Question about Zoom G1x Guitar Multi Effects Pedal with EXpression Pedal
Automatically turn on and off - Zoom G1x Guitar Multi Effects Pedal with EXpression Pedal
  • Zoom Master
  • 5,603 Answers
Most pedals turn on when a MONO type plug is inserted in the input jack, such as a guitar cable.
If you are having a problem we need to know what the exact problem is.
Posted on Aug 21, 2010
Psr s 910 keyboard. Why does it turn on for 5 minutes, then turn off?
Be sure to use the original adapter and still in good condition/normal.
Have you tried, at the time after 5 minutes then turn off, and then you restart immediately, the unit is turn ON again? Or is there a time lag to ON, after power-switch is pressed?
Errors like this one,may be due to defective adapters (works only for a moment, after being hot, stop sending voltage), and can also be caused by damage to the regulator section in PSR910.
To check this, it must open/disassemble the PSR910.
"Do not do this if you are not experienced in electronic repair.
Leave it to the experts."
At Yamaha PSR S950 keyboard, there is a setting "AUTO POWER-OFF" in the UTILITY menu.
This setting function is To prevent unnecessary power consumption. It will Automatically turns the power off if the instrument is not operated for a specified period of time. The amount of time that elapses before the power is automatically turned off can be set (default setting: 30 min.). The setting is retained even if the power is turned off.
At the PSR-S910, this function does not exist.
25916731-0iboo3zhsd2tihqbcqrvolhc-1-1.jpg .
Oct 20, 2015 | Music
Turn off accompaniment?
go to the utility settings, accompaniment settings..turn off.
Apr 09, 2014 | Roland FP-80-Digital Piano
I installed my new Roland SD-50 and all worked fine untill it turned off automatically (powersave mode was default). After that computer didn't find the canvas. I decided uninstall driver by hardwares...
You may have to coax it back by unplugging or even trying a different connector on the computer. It may have disabled the port due to a current spike. Using the devoce manager in the windows control panel, see if the port has been disabled. If necessary delete the device and tell it to seearch for new hardware.
Jul 17, 2011 | Cakewalk Roland SD-50 Mobile Sound Canvas
My recording function automatically turns on? I do even have to press any keys and it will just start recording. Its very fustrating because while I am playing it will often turn on and interrupt my...
Look for the button that starts the recording and see if it might be sticking down part way. If it is,then wet a Q tip with CRC226 and wipe the sides of that button. CRC226 is plastic safe and is available in the electrical dept of Home Depot.
Apr 29, 2011 | Casio Privia PX-130 Digital Piano 88 key
I need sound please
Make sure to plug it in before you start up the application. Make sure you restarted your computer after installing device.
Did you check system preferences to see the output settings?
I have mine set to output as headphones and have some external speakers in them. If I unplug them the computers speakers turn right on automatically.
Mar 03, 2011 | Akai MPK mini MIDI Controller Keyboard,...
On my yamaha v50 keyboard there is another sound on the keys after the c3 key how do i turn it off to just leave the synth sound?
you must do master reset!
1) Turn on the power.
TIP: All buttons must remain depressed and be pressed in the order mentioned in step #2 for proper execution.
2) Press and hold down the [SEQ] button, then the [CARD] button (located next to the Demo button), and then the [DEMO] button.
3) Continue to hold the buttons down until the dialog box appears in the display. The display will first indicate the V50 Test Program and Main Rom Version then will automatically display the question: 'Test Entry Manual?'
4) Press the [DEMO] button. The screen will display: 'Factory Set?'
5) Press the [+1/YES] button. 'OK' will appear beneath the 'Factory Set?' readout, indicating completion of the Factory Reset, and the V50 will automatically return to Play Mode.
Jan 10, 2011 | Yamaha Music
How do you use the automatic tuner
Hi, you have to clip it to the part where the keys are and turn the tuner on and which ever strig you will play will be indicated on the tuner and will tell you if it is flat or sharp, they you adjust your string by turning your key clockwise or conterclockwise. If you're to sharp don't forget to go a litte lower then bring it back to the right note. I hope it will help you. Mike
Oct 19, 2010 | Washburn D100dl Acoustic Guitar
Pocket Pod wont turn on
MOST pedal devices ENABLE the battery when the INPUT audio cable is inserted (there is a switch on the jack it plugs into). This automatically connects the battery when you go to use it... ALSO if you leave the cable plugged in will DRAIN the battery.
May 02, 2010 | Line 6 Pod 20 Fx Box
Zoom G1x Guitar Multi Effects Pedal with EXpression Pedal Logo
148 people viewed this question
Top Zoom Music Experts
Michial Gueffroy
Tom Chichester
rhodesworks
Are you a Zoom Music Expert? Answer questions, earn points and help others
