Question about Philips 32PF5331 32 in. HD-Ready LCD Television
Hi, My philips 32pf5331 lcd tv sometimes does not turn on the backlight, it just gives sound out but there is no picture. After waiting a few minutes and trying again, it turns on the backlight and the tv opens. Is there a solution for this issue?
  • 138 Answers
SOURCE: i need help tv plasma phillips
When installing the software turn the set off plug in the USB and then turn the set back on. The software should install it's self. When finished just unplug the USB. If the issue is still there then yes replace the SSB.
Posted on Aug 20, 2008
  • 61 Answers
SOURCE: TV freezes at "Philips" screen
a professional. -These electronics go threw a self diagnostic when they start up, normally they turn off when they find a problem.
Posted on Jun 01, 2009
  • 92 Answers
SOURCE: 37" Philips LCD sound but no picture
Check the inverter on the sides of the TV. This sounds like the inverter is going bad and that's the reason why you have sound but not picture.
Posted on Jun 16, 2009
circuitworld
  • 335 Answers
SOURCE: 42'' lcd turns on no picture/menu
Your tv is being attacked by electrical surges which seem very violent and has already damaged some logic controls. Please invest in a AC filter which will protect your tv from such spikes....... but first you need to get your tv serviced from the electrical damaged it has already suffered.
Posted on Nov 03, 2009
  • 10 Answers
SOURCE: No picture on Philips LCD TV
One very common problem encountered on many Philips models, old and new, In some cases, the SSB board has to be replaced as the resistor on the PCB on the back of the CRT had to be fixed. In other cases the Y Sustain board had to be replaced. If the problem is not due to these two issues, then the capacitors will need to be replaced as they only have a fixed guaranteed life. Thus, it would be wise to take out an extended warranty on Philips due to this common repair issue which often occurs after the limited warranty has ended. Or you could just call your local repairman. There are lots of websites on how to fix it yourself on google. There could be many reasons. Hope this helps!
Posted on Apr 14, 2010
LCD TV backlight goes off but still sound is present. Sometime it happen within few minutes and sometime take 30 minutes plus. Is that inverter Problem or CCFL? how I can rectify?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Feb 12, 2016 | Philips Televison & Video
Philips 32PF5331/12 has negative picture... Please help me
Please provide more details about the problem you faces with this TV. Or, contact the nearest authorized service center for Philips, if you are not so experienced to do the work.
Aug 29, 2012 | Philips 32PF5331 32 in. HD-Ready LCD...
Sounds from tv when titles appear
U mean the tv have pictures flashes only a few sec. than dies have the tv pragram sound left only?Yes? Mean ur tv have a tv LCD Screen Panel have no tv LCD screen backlight to produce tv pictures tv now are having backlight problems.The tv have 1 or 2 long boards that are called LCD inverter boards problems and the causes.These 1 or 2 long Lcd inverter boards only job are to produced backlight for the tv LCD screen panel to hold on to give the tv screen panel to have pictures only.Tries websites like Shopjimmy.com,EBAY.COM to those refurbishes 1 or 2 long LCD inverter boards for the replacement.
Oct 03, 2011 | Philips Televison & Video
I have a philips flatscreen (32PF5331 / 12) that I bought it around 3 years ago. Everytime I turn on the TV, I only get the sound then I should turn the TV on and off (sometimes 5-10 times) before I...
Hello, not positive what part you need...but it sounds like maybe the main board needs replacing. I have purchased parts many times from a company named ShopJimmy.com. I included a link to the part from their site for your model. Hope that helps!
TeeVeeMan2@gmail.com
http://www.shopjimmy.com/catalogsearch/result/?q=32PF5331
Aug 25, 2011 | Philips Televison & Video
Picture keeps going out on Philips TV 47PFL3704D/F7, 2009 model. The sound stays on. It happens very randomly-may be fine for several hours, may happen every few minutes. Also happens when playing video...
I think that the connectors from the backlight inverter board that go to the LCD panel's backlight are a bit loose which explains why it comes back on when tapped. I am positive that unplugging and replugging the inverter cables should do the trick. WOuld like to do it yourself? It requires you to open up the tv ofcourse.
Jul 10, 2011 | Philips 47PFL3704D 47 in. LCD TV
Philip 42pfl7432d/37 has sound, but no picture, what is wrong?
Tv turn on now,pictures only flashes few sec. than dies have audio left only?Yes,than the tv 2 long LCD inverter boards are dead.These 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 long LCD inverter boards for the replacement.
May 11, 2011 | Philips 42PFL7432D 42 in. LCD Television
I have a philips lcd tv model 42PFL7332D/37. Suddenly, the picture lost, but the sounds works perfectly. Can anyone help me to solve this problem?
Tv turn on now,u just get a flashes of a picture only a few sec. than dies and have sound left only?Yes,than those 2 long boards that call the LCD inverter boards are dead.These 2 long LCD inverter boards job are to help the LCD picture screen panel to have a backlight to produced the picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 refurbishes long LCD inverter boards for the replacement.
Nov 29, 2010 | Philips 42PFL7432D 42 in. LCD Television
I have a Magnavox 30mf200v/17. When I turn it on the sound works but there is no picture.
Turn the tv on now,have pictures only flashes a few sec. than pictures dies,than have sound left only?Yes,than tv have those 1 or 2 long boards call the LCD inverter boards are dead.These 1 or 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 1 or 2 long LCD inverter boards for the replacement.
Oct 30, 2010 | Philips Televison & Video
Philips 50pf9631d/10 Audio ok but no picture
Bad power supply or backlight inverter.
If the backlight is not turning on, you should be able to see the lcd image by shining a bright flashlight at the screen.
Backlight inverters are loud, so you can hear them operating (high pitched whine) and if the backlight is coming on, you can see white light leaking around the edge of the screen, and even a little inside the cabinet.
Philips are legendary for having power supplies that fail due to bad capacitors, so that could be the culprit as well.
Oct 22, 2009 | Televison & Video
Philips 32PF5331 32 in. HD-Ready LCD Television Logo
251 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
