Question about Amana RanARG7302 Gas Kitchen Range
I spilled water on my gas stove.. out of 5 , 3 burners are working but there is a continuos clicking of the sparky thngs attached to each burner....
  • 999 Answers
Sounds like water got into one of the burner switches. It may dry out and stop or you are going to have to replace the switch. If taking apart to replace I would replace all the ones that got wet when the water spilled.
Eric
Posted on Aug 21, 2010
Gas burners clicking noise not lighting
Have you dis-assembled the burner assembly and cleaned them out?
Dec 23, 2013 | KitchenAid KDRP467KSS Dual Fuel (Electric...
I have a GE Monogram Gas Stove - 5 burner. All
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
w3
Jun 15, 2010 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
Stove top burner ignitors will not turn off
This tip I wrote to help people with the problem of the spark not shutting off...the clicking non-stop is a common problem.
Gas Range2_bing.gif Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Apr 30, 2010 | KitchenAid KGST307 Gas Kitchen Range
Gas was turned off and igniters keep clicking?
As I did not see what occurred, I suspect that the tea kettle boiled over and sent water into the burners. The igniters kept clicking and I eventually turned the gas back on. Will have to replace one igniter which apparently went out and have to light it manually at this point.
Dec 11, 2009 | KitchenAid Cooktops
My roper stove keeps clicking even when all knobs are off!!!
spilling water around spark control switches closed to burner control valves could cause that...may stop clicking in a day or so..or if on low flame setting the orfices on the burner head are carbon restricted? clean orfices with torchtip cleaners..
Jun 24, 2009 | Roper FGP210 Gas Kitchen Range
Kenmore gas range
hi Clogged burners are a very common problem with gas ranges because foods spilled on the burners block the gas ports and prevent ignition. On some gas ranges you can remove the top ring of the burner to expose the ports. Here's how to clean a burner:
Step 1: Turn off the power supply, both gas and electric, to the range. Then remove the burner.
Step 2: Soak the burner in a solution of mild household detergent and water. Clean it with a soft cloth.
Step 3: Clear the gas ports with a pin or needle, rinse the burner, and let it dry. Caution: Do not use a toothpick or matchstick to clean the gas ports. If the tip of the wood gets stuck in the burner ports, it could cause a serious blockage.
Step 4: When the burner is completely dry, replace it, and turn on the power and the gas supply.
Nov 06, 2008 | Kenmore 75022 / 75024 / 75029 Gas Kitchen...
Stove-top burners
heatman101
bvn
Jul 10, 2008 | Belling 27 in. CTC465 Electric Cooktop
Amana RanARG7302 Gas Kitchen Range Logo
894 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mike Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
