Question about Canon MP490 InkJet Printer
Can open the cover of my canon pixma mp490 but am not sure how to change the ink cartidges. they are all the way to the right out of reach- how do I center them? i think i know how to change them once they're in reach.... just pull out the old ones and pop in the new ones?
You have to make sure the printer is plugged in the power. After you not only have to open the photo copy top, but you have to lift up the copying part aswell, then they will be centered. The ink exchange is easy.
Posted on Feb 21, 2011
Canon mx330 how to change ink cartridges
Use the thumb drill to literally drill a hole into the side of the old cartridge. Make sure to chose a location that's closer to the top of the ink cartridge to avoid over spillage when you add the new ink. Once you have the hole just squeeze in some ink of corresponding color into the hole. Not a huge amount, but enough to get some use out of it before the next refill. I highly recommend covering the hole afterward with a sticker or something so that you don't dry out the cartride. Reinsert the cartridge into the printer and use. (: All set!
*Note: You may have to reset the count on the cartridge to avoid getting messages that the ink need to be changed. From here on in, use your eyes to determine if the cartridge needs a refill (:
Dec 07, 2014 | Apple Nano 69472169 4X130Ml Premium Refill...
How do I change the ink cartridge in my canon mp495 printer
Make sure that the printer is plugged in and turned on. Close the document cover (if it is open). Lift the scanner unit and hold it open with the support on the right. Wait until the ink cartridge carrier moves to the ink replacement area. Pinch the tabs on one of the ink cartridge covers (front and back) and lift the cover up. Then pull the cartridge up at an angle towards you. Put the new cartridge in at the same angle. Then close the cartidge cover (it should click). Repeat this for the other cartridge, if needed. Lift up the scanner unit and then lower it down to close the printer.
Wait for the printer to do the print head cleaning before sending more jobs to the printer. (It will resume jobs in progress automatically.)
If it takes more than 10 minutes to replace the cartridges, the cartridge carrier will return to the home position. Close the scanner unit and then lift it back up.
I hope this helps.
Mar 21, 2013 | Canon PIXMA MP495 InkJet Printer
How do I change my ink cartridge on my canon Pixma MP490?
Visit the link below and download the Manual
http://www.retrevo.com/support/Canon-MP490-Multifunction-Printers-manual/id/23498dj693/t/2/
Here you will find detailed instructions about changing ink cartridges.
Aug 01, 2011 | Computers & Internet
CANON PIXMA MP490 ERROR CODE IS 5200 AFTER INSTALLING NEW BLK INK..........
canon mp490 error 5200 solution...... turn off printer,then hold reset button(the red 1 circle with triangle in middle) for 5 sec then whilst holding reset button turn power on let go of reset button then push reset button twice whilst still having hold of power button then release power button then push reset button 4 times and then power button twice hope it works it did for me carlos:)
Jul 30, 2010 | Canon PIXMA MP490 Inkjet Photo All-In-One...
Renewing ink cartidge
Turn the printer on. Lift up the cover on your printer. You will here the cartridges moving, then they will stop, in your case, i guess in the center, but if not, just look and you will surely see them (they may be either in the center or on the left or right end of the printer). Then just put your hand on the cartridge and gently pull down. You will not break anything, promise :)
Apr 02, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Hi, i cant find where to change my ink cartidge for my canon pixma MP480 printer
just open the cover on top catridge will come to center and remove it.
just open the cover .when you open the cover cartridge will come to center just pull all the cartridges one by one don’t make pressure too hard it will come easily if you put more pressure and try to removing it and it is not come out then don’t do it may be you doing wrong . let it be and take help from some one who using printer and know how to fix the cartridges.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 22, 2010 | Canon Pixma MP480 All-In-One InkJet...
Changing the print head on the Canon Pixma iP90. Same for the iP80
It's not the same printhead but you change it the same way. open the cover and wait til the inks come to the center, hold the resume button for a few seconds and it moves to the right a bit so you can reach the handle to lift up and change the printhead.
Nov 25, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Computer wont reconize ink cartidge
Hi there
You can try this it some times works.
Super Canon User's method of resetting IP1600
1.Press Resume button hold for 1 - 2 minutes (count to 1 to 15-16)
2.Open the cover right away
3.Release Both cartridges out and then put cartridges them back again
4.Close The Cover
5.Turn Off Then Turn On again.
You can download the Resetter tools program from my website.
Click Link = http://www.4all2sell.com/reset-tools/ip1600st-RESETTER-TOOLS.zip
1. Download software for Canon iP1200, iP1600, 2200 Printers.
2. Unzip downloaded file by etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Free WinZip http://www.winzip.com/downwz.htm
Please call back to vote
All the best: Pineworks
Nov 02, 2009 | Canon PIXMA iP1600 Printer
I have put in new cyan ink cartridge but printer does not recog
are you sure you got the right ink cartidge put in? Also check if you took that piece of plastic that coverred your ink cartridge contact
Mar 20, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Changing ink cartridges
Hi.. Log on to the Canon website.. The printer manuals are in PDF Format at their site.
Thanks
jim
Feb 18, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon MP490 InkJet Printer Logo
161 people viewed this question
old marine
old marine
