel no tension no mater how much thread you pull, your thread is good. If that your machine passes that test, then let me know, we can go to step 2. If not, try different spool of thread, same test until you get a smooth pull (tip: always check your thread this way when you thread your machine)
Step 2:
Pull on your threaded bobbin thread while it’s in the machine. Does it pull smooth and even? If so, go to step 3. If not, try a new bobbin (bobbins get bent or distorted if wound too tight).
Clean thoroughly in the hook and bobbin case area and oil 1-2 drop is all.
Thread knotting on the bobbin can be a lot of things but here's some guidance:
Tension:
If the thread is loose on the bottom of the fabric, it's actually the top thread is too loose. Think of 2 little elves playing tug of war in your machine, one on toip and one underneath. If you have loops on bottom, the top needs to pull harder (tighten top tension)
Jamming bobbin case:
If it is damaged from turning out of place once, it could have rough spots on it that makes the thread hang on it, and keeps making it turn over and over. Use a finger nail board (fine sanding) and smoothall rough spots. Then reset the bobbin case taking care to put the notch in the bobbin case in alignment with the proper spot in the machine (basically 5 o’clock) when looking at the round area where the bobbin case goes.
Posted on Mar 18, 2009
SOURCE: thread knotting around bobbin case
hello, I had the exact same problem and could not find the solution until i took my machine to my sewing sensei and i solved my tedious problem. It was actually not a tension problem at all but a threading problem. Make sure you have threaded your bobbin correctly and that when you pull on the bobbin thread that the bobbin turns the right way. (mine must spin anti clockwise to work)  Make sure that when you pull up the bobbin thread using the needle that it is not over the feed dogs connective bar but under it. A big problem when the thread gets caught around the bobbin case wheel is that the thread is looped around the feed dogs once and that causes the thread to get caught around the bobbin wheel. In conclusion, thread the bobbin correctly and read over your instruction book before spending the money to get it fixe in s shop.
Posted on Mar 31, 2009
  • 201 Answers
SOURCE: needles keep breaking & bobbing wont feed thru
First try taking your bobbin case right out of the machine (not sure if this model has a top loading or front loading bobbin, but your manual will help you here) and floss out the tension slot with a piece of strong thread. Don't use waxed dental floss, but non-waxed would work okay. (The bobbin case is the piece that the bobbin sits in.) Look around while you have the machine open and remove any fluff and thread you can see - TURN MACHINE OFF BEFORE DOING THIS! Replace bobbin case. Replace bobbin and make sure it "clicks" into the tension slot.
Then unthread the top of the machine, clean the tension disks by passing a folded dollar bill (or any paper money, depends on what country you are in) through the disks in the direction you thread the machine. Do this several times. Re-thread making sure you follow the correct thread path.
Make sure the needle plate is on firmly.
If after all that it still won't work, I'm sorry to say that it sounds like you have a misaligned needle bar. This commonly happens after you have a major thread snaffoo and needle breakage. The needle gets caught in the thread knot, pulls to the side and breaks but if it gets seriously caught it can pull the needle bar out of place. You cannot put the needle bar back in place yourself - it's a job for the workshop. Don't sew on your machine until it is fixed. The noise you are hearing is likely to be the needle striking against the needle plate or even the bobbin. Your timing will probably need re-setting too and this needs to be done by a qualified technician.
If you really need to sew before you can get your machine into the workshop, and if you can move the needle position on your machine by pressing a "sideways" button of some sort, you could try to get the needle in the centre yourself using this feature. This will not help if it is the timing that is the major problem.
Pam M.
Posted on May 03, 2009
SOURCE: thread clogs up bobbin and knots up thread on back side of fabric
I hope this helps: I bought a machine, and had the same problem... I read reviews, found that soOo many people were having this same problem. I thought it was a defect or something with the brand of machine so I exchanged it for another... well, the instruction aren't always clear. Not until I watched a DVD that came with my new machine did I realize I wasn't running the thread through the bobbin correctly. I had been just running it through the hole in the bobbin case... not right. Don't just thread it through the hole from the inside. When you place the bobbin in the case, pull out some of the thread and run it from the side between the little **** / split in the metal and you have to pull it down to the left and UNDER the metal strip held by the tension screw (the little sliver of metal). So, the thread is actually being pressed between two pieces of metal. I felt like a "dingbat" when I realized why I couldn't work it. This is kind of hard to explain, but I hope this helps...
Posted on Jun 01, 2009
How to remove the bobbin case
Go back to the manual and make sure you are following instructions for removal first. (Here is a link if you don't have the manual
http://www.singerco.com/accessories/instruction-manuals ). Second, it could be that there is a ball of knotted thread from the bobbin holding it all down. If that is the case, trim any loose threads away and keep the upper thread out of the bobbin. If the machine has seized up, though, you will probably have to take it to a professional.
Dec 14, 2013 | Singer 2662
Can't set the tension on needle or bobbin to match
1. make sure your machine is threaded right.2. set the tension between 3 and 4 and play with the tension as you need it to adjust it.3. make sure the bobbin is threaded right.make sure to visit the site below; it has solutions to multiple problems and instructions how to thread the needle or bobbin. Good luck.htt://Fix Looping/Knotting Thread Fix Knotting/Bunching Thread Looping Bunching & Knotting Thread
Aug 03, 2011 | Euro-Pro 1260DX Mechanical Sewing Machine
Bobbin thread keeps knotting
1. Do you mean that there are knots in the bobbin thread?
2. Is the bottom thread in your stitching looping and knotting.
If yes to 1. you need to rewind your bobbin fresh, and keep slight tension on the thread reel that you are winding it from. Put the handle of your scissors into the top of the reel to apply a gentle pressure while winding. Keep your eye on the bobbin as it winds and give it a nudge with a finger tip to ensure it winds the bobbin evenly top, middle and bottom.
If yes to 2, then you need to check your bobbin threading, is the thread even under tension. Is the bobbin tension set correctly. Break out your manual and revisit this to ensure it is set correctly.
Feb 27, 2011 | Brother XL-5340 Mechanical Sewing Machine
Thread knotting
Ensure you have cotton thread on the bobbin and that the bobbin is placed with the thread counterclockwise. It may also be the needle.
Apr 06, 2010 | Euro-Pro Dressmaker 998B
Singer 301a sewing machine does not sew for more than 2 secs...top thread just knots into a huge ball on bottom of fabric...everything is threaded correctly and all tension set well...next step is trash...
Recheck the top thread and bobbin tension for equal balance of thread when sewing. The knotting of thread problem is usually because the tensions are too tight or too loose and/or thread may not be properly threaded. Another reason is when the bobbin thread is wind imbalanced it will cause the thread to knot-up when sewing. This problem is notorious when the bobbin is winded within the bobbin case on some machines. The bobbin thread need to be wind smoothly in the bobbin to avoid this problem.
Jan 24, 2010 | Singer Sewing Machines
Thread keeps knotting up in bobbing casing
Make sure the bobbin is wand correctly. It also need tension. you have a bobbin case be sure it inserted correctly.
Aug 08, 2009 | Sewing Machines
Cotton keeps getting knotted from the bobbin
upper tension is wrong or upper threading is wrong (problem is always on the other side of the bunched thread)
Jul 07, 2009 | Janome Sewing Machines
The thread keeps knotting up near the bobbin on my older model singer
Sounds like a tension problem. You may can email the singer company at talktous@singerco.com
Jun 24, 2009 | Singer Sewing Machines
Kenmore model 385. 12912890
Make sure your machine is set to feed material. There may be a switch or knob somewhere on your machine to lower the "feed dogs" (the little metal teeth that pull the material through the machine). If they are down, the material won't feed so the machine will sew in place. More likely, since its knotting on the bottom, your machine is probably not threaded correctly. Rethread the machine, and try again.
Yes, the thread on the bottom IS the needle thread.
Nov 25, 2007 | Sewing Machines
White Sewing 1866 Mechanical Sewing Machine Logo
376 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
