Question about Hoover Washing Machines
How to remove main drum bearings on Hover washer/dryer Performa1100/wa110
  • Hoover Master
  • 909 Answers
Sorry, not a job for a non appliance technician.(certain tools and know how needed) Things can break very easily and if bearings dont want to come off,that becomes anther problem.
Posted on Aug 21, 2010
How do I remove drum bearing from Candy CNW136 WASHER / DRYER
How do I remove bearing from Candy CNW136 washer/dryer.
Thanks
Reply to rsparling@manutec.ie
Jan 20, 2011 | Candy AQW130 Front Load Washer / Dryer
Zanussi 1400 jet model nowjd1457w ball bearings have come out
If ball bearings have come out, then there are only 2 possible places they could have come from.
1- The motor bearings.
2- the main drum bearings.
In both cases, it is a expensive fault to rectify.
To check, remove drive belt, and spin drum by hand, this should help you to tell if it is the main bearings or the motor.
Dec 16, 2009 | Zanussi ZWD12270 Front Load Washer / Dryer
Loud noise when spin drying, rumbling sound, sounds like concorde taking off! Hotpoint Aquarius 1200 washer dryer WD62
Remove rear panel of washer, and remove drive belt.
Spin the drum by hand, and if it feels rough, or is noisy, then the main drum bearings have failed, quite a big job to do.
Please rate my solution.
Thanks.
Nov 07, 2009 | Washing Machines
Loud banging
Several possibilities for noise. check concrete balance wieghts at top and bottom of washer, make sure they are not loose.
Check drum restraint spring(s) are not broken.
Check suspension legs for wear.
Check for loose motor fixings.
Finally, remove drum belt, and spin drum by hand, tjhere should be noise from bearings, if it feels rough or is rumbling , then main bearings have failed.
Please rate my comments.
Thanks.
Jul 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Fix main bearing
On every front-loading washing machine which I've replaced the main bearing on, it's normally removed and refitted using a suitable sized drift and a club hammer. Most of the time i find a trusty one foot length of scaffold tube which is in my toolbox does the trick.
If the washing machine has a polypropylene outer drum rather than a steel one then it's rare that the drum doesn't break whilst attempting the repair. On these types I've usually fitted a used drum from a scrapped machine, or more frequently just replaced the entire machine with another used machine which has been thrown away with a silly little problem like a blocked or broken pump.
Jul 02, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WMA37 - the drum is not turning, even by hand
Remove rear panel of washer, slip the belt off, then try the drum to see if it turns, if it does, then the motor is the problem, if it does not, then the main bearings have siezed, or there is something fast between the inner and outer drum..
If it was noisy on spin prior to this happening, then it is more than likely the main bearings that have siezed.
Plz rate my solution.
Thanks.
THAN
Jan 10, 2009 | Hotpoint Aquarius WD640 Front Load...
Removing/replacing main drum bearing on a zanussi WDT1085
Yes you do need to remove the drum, it entails stripping the washer down, and it is normal practice to replace the complete drum half with the bearings pre-fitted..
It is not a job to undertake, unless you feel competent to do do it, as it entails al ot of work and time..
Good luck if you decide to proceed.
Plz rate my suggestions.
.Thanks.
Jan 03, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Hotpoint wd420
if the drum is tight to turn ,then the main bearings have probably seized, or their could be something fast in the drum. Remove belt, and try to turn the drum by hand , it shuold be free with no resitance.
If it is noisy or feels rough, then the bearings have gone.
Sep 01, 2008 | Hotpoint Aquarius WD63 Front Load...
Haier Washer M # XQG50-11
Once you remove the rear access panel, you would see the main pulley on the rear of the outer tub. You need to remove that nut with a metric allen wrench. once the pulley is off, you can then remove the bolts holding the yoke in place. The Yoke and the bearings are available as a part assembly from haier. It is highly unlikely that you would need to replace the outer tub.
Mar 07, 2008 | Haier XQG50-11 Front Load Washer / Dryer
Fridgidaire gallery
From the sounds of things, you are talking about a front loading dryer. The agitators in the dryer can get coins stuck inside them. Remove the top and rotate the drum to reveal the screws which hold the agitators to the drum. Remove the screws and the agitators, empty the coins or other debris and reinstall.
The loud squeal sounds like the pad under the open side of the drum is worn out. There may also be a dry main bearing in the rear of the dryer. Lubricate the bearing and reinstall the drum. The squeal should disappear.
If this is not a dryer or a front loading washer, none of these suggestions will apply, Sorry
Feb 08, 2008 | Washing Machines
Washing Machines Logo
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
