Question about Fujitsu AMILO PC Laptops
When I turn on my laptop the on button lights up and the fan starts but absolutely nothing happens. The screen still appears off. The laptop has been working perfectly so not sure what might be wrong.
    Sergeant:
  • 238 Answers
1. Check your power cord & adapter.
2. If its working then check the battery, reseat the battery & check.
3. If available then check with another battery
4. If no, then remove the battery & switch on the PC in AC mode.
5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
7. If still no display, connect an external monitor, check if display is comming.
8. If Display is coming then your LCD need to replace.
Posted on Aug 21, 2010
  • Colin Mar 19, 2011
    The lights come on so 1-5 are irrelevant. From my knowledge of FS laptops it could be the graphics chip. Or if there's an EXTREMELY faint image on the screen, maybe you need a new inverter or screen cable
I switch the power on power light comes on fan starts as if to boot then nothing, no screen and no keyboard lights
Does BIOS messages appear, or is the screen absolutely black?
If you see BIOS messages and then black screen, you should go to BIOS and choose your boot devices correctly. If there is no screen do the following tip:
1) Turn off the laptop.
2) remove the battery.
3) click and hold power button for about 30 seconds to discharge the circuit from motherboard.
4) then install the battery again
5) and click power button.
See what happens. In many cases it helps.
If there is still black screen, you should check your laptops RAM. In many cases removing and then installing back the RAM helps.
Oct 19, 2013 | HEWLETT-PACKARD HP 630/P6200 Notebook
Acer Aspire One NAV50 screen blank
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Oct 07, 2012 | Acer Aspire One Netbook
Toshiba M305D S4830 laptop wont start
"I have M305D S4830 laptop. I put it to sleep in the night. In the morning when i tried to turn it on, it wouldnt start. The light on the switch turns on and it charges the battery fine, but no HDD activity(but it does spin up and stay), no screen, nothing. The fan turns on and then turns off in 1 sec and then just the power indicator lights stay on... i also checked cmos battery, removed it and put it back.its voltage is also fine..."
Hello PPL! Maybe this WILL HELP you! I HAD absolutely the same problem >> 3 months of god **** stress, didn't find any solution, till one day i found on my Recovery CDs one note!! >> It sounds like:
"BEFORE pressing power button, HOLD 'C' button and while Holding 'C' button push POWER Button ONCE!! to start Laptop, KEEP Holding 'C' button!!! untill appears TOSHIBA screen!" then release 'C'. After that, it will appear "Operating System not Found">>then just do a restart by pushing Power Button and Start again! For me, It Worked!! and i'm god **** happy now)...let me know if it Helped you, Good Luck!
Feb 04, 2010 | Toshiba Satellite Laptop with AMD Turion...
Power light is on, and nothing happens.
The RAM may have been "jammed up" when it was put to sleep. You said you powered down completely and then started up again. How long did you leave it before turning it back on? Try it again, but this time, unplug the adapter from it and also take out the battery so there is absolutly no power going to it. Leave it like that for about 5/10 minutes and then try it again.
Hopefully that will help you out
Sep 23, 2009 | Toshiba Satellite A60 Notebook
When I press the power button to turn the computer on, nothing is displayed on the LCD screen. Power light, Hard Drive light, and Battery Light all appear normally. I hear the fan blowing internally and...
Check the resolution of the screen by right clicking on an empty part of the screen and choosing properties. Go to settings and make the resolution 1078 x 768 and hit apply and ok. There are instances when the resolution will change from a software update etc. that is not supported by the monitor or graphics card.
Sep 03, 2009 | Dell Inspiron 1525 Laptop
My laptop (Compaq Presario v2000) won't seem to boot up
Remove the battery. Plug power cord in. Turn on machine. Does it boot? Replace battery.
gurutim
Mar 17, 2009 | HP Compaq Presario V2000 Notebook
Dell loptop wont turn on
take out ur batteries, clean the terminals with spirit or light alcohol, then re-insert it. better u use direct power supply but be sure to check that the power is beig supplied and the terminals/sockets are cleaned.
did this helped u. if not, tell me, when u push the power on button of ur notebook, does anything happens, like the fans start spinning or light went on. does the screen turn on or does something appears on the screen?
if nothing is happenng after pressing the power button, then this is a clear case of problem with ur power recieving section of the notebook. go to your pc dealer.
Jan 03, 2009 | Dell Inspiron 6000 Notebook
Fujitsu AMILO PC Laptops Logo
144 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
