I have a Honeywell oscillating quiet cooling tower fan that was bought two years ago. Loved it, till yesterday it just stopped working. the oscillating feature still moves, but the fan does nothing. the buttons still beep and turn on and change while plugged in, and it sounds like something is working...but obviously not everything cause the fan doesn't fan. Is it fixable? Should I send it to the manufacturer? Or just eat the cost and buy a new fan?
  • 828 Answers
Could be fixable but until someone determines the problem there is no way of knowing if it is fixable. Could be a broken wire between the selector switch and the motor or the motor itself could be bad.
When you are trying to operate it does the fan motor get warm or hot? Does the fan turn freely?
Posted on May 03, 2008
Wind chaser fan motor not working
Hard to find parts. Could contact manufacturer, but might not be cost effective.
Sep 21, 2012 | Windchaser Ionizer Tower Fan with Remote...
I just bought the Honeywell Quietset 8-Speed tower fan (black and silver on top). I installed it correctly but the fan is extremely loud and squeaky and can hear the inside pole that rotates the fan, even...
STOP! Before you take anything apart, turn fan upside down and find the large plastic "screw"(cord passes through it)that secures the fan to the pedestal. Is same color as unit. Loosen it and see if squeaking stops. Worked for me!
Mine was driving me nuts and I was prepared to return it to store.
Aug 30, 2011 | Honeywell Comfort Control Tower Fan -...
Bought a 36" oscillating tower fan model FZ10-9LR
this happen to me one i just went in bought new fan took the good remote out and gave them back the bad one brought it all back and got my money back.good luck
Aug 05, 2011 | Hampton Bay Dryers
Hello i have the Honeywell Quietset 8 Speed Tower Fan. We purchased it from target last summer. It was a great working fan, loved how lightweight it was and it was extremely quiet. Not too long ago it...
The cord has a fuse at the plug. Check the fuse it could be blown. To access the fuse there is a slide open door that is about 1" x 1/4" on either top or bottom of the actual plug.
Jul 07, 2011 | Honeywell HY-048BP Tower Fan
My oscillating fan has stopped oscillating how can i fix this
pls check first if the mode was properly set, or if not follow the manual you own from the first you bought the item. or try to unplug the item and open the back panel look if the gears is loose or broken.
Jun 30, 2009 | Black & Decker BDTF1010B Tower Fan
Squeak in aloha breeze tower fan model 05538
If the model is equipped with a fan, and the noise occurs even when not oscillating it must be a fan/blower motor. If it is a squeak. A squeal could be an electical component going bad which is always bad. I would definitely take some bottom drawer tools , ie. screwdrivers and WD-40 and oil that squeaking motor. Being a fan it goes through alot of air pollutants. That tends to build up on the shaft and can work its way into the bearing seal. Good luck.
Jun 28, 2009 | Tower Aloha Breeze Fan
Bathroom ceiling fan has stopped working
remove the switch and test it with a meter on ohms or remove the switch and disconnect the fan wires and connect the fan wires to an extention cord to test.
Phil
Jun 09, 2009 | Honeywell L4064B2236 Fan/Limit Control...
LASKO fan problem
Check for a loose wire in the wiring harness
Sep 01, 2007 | Lasko 2530 Elite WindTower Fan
Heating & Cooling Logo
255 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
