Question about Philips GoGear KEY019/17 Digital Camera
When i turn on my gogear it says cam on the screen and won't let me do anything can anyone help
My phillips gogear started acting weird last night when the screen turned whit, i literally cant see anything on the screen now and am NOT willing to pay to fix it, any suggestions?
Hi, there!
Your philips gogear screen is bad get it replaced and things will be normal .
there is nothing wrong with the machine other than this lcd .
Good luck .
Nov 30, 2009 | Philips GOGEAR SA6045 MP3 Player
It just says gogear on the screen and it will not show anything else. i can't turn it off it seems as if none of the bottons are working. the battery lookes to be charging then this Gogear will just come...
It just says gogear on the screen and it will not show anything else. i can't turn it off it seems as if none of the bottons are working. the battery lookes to be charging then this Gogear will just come back on till the battery runs out. what can i do.
Sep 15, 2009 | Philips GoGear HDD1830 MP3 Player
My mp3 player is fully charged right! i try to play my songs. it says phillis then turns black screen,phillis then black screen,over and over it says this! i tried to plug it into my labtop and nothing...
Reset the player first. If that fails:
Recovery Mode for Philips' GoGear
Open the Philips Device Manager (Start à All Programs à Philips Digital Audio Player à SAXXX à Philips Device Manager) and click on the “Repair” tab. Then click on the “Repair” button to start the repair process. Most of the time, when your player is in that state, the Device Manager will not recognize that your GoGear is plugged in. If this is the case: Disconnect the player from the PC, and make sure the mp3 player is turned off. Hold in the volume + button on the mp3 player, and reconnect the player to your pc while holding in the volume + button. Continue holding the volume + for 10-15 seconds until a "Found New Hardware Wizard" pops up. It should recover your device if there isn't anything internally wrong with the player. Warning: this procedure will result in your songs being erased off the player, so they will have to be reloaded.
-Tha Mp3 Doctor
Nov 01, 2008 | Philips GOGEAR SA6045 MP3 Player
Philips HDD6330 - Dead?
WARNING: this process will erase all songs off the GoGear.
Disconnect the GoGear from computer.
Turn the GoGear off.
Hold in the volume + button.
Reconnect the GoGear while holding in the volume + button.
Continue holding the volume + button.
After 5-50 seconds, Windows will pop-up a "Found New Hardware Wizard." - complete the wizard (BTW, you can take your hand ff the volume + button now).
Good To Go (Gear)!
-Tha Mp3 Doctor
Mar 29, 2008 | Philips GoGear HDD6330 MP3 Player
I turn on my Go Gear and it freezes
Get a firmware upgrade...whenver you reset the device it reset the firmware install..so get the firmware upgrade and that should solve the problem you are having..hope this solve the problem
Jan 27, 2008 | Philips GOGEAR SA6045 MP3 Player
Philips GoGear KEY019/17 Digital Camera Logo
Top Philips Cameras Experts
Lyle Siemens
Lyle Siemens
Are you a Philips Camera Expert? Answer questions, earn points and help others
