Question about Watches
I HAVEW A FONDINI STAINLESS STEELE QUARTZ MENS WATCH WITH THREE SMALL DIALS AT 12.00, 6.00 AND 9.00. WHAT ARE THE DIALS FOR AND HOW DO I CHANGE THEM
  • 17 Answers
SOURCE: I can't get the stainless steel back off my watch
Does it screw off or is it a pop off? If it is a screw off you need a jax tool and read the instructions. If it is a pop off you need a tool and find the indentation or tab to lift up on to pop off the back. I use a Testors razor knife because it is strong and thin but Always Use Eye Protection when doing this. Most folks do not undertake this. If you do remember you have to more often than not need a watch presser to press the back back on. You can find them on watchmaker supplie sites (or Ebay or similar shady places). This is a necessary item to have to do this and most people do not undertake this unless they plan on doing this often. Novices using a case press often includes shattering the crystal when they do not know what they are doing. It takes experience and research to do the most common watch repairs.
Posted on Nov 19, 2008
escapement
  • 2334 Answers
SOURCE: Adjust watch band for Seiko 7T94 Stanless Steel Band
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Apr 04, 2009
SOURCE: no watch setting directions
Some of the inexpensive watches like to mimic the expensive watches and put fake dials on the face of the watch. That way you get a Breitling look alike at the price of a Timex. If there don't appear to be controls for the dials, chances are that they aren't real dials, Look closely.
Posted on Jun 15, 2009
escapement
  • 2334 Answers
SOURCE: ICHRONO ARMS DO NOT LINE UP AT 12:00
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all Invicta watch manuals. Rate me, please
Posted on Mar 09, 2010
  • 8404 Answers
SOURCE: What tools do i need to remove back cover to
sharp knife.
Posted on Mar 18, 2010
What battery does this watch use
http://www.fixya.com/support/t7335468-remove_stem_get_battery_in_ebel
Mar 17, 2016 | Ebel Mens Classic Wave 18k Yellow Gold/...
Invicta model 12983, how to set day on the subdial
View the instruction manuals - Invicta
invictawatch.com/service/view-the-instruction-manuals
Enter your 4 or 5 digit model number to locate your watch. RECEIVE THE NEWSLETTER SOCIAL MEDIA · Terms & Conditions Customer Service Service ...Missing: 12983 ‎subdial
Setting Time Date Invicta Watch Chronograph - SmartBargains
https://www.smartbargains.com/.../Setting-Invicta-Chronograph.html
Know how to set time, day, and date in the Invicta Watch Chronograph. ... Invicta sells several different kinds of chronograph watches, with the two main ... and the Invicta Big Date and Day chronograph - the subdials that measure seconds and ...Missing: 12983
Invicta Reserve 48mm Octane Swiss Made Quartz ...
Jan 16, 2016 | Invicta Reserve Mens Arsenal Swiss Quartz...
What is the battery that goes in an Invicta Reserve Model 1957 watch?
395...
http://cdn.invictawatch.com/invictawatch/website2014/webroot/uploads/manuals/7-5040d-pdf
Jul 29, 2015 | Invicta Mens 1957 Stainless Steel Reserve...
Set the gmt on renato t-rex
Take a look here - you will need the model information for your watch that should be on the back of the watch. Good luck! http://www.renatowatches.com/manuals/
Oct 19, 2014 | Renato Mens T-Rex Swiss Quartz Stainless...
My DZ 7241 watch analog watch does not turn on?
please ckeck the crown of your analog time if it is pressed down, if it is pressed it is possible that even if it is a brand new watch, the battery has no power at all.. it is maybe that your newly purchased watch is been in its selling showcase fo a long time, so that the watch movement consume all the power of the analog's battery.. you have to replace the battery of your analog., Note: your watch has three batteries. I hope this will help..
Feb 05, 2013 | Diesel DZ7241 Mens Watch Stainless Steel...
Which is a better gift for my boyfriend? Please do help. :)
the swiss watch. also a new fishing rod and a case of beer
Apr 06, 2017 | Timex Indiglo Watches
Watches Logo
158 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
