Question about Microwave Ovens
I have Krups machine, and the error code is 0A.
Lost directions - how to descale keurig ?
Hello, Here is a tip i wrote, see if this helps you.
Have you ever wondered, 'how do I descale my expresso machine?' First lets us understand what is exactly is scaling. The build up of minerals inside the hot parts of your coffee machine or espresso machine is commonly called lime scale. When lime scale builds up inside the Espresso machine, it slows down the water flow, reduces the boiler capacity and can prevent your coffee machine from working properly. To keep your Espresso machine operational at full order, it is important to descale it every three months. The time intervals between descaling depend upon many factors. Quality of your water and the amount of water running through the machine are the two main factors that decide the frequency at which you should descale your Espresso machine. The more you your machine, more often should you descale it. In some cities, in conjunction with a water filter you can use your coffee machine for a year or more without descaling at all. If you use less water by drinking espressos you'll need to descale less often than if you make cappuccinos.
Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Espresso machine is intended for this specific use only. Before you descale your Espresso machine, always unplug it and make sure that it is cold. Also, never immerse the appliance in water and nor should you use abrasive cleaning products or scouring materials on any part of your Expresso machine. In case your Espresso machine does not come with a instruction guide or booklet, then use a proper citric acid based descaling solution designed for espresso machines. This should be mixed and prepared as per the instructions on the bottle or packet. Once your Espresso machine has been descaled properly you would not be left wondering, 'how do I descale my expresso machine?', treat yourself to a great cup of coffee. Some popular models of Espresso machines are Krups EA8080 Espresseria Automatic, DeLonghi Magnifica EAM3200S, Krups Nespresso CitiZ & Milk XN 7106 Fire-engine red, DeLonghi Perfecta ESAM5400, DeLonghi PrimaDonna ESAM6600, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5500 and Magimix Nespresso Citiz M190.
Jun 29, 2011 | Microwave Ovens
What does it mean to descale my tassimo? the yellow light is on and the screen keeps saying "descale". thanks
In order to keep your Tassimo machine operational at full order, it is important to descale it every three months. Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Tassimo machine is intended for this specific use only. Mix the descaling product directly in the water container, following the instructions provided on the descaling packaging. Then replace the water container on the machine. Place a large cup or mug on the cup stand, insert the cleaning disc, bar code down and close the brew mechanism. As soon as the AUTO light illuminates, press and release the start/stop button. This will fill the brew cycle with descaling solution. Empty the cup and let the machine stand for 15 minutes. Then open the brew mechanism and close it again, leaving the cleaning disc in place. Repeat this step two more times for maximum descaling effectiveness.
Discard the remaining descaling agent from the water container, rinse it well and refill with fresh, cold water. Clean the machine by flushing water through it in the same manner and emptying the cup as it fills. Make sure that all the descaling solution has been completely rinsed away, and then flush two full water containers through the machine before using it again. Remove the cleaning disc, rinse and refill the water container and your Tassimo machine is ready to use. Also, before you descale your Tassimo machine, always unplug it. Also, never immerse the appliance in water and nor should you use abrasive cleaning products or scouring materials on any part of your Tassimo machine. This method works for most espresso machines, including some of these popular models: the DeLonghi Magnifica EAM3200S, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5400, Gaggia 74507BCN Classic, Krups EA8080 Espresseria Automatic, DeLonghi PrimaDonna ESAM6600, the BC0255 DeLonghi coffee machine and the Krups Nespresso CititZ XN 7006.
May 16, 2011 | Microwave Ovens
Error E:02 comes up
Hi nic_marlon,
The meaning of the error code depends on what brand of your machine is. If you can provide it to me I can give you accurate information. On Westpoint this error means you have a temperature sensor error. The sensor is damaged or faulty.
Hope it helps.
Thank you for using Fixya.
May 08, 2011 | Microwave Ovens
I have a krups anticalc kit f054-00 for my espresso machine, but there are no english instructions and I don't know how it works.
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Apr 11, 2011 | Microwave Ovens
Where can I get a free manual for the 863 Krups Espresso machine?
go to krups web site they should be able to help... worth a go..
Feb 27, 2011 | Microwave Ovens
I need a manual for the Krups FNC2 Novo 3000 Espresso Maker
This was very difficult to find, but I found it just for you! Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. I would be forever grateful if you could do this for me. To view the manual you will need adobe reader, which you can get for free from http://get.adobe.com/reader/ You probably already have it though, please try opening the file first and find out. Here is the manual / guide please give it a few minutes the file is quite large:
http://www.scribd.com/doc/15940731/Krups-Novo-2300-3000-Manual
Oct 13, 2010 | Microwave Ovens
Water will not pass through the capsule?
Try running vinegar in stead of water, without the coffee thru it several times.
Dec 27, 2009 | Microwave Ovens
Microwave Ovens Logo
124 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
