Clarion MAX385VD Car DVD Player Logo
Anonymous Posted on Aug 21, 2010
I popped off the mono/adj button on my Clarion MAX385VD Car DVD Player. can i buy individual buttons to replace if this happens?
  • Anonymous Aug 21, 2010
    i appreciate the tip about putting the button back into place but i cant find the button so i need to know where i can buy them?
    actually i think we are miss understanding each other. i dont need the entire button. it is just the plastic part of the button that snaps into the head unit.
Willard Broughton
Level 2:
Sergeant:
  • Expert 252 Answers
  • Posted on Aug 21, 2010
Willard Broughton
Expert
Level 2:
Sergeant:
Answers
252
Questions
0
Helped
41583
Points
715
You will have to order specialty parts like that from Clarion. Call customer support at 800-347-8667 Mon- Fri from 7am to 5pm. All you have to do is give them your model number and they will ship it to you.
  • Willard Broughton Aug 24, 2010
    You are not going to find any small part for your radio unless you go back to the company that made it. You don't have the kind of radio that spare parts for it would be laying around someones shop. this radio suggested retail is $700.00 which is considerd an investment. Please go to Clarion and by your part it is not that expensive. Thanks
Level 3:
  • Clarion Master 17,130 Answers
Clarion Master
Level 3:
Answers
17130
Questions
0
Helped
3631717
Points
52372
It is difficult to buy one individually as it comes with the Panel. I would be easy to have the button stuck on back to the panel .
I shall give below a service tip we tried on.
1. Open the panel and remove. fix the button on the correct position and use an instant glue to fix it in place.
2. Now use thin strips of thin stranded wires - from a power connection cord- use this bit and with the help of a soldering iron touch the wires into the button and to the panel so that you have the attachment in good structural fitting.
3. Reinforce the plastic with glue to set.
Now the button must stay in place and will not POP out.
If you take care to so the job it will be as good as new.
I hope this trick works.
Good day
1helpful
How I can reset a Clarion MAX385VD?
If there is a reset switch, there will be a pencil tip sized depression somewhere on the face. It will not be marked. If there is no reset switch, just disconnect the battery for a minute or so.
Asistanse t unlock my stereo clarion of my car. ..
This stereo does not need to be unlocked but if you are getting some problems the best way is pressing the reset button. Follow this link to see the owners manual.
http://www.clarion.com/us/en/MungoBlobs/391/380/VRX485VD,2.pdf
1helpful
Im trying to wire a clarion max385vd into my 2004 gmc sierra do I need to purchase any extra wiring harnesses
Yes you will.. a good car audio shop in your local area will have what you need in stock.
Where are the audio inputs on the max385vd clarion dvd players which cable is it
the red rca's are the input and the black rca is the video input
pls rate
1helpful
Park brake switch
If you have the old firmware then all you need to do is ground the parking brake wire..
if you have the new firmware(just bought the system) a toggle switch is involved:
1 - connect e-brake wire from dvd unit to the switch
2 - connect a ground wire from switch to the unit chassis(any good metal grounding surface will do)
3 - pop in a dvd, toggle the switch back and forth 2 or 3 times depending on what wire you placed where...and voilaa!! your dvd system should work in motion!!
My screen went dim and only the power button works
Most likely an insufficient ground is the culprit. Clarions are VERY dependent on a good ground. Check your connections - again...redo the ground if there's no change. If that doesn't work, take it to your local car stereo installer and ask them NICELY to diagnose the prob (probably free) if they do it FREE, buy the dude lunch $10
Good Luck
Clarion max385vd i mounted it in a camper need bypass code and how to enter it what about green wire?
you only need to connect the green wire to earth then u can watch dvd's whilst drivin it is meant to be connected to the handbrake but this bypasses it
No sound
you need to buy the wireless head phones for this unit. try the dealer or best buy
I just installed a Clarion max385vd. When we turn the headlights on, the buttons and screen illumination on the head unit keep flashing from dim to bright. Everything else is working perfect.
illumination wire does not need to be installed on this model. depending on your car, it may use odd voltage for the dash lights. Clip and tape off the illumination wire going to the harness.
Top Clarion Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
