Question about Toshiba 32HLC56 32 in. HD-Ready LCD Television
I need a replacement hdmi port for my Toshiba 32hlc56 lcd tv. I cannot find any information on the board part number.
SOURCE: i have a toshiba 32hl67u lcd tv
I had same thing happen recently on same model. Turned it on one night, light came on in screen, briefly saw info bar at top, then nothing. Cannot get picture, volume or menu. Each time I turn off and turn on the same thing.
Any solution to this appreciated.
Posted on Jan 02, 2009
  • 1039 Answers
SOURCE: i threw out the original stand that came with our
Try Ebay, Toshiba dealer or contact Toshiba.
Posted on Nov 22, 2009
SOURCE: Tv with out coax inputs.
you can run it through a cable box or vcr that has a coax input and rca output.
Posted on Dec 17, 2010
SOURCE: instead of replacing the Seine
You can access the SD slot without having the back cover off of the TV. The SD slot is covered with a L-shaped bracket held on the TV with a single Phillips screw. The plate is located in the recessed part of the back panel to the right of the HDMI port. Good Luck
Posted on Dec 31, 2010
SOURCE: TOSHIBA 37E200U TV gets "NO VIDEO SIGNAL" error on
I am facing similar problem showing "no video signal" following failed attempt to connect Wii. Even after trying to reset, it won't come out again.. I am totally at loss? Toshiba Customer Desk has not been connected well and appreciate any advise.
Posted on Feb 14, 2011
Toshiba 55g310u - HDMI Ports are not working( No Signal)
Had the same issue for one of my Toshiba ports. Had to call for service. Apparently, the circuit board is fragile and after plugging in cables many times, the HDMI outlet separates from the board. Trust you have warranty coverage....
Sep 01, 2013 | Toshiba 55G310U LCD TV
HDMI PORTS DONT WORK
You will need to replace the main video logic board, its part number is either EBU60852909 or EBU60852911. These two board are direct replacement parts. There are several boards available on Ebay such as this one: http://www.ebay.com/itm/LG-46LD550-UB-Main-BPR-Total-Assembly-EBU60852909-subs-to-EBU60852911-/150895037335?pt=US_TV_Boards_Parts_Components&hash=item23220b8b97
Sep 11, 2012 | LG 46LD550 46 in. LCD TV
Both HDMI ports are bad due to lightening strikes. What do I need to do to fix this? Can you suggest part numbers?
The main tv Tuner signal board have problems and all those HDMI insert ports are shorted dead,those HDMI insert ports are put on by wave soldering machine and fused by iron core solders joints to the main tv Tuner board itself.These HDMI insert ports are not replaceable by hand soldering equipments or can buy those HDMI insert ports individually anyway.Tv still work wright?Yes? Why don't u just skips the used of those HDMI insert ports all together and tries used those RCA component cable connections like AV1 and AV2 on the tv.Or u must have some mechanicals skills and like take things aparts and putting back together again?Yes?Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv main Tuner signal board for the replacement to able to used those HDMI insert ports again.I have the same problems with my Samasung 46" all my HDMI insert ports are dead too,but the tv still functions.That what i did used RCA cable components connections for my cable box and blu Ray player.
Aug 03, 2011 | Sceptre X42BV 42 in. LCD TV
Instead of replacing the Seine PCB board (which is supposedly what the problem is) on our 42LX177 Toshiba LCD TV we are going to try the SD fix from this website but we need to know where the metal plate...
Dec 18, 2010 | Toshiba 42HL167 42 in. LCD Television
I have a model no. 32HLC56 TV. Everything seems to work fine, except the color of football fields. They come in gray instead of green. However, other things, such as uniforms that are supposed to be...
Take this tv set test it with other tv incomming tv signal cable in ur house or take another tv test this incomming broadcasting signal cable.If it is the tv,not the incomming broadcasting signal cable.The tv Tuner signal board is the causes and it is dying.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacemennt.
Dec 09, 2010 | Toshiba 32HLC56 32 in. HD-Ready LCD...
Problems with Toshiba 32HLC56. When we turn it on we get sound but no picture after leaving it on for a while and turning on and off it comes on. Why is it doing this?
Ur LCD inverter backlight board have problems.Just not completely dead yet,when it is completely dead u will get sound only will not get any picture.When that happen,must replaced the LCD inverter backlight board to get picture back.This is a long board in shape.U can buy a refurbish LCD inverter backlight board at Websites Shopjimmy.com,Ebay.com for the replacement.
Mar 16, 2010 | Toshiba 32HLC56 32 in. HD-Ready LCD...
WHERE CAN i GET THE MANUAL FORToshiba 32HLC56 32 in. HDTV-Ready L
What you need is what they call a Service Manual. It has everything you need.
Here's the link:
Toshiba - 32HLC56 Service Manual on Windows Drivers Downloads
I'm sure there's a fee for downloading.
Good luck with the TV repair.
Apr 24, 2009 | Toshiba 32HLC56 32 in. HD-Ready LCD...
Apr 14, 2009 | Toshiba 32HLC56 32 in. HD-Ready LCD...
Toshiba 32HLC56 32 in. HD-Ready LCD Television Logo
270 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
