Question about Vivitar ViviCam 8025 Digital Camera
Camera reads card protected how do i unprotect
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Vivitar Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on Aug 21, 2010
Testimonial: "thanks for the correct solution"
SOURCE: how to unprotect the memory card
the problem isnt with your camera, its your memory card, and it isnt a problem at all. simple solution- take out your memory card, and on the side there is a tiny switch. all you gotta do is flip the switch. quick and easy. hope that helps anyone.
Posted on Sep 18, 2008
  • 4 Answers
SOURCE: Turn off card protection
The SD card has a small "lock" slide switch on its side. Simply slide it away from the contacts edge.
Saul.
Posted on May 16, 2008
On most sd cards there is a physical (tiny) sliding switch on the memory card. Here is a picture of a standard SD card. On the left you can see the gray switch in the unlocked position. Hope that helps. -WN
4bfc547.jpg.
Posted on Aug 27, 2008
  • 102366 Answers
SOURCE: message reads protected card and has locked the camera
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on Jun 12, 2010
  • 102366 Answers
SOURCE: The camera says that my Memory card is protected.
If you had protected any pictures on the card, then while viewing that picture press the Menu button. Use up/down to select Unprotect.
Posted on Oct 13, 2010
Testimonial: "Thanks so much for your help. This is my very first digital camera. It was a very simple solution but very powerfu information for me. "
How do I unprotect pics on a 0lympus c-765
As it was the camera that put the protection on ..You need to put the card into the camera..And ..UN-TICK each one to unprotect them...The idea of the protected photos is so you cant erase them when you format the card.
Sep 28, 2014 | Olympus Camedia C-765 Digital Camera
How do i unprotect memory card
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 02, 2014 | Nikon COOLPIX S630 Digital Camera
How can I delete" write protected" and protected photos from sd card individually?
Unprotect them first, then you can delete them normally. See page 129 of the manual at http://gdlp01.c-wss.com/gds/3/0300001393/01/eosrebelxs-1000d-im-en.pdf
If the memory card is protected, unprotect the card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 07, 2013 | Canon EOS Digital Rebel XS / 1000D IS...
Unprotect a card
Dec 23, 2012 | Nikon COOLPIX L18 Digital Camera
How to unlock a photo in camara
The protect function allows a user to protect a picture from accidental deletion. To unprotect a picture on your camera, scroll to the protected picture that you want to delete, then press the Menu button (the button to the right of the Play button.) Scroll down the menu and you should come to an option that allows you to Protect/Unprotect the picture. Since your picture is currently protected, deselect that option. You should then be able to delete the picture normally.
Alternatively, you could also format the memory card, however this deletes ALL photos and data you have on the memory card. If you are trying to completely clear the memory, this is the best way. After turning on your camera, simply press the Menu button, scroll to Setup, then scroll down to Format. Select Format, it will ask you if you want to format the memory card, or the camera's built-in memory. Format whichever one you want to clear, if you are using a memory card then your pictures are stored on the memory card. It will take a few seconds to format.
Hope this helps.
Dec 05, 2012 | Kodak EasyShare M1033 Digital Camera
How to delete protected images
If you want to delete everything on the card, the easiest way is to format the card. This will wipe out all images (and any other data as well) on the card, whether protected or not. The Format command is in the Setup menu. Details on page 32 of the manual.
To delete individual protected pictures, unprotect them first. From the Playback menu select Protect/Unprotect (the key icon). Details on page 84.
Mar 16, 2012 | Canon PowerShot SD600 Digital Camera
Protection problem
Easy solution:
1) Put the sd card into your computer
2) Copy all the photos to your computer. User Windows Explorer to just drag the folders from the card.
3) Format the card
If you insist on having the photos back on the card, then just copy them back to the card using Windows Explorer reversing step 2.
Aug 26, 2009 | Sanyo VPC-E760 Digital Camera
Card Protected
If you read the manual there is a section on protecting frames. You should be able to go into the menu on the camera and unprotect all, which should allow you to then write new photos and remove old ones on the card.
HopHead
Oct 28, 2008 | Fuji FinePix S7000 Digital Camera
How to unprotect the memory card
4bfc547.jpg.
Jul 27, 2008 | Nikon Coolpix 4600 Digital Camera
Card Reading Write Protected
hi there
some card do have a physical lock onto itself to protect files.
please check your card and look for a small switch, its usually at the side. click it up or down and try re inserting it to your cam. if this still isnt any help, it must be a setting on your cam.
hope this helps. :)
Feb 06, 2008 | Olympus Stylus 410 / ? 410 Digital Camera
Vivitar ViviCam 8025 Digital Camera Logo
135 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
