Question about Tusa Geminus Two Window Mask Cobalt Blue Clear Silicone SCUBA Equipm
Clear silicone seems to turn green and or yellow when applied to the post catayzed convertion varnish coating on my high end custom kitchen cabinetry. Is it the coating that is changing, or is it the silicone telegraffing colors from the adjacent granate / solid surface etc? Or is it a chemical reaction between the coating and the silicones curing process?
Why wont headlights come on
Bad relay. Here's a tip. Open up the replacement relay, and thoroughly coat the thin wired coil with clear nail polish (or good 'ole varnish). Keep applying until there's a good thick layer covering the entire coil, and also coat the lead wires. Doing this will utterly prevent future burnout. BTW, you can do the same with the charging relay. The coil's wires are so thin that they burn out with the slightest overload. Coating them not only protects them from burnout, but also from corrosion... forever.
Oct 15, 2015 | Harley Davidson 2010 Flhrc Road King...
Primary cover will not come loose on Harley sportster 1200 how do I remove
Get a fine gasket scraper and wedge it very lightly to un stick it start on back side and slowly go around till it unsticks someone used like a head gasket glue on it !!! instead of gasket I like clear silicone never leaks end of problem !!! Apply clear silicone very lightly let stand and get tacky and slam it on and be done
Mar 27, 2013 | 2000 Harley Davidson XL 1200 C Sportster...
Repair scratches on a stainless steel refrigerator
YOU WILL NEED A POWER POLISHER WITH A BUFFING PAD AND SOME YELLOW ROUGE AND WHITE ROUGE, (CAN BE PURCHASED AT HOME DEPOT TOOL DEPARTMENT). APPLY BUFFING PAD TO POLISHER AND TURN ON, SET TO LOWEST SETTING, APPLY YELLOW ROUGE TO PAD AS IT SPINS, ( START AT CENTER OF PAD AND MOVE OUTWARDS), DO THIS TWICE THEN BEGIN POLISHING STAINLESS,APPLY SLIGHT PRESSURE BUT ALLOW POLISHER TO DO WORK, REPEAT AS NEEDED, APPLY WHITE ROUGE TO BRING OUT SHINE.
Sep 20, 2011 | LG LRFD25850 French Door Refrigerator
Is a light coating of oil the only thing to use to return your gas grill exterior to a shinier black again? Was thinking that would make it sticky after it heats up.
A light coat of oil will bake on and create a brown varnished look that you will have one heck of a time getting it off. If the gas grill is painted... and not porcelin coated no amount of cleaning will bring back the shiny black if the pain has been faded by sunlight. The only thing that will bring back that sheen again is a "high temp" gloss enamel paint. (Clear coating is NOT recommended. post paint as it will also darken even if it is high temp)
To clean it use a product like Mr. Muscle Kitchen cleaner or similar product. Engine degreaser works too but will dull the paint. If you plan on cleaning for painting you can use engine degreaser. If not... stick with the Mr. Muscle kitchen cleaner. Just make sure to rinse thoroughly and let it dry and lightly sand / wipe before painting.
Thanks for choosing FixYa,
Kelly
Jun 04, 2011 | Garden
Paint colour for 1973 tx750 yamaha
Can duplicate the 73 paint but it is gold candy over silver metal flake.
  1. apply Grey primer sealer
  2. apply silver base coat, apply 3 coats
  3. apply silver metal flake mixed with clear, about 3 coats
  4. apply about 2 coats heavy clear
  5. sand clear smooth because metal flake makes it rough
  6. apply about 3 coats of tinted clear (candy gold or yellow)
  7. let it dry, inspect it, wet sand with 600 or finer
  8. apply final coats of clear to all parts except the fuel tank, apply only one coat to tank
  9. lightly wet sand the tank
  10. paint the gold and black striping on the tank, don't have any stickers and paint is thinner
  11. apply 3 medium coats of clear to the tank
  12. west sand with 1200 grit and polish all parts
  13. mix huge glass of good tequila, get lawn chair, sit back and admire
hope this helps
John
May 23, 2011 | Yamaha TX 750 Motorcycles
Hard to turn spout side to side
Remove the spout and apply a thin coating of plumber's waterproof silicone lubricant to the O-rings on the spouts mounting post. If the spout is still difficult to turn, replace the O-rings. Here is the link to the delta waterfall parts breakdown.
Sep 04, 2010 | Delta Faucet Delta 172-SSWF Waterfall...
While applying clear coat over silicone base coat we get spots of dust mostly colored black or white.what to do.base silicone paint and top coat is PU
Open Total Video Converter.
2. Select New Task -> Import Files .
3. Select the Video file to be convert.
4. Select MJPEG Avi Video format.
5. Select Motion MJPEG Avi Normal Quality Profile.
6. Goto Settings.
7. In Audio Option Select Audio Codec to pcm_s16le.
8. In Audio Option Change Sampling Rate to 8000 frames/second.
9. In Audio Option Change Bit Rate to 128 Kbits/s.
10. In Audio Option Select Volume level 255.
11. In Video Option Select Video Codec to mjpeg.
12. In Video Option Change Frame Rate to 15 frames/second.
13. In Video Option Change Bit Rate to 128 Kbits/s.
14. In Video Resize Option Change Video Size to 128 x 104
15. Then Save & Apply the Settings.
16. Now Convert the file.
download and enjoy
Jan 12, 2010 | Samsung Cell Phones
Can a starter tube on a carburtaor be fixed?
need a pic of the damage ?
if just the copper you can propane torch with solder
if the carb body is to far damaged can use high temp silicone (red) clean area with laquer thinner let dry then sand 120 blow off dust
then apply silicone lightly let 20mins pass the apply finsh coat
Apr 06, 2009 | 1996 Suzuki GSX 1100 FT (Katana)
Lexus ES300 trunk leaks when it rains
This may sound odd but if you can put a small person in the trunk with a flashlight while you pour water in the areas suspected, they can trace the leaking area, believe it or not I used to use this method while I was a Ford mechanic. Otherwise, maybe you can apply clear or black silicone to the area or remove the screw or bolt and coat it with silicone and replace it.
Apr 04, 2009 | 2000 Lexus ES 300
The rubber on the speaker surrounds
I have removed all te rubbercoating by using a degrease liquid the they use normaly in the kitchen to clean the oven : It's perfect now .. a clean plastic surface ... just like new !!!
Be careful with other agresive cleaning products , otherwise you demage the plastic surface below the rubber coating .
Try it out it works perfect .
I hope your problem is solved now .
Excuse me for my incorect englisch ... i'm living in Belgium and my motherlanguage is dutch .
Sep 20, 2008 | JVC RV-B90 Boombox
Tusa Geminus Two Window Mask  Cobalt Blue Clear Silicone SCUBA Equipm Logo
447 people viewed this question
Top Tusa Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you a Tusa Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
