Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
Dishwasher sounds as if it starts cycle, then stops, bleeps, and Fat and prewash lights come on. Manual says to turn off machine, turn off tap, wait 30 seconds and turn it all back on, but it doesn't make any difference. Manual says 'If the above does not solve the problem, check that the water feed pipe is not blocked' however, it doesn't say where this is, or how to do it. Please help!
  • 1 more comment
  • lesleyglaist Aug 21, 2010
    Hi Ginko,
    Thanks for quick reply. Does this mean pulling machine out? I can't see how to do this as it's wedged in with worktop, which includes adjacent sink, on top. Also how do I find the float sensor in the tub? It's not identified in the diagram in my usage booklet. Lesley
    Hi - thanks for your help so far! Looking for this water level switch panel, but there isn't one where you describe. In the base there is 1. the draining filter 2. a grey hexagonal nut a bit over an inch in diameter. Also high on the left side there is another pale plastic nut. Is the panel I'm looking for any of these,or does my model not have such a supply level switch?
    Unscrewing from inside the water feed pipe, I've found a split and torn washer ring, which I reckon would partially restrict the water inflow - could this be the source of my problem?
    Thanks - Lesley Glaister
  • lesleyglaist Aug 22, 2010
    I need you to identify a damaged part for me: inside the dishwasher, two-thirds way up the centre of the back panel, is some kind of inlet (my guess is this is where the water actually enters the chamber). It's outer piece is a round off-white plastic threaded disc, with a c. three-quarter inch hole at its centre, some 2 ins. diameter. I unscrewed this and found the circular washer fitting inside its rim is quite badly torn.
    Q: could this be enough to diminish water pressure by partially obstructing the inlet?
    Q: what is this part called so I can order a replacement?
    Hope you can identify this!
    Lesley Glaister
  • Hotpoint Master
  • 19,396 Answers
Hi.
You need to check the water inlet hose, that is the hose connected to house water faucet at the back of the dishwasher.
Checck for blockage in the hose and ensure that the inlet hose is not blocked or kinked.
If that is not the problem , then the inlet valve, that is the part with one or two hose attachment connected to the inlet hose ,must be tested and eventually replaced.
Also have a look at the water level switch (the float sensor inside the tub). if this is stuck, sunk or broken can cause the same problem.
Posted on Aug 21, 2010
  • 2 more comments
  • Ginko
    Ginko Aug 21, 2010
    Hi.
    Yes, the appliance must be pulled out to reach the inlet at the back.
    Regarding the floater, this is inside the tup, at the bottom on one side. The floater operates a switch located under the bottom panel inside the tub.
  • Ginko
    Ginko Aug 21, 2010
    Hi Lesley, please give me the full model number, as printed on service tag, so that I can locate the diagram for the exact model and tell you what kind of water level sensing is used, I thought to remember the FDW60 has a floater on one side.
    Thanks.
    It's a FDW60P, serial no: 80211 1627 37331831000 (not sure if all these numbers are relevant).
  • Ginko
    Ginko Aug 21, 2010
    Hi.
    There is a floater, it is inside the tub, near the bottom. There is also a pressure sensor under the kickplate.
    FLOAT/OVERFLOW UNIT or:FLOAT/OVERFLOW UNIT
    Here the water level sensor.
    Here the switch connected to floater, and located at the base, below the kick panel.
    Here pressure chamber.
    Here the inlet valve.
Indesit WIA121 Flashing Door Lock, Prewash and Spin Lights - Machine not draining
hi something similar has started happening to our washer, after the initial wash starts the machine doesn't do anything for a while then the red door light flashes on and off very quickly as does the 1st and 3rd green wash cycle light?
Jul 04, 2012 | Washing Machines
ESSENTIALS CDW60W10 Full-size Dishwasher the third light flashes and beeps then the cycle stops
ESSENTIALS CDW60W10 the 2nd light is flashing then it flashes and bleep for about a minute before the machine stops...I cant find my user manual anywhere..need my dishwasher working with my family!!! plz help!!! :(
Jan 04, 2012 | Dishwashers
I have an Electrolux EWD1477. I have been away for four months and I'm having problems with it. I set to do the quickwash30 program and press start, you hear the clicks, it might put some water in then...
My EWD1477 was doing this a year ago and I fixed it. Then it started doing it again a month ago and I seem to have cleared it again.
Firstly, remove the drain hose from where it is inserted into a laundry sink hole to make sure it is not blocked or sealed in with sludge.
Secondly, make sure the machine is empty of water and clothes and then turn the machine to off with the Program Selector Dial. Then turn off the power at the socket and remove the power plug and leave for five minutes.
Step 1: put the plug back in and turn the power back on.
Step 2: turn the selector switch to the right (Whites/Intensive). The green light of the Start/Pause button should be flashing and the green lights on for Prewash/wash, Rinses and Spinning. Don't press any other buttons or change any other settings.
Step 3: press the Start/Pause button and wait for the machine to empty any excess water. Press it again immediately after you hear water flowing into the machine OR two audible clicks. The machine is now in pause mode with the green light of the Start/Pause button flashing. Only the green light on the Prewash/Wash button should be on. Leave it in pause mode for 30 minutes and then press the Start/Pause button to recommence the cycle.
Step 4: If the Start/Pause button begins flashing, water stops flowing into the machine and the three green lights mentioned above are back on, turn the Program Selector Dial back to off, wait 10 seconds, and repeat the process above.
Step 5: If when you then turn the Program Selector Dial to Whites/Intensive and hear the two audible clicks, immediately press the Start/Pause button to set the machine in pause mode. Wait 30 minutes. Then press the Start/Pause button to recommence the cycle.
Hopefully the cycle will run without a problem.
Mar 26, 2011 | Electrolux Washing Machines
Start / resume light blinks. dishwasher won't cycle
my dishwasher runs through the cycle as normal for 20mins and then starts bleeping nonstop. opening the door the start light flashes without any pauses and the light above prewash is on. my engineer cnat figure this out as the flashing has no pauses. help.
Jul 02, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
I have a Bosch Exxcel washing machine which is great but it bleeps for ever and a day when the wash is finished. How do I silence the beeps without having to get up?
Switch machine on but do not program.
Press and hold PREWASH button.
After a few seconds it begins beeping.
Keep holding PREWASH button in until beep gets quiet
then eventually stops.
Hope this helps - Colin, Billericay Essex
Apr 11, 2010 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Whirlpool dishwasher stuck on prewash cycle
the eprom memory is brocken,the main board must be changed.
Feb 14, 2010 | Whirlpool 24 in. ADG7952 Built-in...
Motor starts but no water entering dishwasher
TRy priming by putting a jug of water in bottom of inside of dishwasher
Mar 04, 2009 | Westinghouse Dishwashers
Flashing lights on Hotpoint FDW20P Dishwasher
No solution! tried resetting to factory defaults but ended up that even the drain pump stopped working. after flooding the kitchen (nearly). I decided it was terminal and am loking for a new dishwasher urgently as I type. Cheers.
Feb 18, 2009 | Hotpoint 24 in. DWF32P Free-standing...
User Manual of Asea Cylinda 1200 Dishwasher
One of these was in my house when I moved in, still have the manual. Very efficient dishwasher.
A is a prewash (machine will stop after it). Manual says it's meant to rinse stuff while you wait until you've filled the machine to run a full wash.
D is economy wash. Water is heated according to the switch you select on the front.
C is a prewash that will continue on to D (normal cycle). Water is at incoming temp.
B is another prewash that will continue on the C etc (heavy cycle). Like C, water is at incoming temp.
E is dry cycle. Heating element is on/off depending on switch on the front (dunno why you'd turn it off..)
While turning the dial, push it in and it will stop exactly at the start of theach cycle.
Mine has stopped emptying, think the pump has died, looking for a replacement..
Apr 25, 2008 | Dishwashers
SMEG DI 612CA. Dishwasher
Pisss!!! Comin from my asss!!
Mar 04, 2008 | Smeg Dishwashers
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
Top Hotpoint Dishwashers Experts
AcmeUK
Level 1 Expert
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
