Question about Sony Cyber-shot DSC-T90 Digital Camera
After formatting the memory card i inserted it onto my t90 camera but its displaying-creating image management file.....
    Genius:
  • 1,234 Answers
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
Posted on Aug 27, 2010
Hi how do i formatt my camera card
From page 63 in the manual.
Format
Internal memory format : Remove the SD memory card to format the internal memory.
SD memory card format : Insert the SD memory card to format the SD memory card.
All the files in the memory are deleted by the [FORMAT] function.
Before formatting the memory, it is advisable to copy important data onto other media as back-up
e.g. floppy disks, hard disks, CD etc.
1. Turn the camera power on.
2. Select the PLAY mode by rotating the mode dial.
3. Do not turn the LCD monitor off.
4. Press the MENU button to display the menu on the LCD
monitor.
5. Press the UP( )/ DOWN( ) button and select [DELETE].
6. Press the SET( ) button and the sub menu will display.
7. Select [FORMAT] by pressing the UP( )/DOWN( ) button
and press the SET( ) button
8. Select [NO] or [YES] and press the SET( ) button.
[Selecting NO] : The image will be displayed on the
LCD monitor.
[Selecting YES] : A [PLEASE WAIT!] message is
displayed and all of images are
deleted.
Link to manual:
http://www.samsung.com/uk/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=2702&prd_mdl_cd=EC-D201ZSBA/E1&prd_mdl_name=DIGIMAX%20201&srchword=digimax%20201
Jul 05, 2011 | Samsung Digimax 201 Digital Camera
The vids on my Sony DSC-T90 won't play and I can't record. The camera says' "file error"
The LCD screen may display a FILE ERROR message when trying to view a still image on the camera if the image was rotated, modified and overwritten using editing software on a computer. To play images you have taken on the camera, it is recommended that you do not make any changes to the original image files.
Not able to record or play :
This error may occur in any of the following circumstances:
-The Memory Stick® media is not inserted properly.
-The Memory Stick media is not supported for use with the camera.
-The Memory Stick media may be faulty.
Mar 13, 2011 | Cameras
Hi, my camera was working fine and then in between taking pictures all of a sudden it said "memory card error" and now I can't see some of the pictures I took. Please help!
If the camera displays Memory card error, No Memory Card, or takes an abnormally long time to write an image to the memory card, when a memory card is inserted or any of the above error messages, make sure that the card is inserted properly. For SD card, make sure that the card lock switch is in the correct position and not stuck in-between. If this is the case, you may wish to Format the memory card in the camera using the Setup Menu option [Format] as shown below. Please be aware that formatting the memory card will remove any images currently stored on the card along with any other data. This can also be caused when images shot with another camera are stored on the memory card.
If after formatting the card in the camera the error persists, try another memory card. If this occurs with only the one card it is likely that the memory card is defective, if the error persists over more than one card the camera may require service. If the card appears to be defective you may wish to contact the memory card manufacturer.
Mar 13, 2011 | Canon PowerShot SD1300 IS IXUS 105...
We have inserted sd-ms card onto our laptop to upload the photos onto FB.however the card when inserted back onto the camera, about 50 over images show, incompatible jpeg?how do we solve this issue?
The computer uses a small program to be able to upload pictures from the memory card once the pictures are safely on the computer hard drive hopefully you created a file folder for them then the memory card needs to be formatted in the camera. Formatting the memory card cleans the card and makes it compatible to the camera again. Every time you download images to the computer the memory needs formatting in the camera. Any new memory card needs formatting in the camera a card that has been formatted in the computer needs to be reformatted in the camera. Also please be aware that there is a protection lock on the side of the SD card and if placed in the incorrect orientation will actually lock the card from formatting or deleting files on the card. I'm going to include a diagram here to show you where this little switch need to be for the "unlock" position.
Switch needs to be towards the top of the card in the direction of the gold contacts
Jan 02, 2011 | Cameras
My samsung s630 says the memory is full. I cleared photos from the sd card and internal memory, but still can only take four pictures in the lowest quality and size setting.
Memory card might gone bad but can do this following troubleshooting step. Formatting a memory ** This is used for formatting the memory. If you run [Format] on the memory, all images, including the protected images, will be deleted. Be sure to download important images to your PC before formatting the memory. Sub menus
[No] : The memory will not be formatted. Press the menu button three times and the menu display will disappear.
[Yes] : A [Processing!] message appears and the memory will be formatted. If you run FORMAT in Play mode, a [No Image!] message will appear. 1d36119.png
Be sure to run [Format] on the following types of memory card.
- A new memory card, or an unformatted memory card
- A memory card that has a file this camera can't recognize or one that has been taken from another camera.
- Always format the memory card using this camera. If you insert a memory card that has been formatted using other cameras, memory card readers, or PCs, you will get a [Card Error!] message. ** There might be bad sectors on your memory card.
Apr 12, 2010 | Samsung S630 Digital Camera
Memory card is not working...
You should not use the memory card from other mobile to motorola. When you insert the memory card two folders will be created automatically (Sounds and images) You have to put the songs and images in the relevant folder, then only you can access. Otherwise it will display that you don't have files in the memory card.
Take a copy of all the songs and images to your pc.
Then follow these following steps
1. Format the memory card.
2. Insert the memory card to motorola
3. Transfer the files and folders to the folder(Automatically created folder)
4. Safely remove hardware
Now you can enjoy music.
Cheers...!
Mr.Maduraikaran.
Sep 26, 2009 | Motorola Mobility W230 Phone US with...
How do i transfer my phone memory to the micro sd
You can store any multimedia files
on your phone’s memory in My stuff
so that you have easy access to all
of your pictures, sounds, videos and
games. You can also save your files to a
memory card. The advantage of using
a memory card is that you can free up
space on your phone’s memory.
My images
My images
contains a list of pictures
including default images pre-loaded
onto your phone, images downloaded
by you and images taken on your
phone’s camera.
My images options menu
The options available to you in My
images
depend on what type of
image you have selected. All of the
options will be available for pictures
you have taken on the phone’s
camera, but only the Use as, Sort
by Grid (List) view
and Memory
manager
options are available for
default images.
Send - Send the image to a friend.
Use as - Set the image to appear on
your phone at certain times.
Move - Move an image from the
phone memory to a memory card or
vice versa.
Copy - Copy an image from the phone
memory to a memory card or vice
versa.
Delete - Delete an image.
Mark/Unmark - Select multiple files.
Print - Print an image via PictBridge or
Bluetooth®.
File - Change the name or view the
information for the file.
Create new folder - Create a new
folder within the Pictures folder.
Slide show - Start a slide show.
Sort by - Sort images into a specified
order.
Grid view/ List view - View each
image in grid or list type.
Memory manager - View the memory
status.
Jul 26, 2009 | LG Secret ? KF750 Cellular Phone
Memory card isnt recgognised!
If the card is inserted correctly and its not damaged, then the memory card should show up under media manager, you need to put the files onto the memory card not on the phone...
When you first insert the card into the phone, you need to format the card, some phones create specific folders for different things when they format, e,g images, Videos, etc. You may need to do this.
I cant remember if this phone had this option but try it anyway as if it works, it should be faster than using Samsung PC Studio...
Close Samsung PC Studio
Unplug USB out of the Phone and a couple of seconds later plug it back in, see if the phone asks you for Mass Storage mode... If it does select that, after a while the Memory Card should show up on your PC just like a USB memory stick you can drag and drop files to it and its faster than going through Samsung PC Studio :)
May 09, 2009 | Samsung C417 Cellular Phone
Canon power shot SD200
You can take out the memory card from camera and then download a memory card recovery software to recover photos from memory card, you can refer to this tutorial that helped me before
http://www.asoftech.com/articles/how-to-recover-lost-photos-from-memory-card.html
If needed, you may do a quick format of the memory card and then use asoftech data recovery to recover your files.
Dec 30, 2007 | Canon PowerShot SD200 / IXUS 30 Digital...
Sony Cyber-shot DSC-T90 Digital Camera Logo
43 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
