Question about Konica Minolta bizhub C250 All-In-One Laser Printer
BizHubC253 error code c3821
Does anybody know what the error code c3821 means?
Or if not, does anyone know if the numbers are sequential for a reason? I see a few problems with codes 3851, I wonder if they're similar?
Thanks for your help.
This error also occurs after a paper jam or a steep power change. If error continues after doors were properly closed and the printer was turned off and on again, it'd be necessary to reset the printer and release it from trouble status.
Turn off the main switch (1/0 botton) but keep the control panel on. Wait 10 seconds. Press and hold Utility Counter botton on the Control Panel while turning on the main switch. Hold it until a white screen with a black dot over the upper rigth corner appears, then release it. Wait for a "trouble reset" botton on the control panel and then manually click on it. You'll see an arrow pointing to an "OK". Now turn off again the main switch, wait 10 seconds, and turn it on. Error must be gone.
Posted on Aug 12, 2008
  • sidindi May 06, 2013
    Thanks alot Oicorcetroc. This solution helped me solve my bizhub c203 error code c3821. It works perfectly.
  • Nelly Martinez
    Nelly Martinez May 30, 2017
    How do you keep the control panel on when turning off main power, please? Very confused! Thanks so much in advance.
    Champion:
  • 214 Answers
C3821: Fusing abnormally low temperature detection (heating side)
cant find the other code.
check that fu is installed correctly, check that right door closes fine.
Check the fusing unit, PRCB and DCPU for
proper connection and correct or change
as necessary.
Posted on May 11, 2008
How do I fix a hot point fridge freezer FFUXL 4DK displaying error code 7?
Hotpoint Refrigerator Error Code E7 = Environmental temperature sensor fault
There may be a number of things affecting the temperature in your refrigerator if you see this error code displayed
Jul 22, 2016 | Refrigerators
I HAVE A EURODESIGN DRYER BOUGHT IN '03 I now have error 68 message and dryer stops - anybody know what this means - cant find it in the manual. thanks
It means it has a stuck button.
I'm taking it that it's a Fridgidaire.
on the door you should have a model number that looks like this
AEQ6700FS .
http://www.searspartsdirect.com/dryer-repair/error-codes/frigidaire-dryer-error-codes.html
Once you find this and you need a manual goto
Browse Products
Apr 17, 2015 | Dryers
Treadmill error code 4
You will need to give more detail, like make and model numbers? without that information there is really little help anyone can give except contacting the manufacturers website for the manual to download.
Mar 01, 2014 | Exercise & Fitness
My panasonic dmrex75 has an error U81 on it. Does anyone know what this means?
This is one of several error codes generated by the main microprocessor IC which are tripped by corruption, preventing proper operation and which may require the processor to be reset or replaced.
The U81 and U80 codes don't mean anything really because the corruption error could be caused by any one of a number of different reasons. It does not point to any specific one fault. This is where the confusion sets in as to the origin of the 'error code' in any device.
Nevertheless, U81 means (in technical terminology) 'microprocessor communication malfunction' on the universal asynchronous receiver/transmitter' or 'microprocessor feedback information error'.
Either way, this is not something an end-user should undertake to repair themselves; it should really go to an authorised service centre. The cost depends on the parts used and the labour, however, it is not unfixable.
Mar 03, 2011 | Televison & Video
Does anyone know what code 0146 means?
This error code is related with the hard drive problem. There is a possibility of hard drive failure.
Mar 12, 2010 | Dell Inspiron 13 Notebook
Error Code 4 on Saeco Talea Ring
I need to know what error code 4 means as well.
Has anyone helped you yet?
Apr 05, 2009 | Saeco Talea Ring Plus Espresso Maker with...
HI My Kyocera FS-6020 comes up with the call service number 4200:0019564 number! does anyone know what this means thanks
This error code means that the Laser unit in the machine has failed and will need to be replaced.
Mar 24, 2009 | Kyocera FS-2000D Laser Printer
!SisRegistryServer error
The error message you got suggests an internal software corruption. I suggest that you update your P990 firmware if it isn't already on the latest firmware and then perform a master reset. This should solve your problem. Don't forget to back up all important data. Good luck!
Dec 10, 2007 | Cell Phones
We have 2 problems :
1-Application
!SisRegistryServer
Reason Code
ucmp
Reason number
0
2-Application
Application installer
Reason Code
KERN-EXEC
Reason number
Nov 13, 2007 | Sony Ericsson P990i Cellular Phone
Flash no more working: error code
You must have an E:61 or E:91 error. You will need to send it back to Sony but, that is what warranties are all about. I am sure it will be fixed quickly and for free!!
Sep 11, 2005 | Sony Cyber-Shot DSC-F505 Digital Camera
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
10,511 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
