Question about DISH Network ViP722 DTV Receiver / 350-Hours Video Recorder
Just got dish a week ago everything fine. Yesterday the power went off and now the main TV has arch screen and three different colors on everything on the TV and TV 2's screen is just blue
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 358 Answers
Wvpotts0,
Are you still having problems with your receiver? Depending on the type TV you have, TV 1, on an older TV will use channel 3 of 4. A newer TV will have an input setting. If you have the TV remote, press either the "input", "source", or "tv/video" button to cycle through the input settings till you find a picture. Make sure the green, blue, and amber lights are lit on the receiver. TV 2 should be on channel 60 or 73. I hope this helps.
Ray Calo
DISH Network
Posted on Jan 08, 2011
I have Dish 322 receiver. Everything was fine; a week or so ago satellite 119 reception was spotty, now we can't get 119 at all. We get 110 but only about 34%. Sometimes the receiver will power itself off...
hartpark
It looks like you have lost the signal for the 119 satellite from your dish. Are you getting an error message, either 002 or 015, saying the satellite signal has been lost or acquiring satellite signal? First, check the cables on the back of the receiver to make sure they are secure. You can also run a check switch test to see if there is a problem between your dish and receiver.
Press the Menu button on your remote. This will bring up the Main Menu on your TV screen. Input the numbers: 6 (System Setup), 1 (Installation), and 1 (Point Dish). On the right side of the Point Dish screen are 3 buttons. Select the Check Switch button. Within the 2 large boxes are satellite numbers and green or red boxes. Make a note of the satellite numbers (should be 119, 110), the trans, the device, and switch. Super dish and alternate should not be checked. Select the Test button on the bottom of the screen. If a box pops up with a warning about TV 2, select Yes. It will now run the check switch test. Let it complete the test. After completion, the screen will automatically go back to the Installation Summary screen. You may get a message stating that the Check Switch test has found fewer satellites than previously detected. If you get this message cancel out of each screen (do not save the results) till you are back to the TV screen and it is acquiring Satellite signal.
If you don't get that error message, see if the information on the Installation Summary has changed. Then select Done on the next 2 screens and cancel out of the others till you get the message, Acquiring Satellite Signal. After it finishes acquiring satellite signal and downloads the program guide, see if you are getting a picture - try different channels. If you still have problems, please email me at, ray.calo@dishnetwork.com. If you are still experiencing problems, we will need to send a technician to fix the problem.
Ray Calo
DISH Network
Apr 23, 2011 | DISH Network 322 DTV Receiver
No blue color on tv screen
Your welcome ! please comment. Thank you !
May 01, 2009 | Samsung SlimFit TX-S3082WH 30" TV
Mitsubishi vs 5043
I turned the set on and everything was fine, then the screen went black and mullti-colored horizontal (arched) lines were flashing across the screen. The next day I turned the set on and everything was fine for about 5 minutes then the problem reoccures again. Haven't looked for solutions till now.
Apr 06, 2008 | Mitsubishi VS-5043 50" Rear Projection...
WD-52725 TV loses picture while playing DVD but not sound
replace DM or try to fix it.
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
Jan 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Samsung HDTV Oval rainbow of colors covering entire screen
I HAVE PANASONIC MODEL TH50PE700U WATCHING IT AND THE COLOR WENT YO B/W
Oct 04, 2007 | ViewSonic N2750w 27 in. HD-Ready LCD...
Re Degaussing
Now Degaussing and convergence are two different things, if you say its degaussing then you should have just a color differential in a certain area, meaning the color should not be arched, everything that passes through should pass throu only with the changing of color. Now if its a convergence the the color may lift upward in an arch, likely separated from the other colors, Red, Blue,or Green. So now which do you think you have? Deguassing usually give you a highish green color or yellow
Sep 11, 2007 | Panasonic PT-47WX52 47" Rear Projection...
Alighning tv
i have an alinemenet problem with my rca tv P52929 i went to the book and it said to go to the menu and select 3 which is the screen menu then select option 6 which is the adjust projection tv. this is suppose to allow you to adjust the the tv's three colors. it says to select the green centering to adjust the green tube. blue for the blue and red for the red. it says to center the green first then adjust the red and blue tubes until the test pattern on the tv screen appears white. i hope this helps you. my problem is that the program is not in my tv. it has everything else but not the option 6 to adjust the tv. this may be your problem to. good luck.
Apr 15, 2007 | RCA P52929 52" Rear Projection Television
Tv will not turn on
your tv needs to be repair again power supply problem or circuit.good luck.
Apr 04, 2007 | Toshiba 37HLX95 37 in. LCD TV/DVD Combo
DISH Network ViP722 DTV Receiver / 350-Hours Video Recorder Logo
118 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
