Question about ViewSonic VX2835wm Monitor
Viewsonic vx2835wm monitor, in DVI mode connection, altough getting signal from the PC(Other monitor connected and tested for graphic card problem-No graphics card problem!!) , Prompts "No input-signal" and gets into power saving mode in 1 second (With Start button turning into yellow from blue), then start button doesnt light, and after 1-2 seconds tries to reopen itself and loops this sequence.This loop ,takes 2-3 seconds.. In trying the analog input connection with the Graphic card with the other cable that comes with the box, this time Monitor shows "Full blue screen" . If the monitor is tried to be started "not connected with PC", the previosly mentioned states also doesn't change.. During the times i connected the monitor with the analog (cable)connection normally, if I tried to open the monitor without opening my computer, The monitor showed "no input-Signal" and went into power saving mode with start button turning into yellow from blue color..
3 Suggested Answers
  • 644 Answers
SOURCE: viewsonic vx2835wm monitor, in DVI
You will need to change the resolution of the screen on the computer to 800-600 and the bit to 24bits or 16bits, to do this right click on the windows screen, and click properties, goto settings.
You should see a slider at the bottem left of the screen to adjust the resolution, and a drop down bar on the other side for the bit rate. This should solve the problem, also you could open the scond screen also in the display properties, and drag what you need to see on the screen to that screen, you will know what i mean when you open screen 2 it just expands the desktop. hope this helps.
Posted on Aug 21, 2010
  • 286 Answers
You are having a firmware issue or the main board is bad. Since you cannot get the monitor to work from either connector, and since this is a high resolution monitor, I doubt you are having any operating system issues. You can test the monitor on a laptop or another computer if you desire, however from the symptom it looks like the main board requires some attention. Contact Viewsonic at viewsonic.com or call their 800 number for service information. You could order a main board, but it may not have the ddc data programmed (similar to firmware) so you may have to bring it or send it to a shop for service. BTW, they have three year warranties. I would recommend calling Viewsonic.
Posted on Dec 17, 2010
How to switch from analog to digital mode
Any contemporary monitor is able to switch analog/digital mode automatically if connection from signal source to monitor is set up properly.
Connect digital output from your graphic card to DVI input of the monitor. Disconnect any other signal cables from monitor and switch on both devices (PC & monitor). Wait a while. Monitor checks its inputs and a activates digital DVI, because it is only one active input on it.
If none picture excluding error message of monitor is displayed, go through these steps:
1) Check whether your monitor is set for automatic input selection. If monitor buttons have no response try to use analog input to activate screen (any picture, desktop background...) and then get monitor menu access by pressing menu button.
2) Find out what connector type has your graphics card in PC. Possibilities are: DVI, HDMI, DisplayPort and some their options. See Wikipedia for connector look if you are not sure.
Remember that blue D-SUB (VGA) connectors are analogue and you cannot activate digital mode through analog VGA cable.
3) Use appropriate cable to connect monitor to PC.
Example: Your PC has HDMI output. Use HDMi-to-DVI cable. Your monitor input is DVI and common DVI-DVI cable is not suitable in case you have PC with the HDMI.
Note that DVI-to-DVI, DisplayPort-to-DVI etc. cables are available. You must buy right one.
Be aware that "Auto" button is inactive in digital mode of monitor.
Nov 18, 2013 | Belinea 1930 S1 Monitor
No signal ???????
I have the same problem in setting up two displays, a Dell as primary and a VA2223wm Viewsonic as secondary, both connected to an Nvidia geforce 9500 GT. I think it might be the cable, but it's baffling. I have one DVI cable that seems to work on either monitor, and either plug on the graphics card. The second DVI cable doesn't seem to work, but when it's connected to the Viewsonic, the Nvidia control panel detects the monitor as secondary, so I can change settings, etc., but the monitor still says no signal. Each monitor works separately when connected with one cable, but not with the other.
Thoughts?
Jul 23, 2013 | ViewSonic VA2223WM 22 inch Monitor
No monitor signal on my m2n-vm dvi after installing my new graphics card asus en210.The graphics card was tested on my other pc and works fine..any help?
First boot the computer without connecting Graphic Card, then go to BIOS and find for VGA option change the option to compatible mood, save the setting and come out of it. now off the computer re connect your graphic card and start the computer.
Aug 15, 2012 | ASUS M2N-VM DVI - Motherboard - micro ATX...
If i connect the DVI cable to my Video card (9200 family)and to my monitor an Asus VH222H i get a dialogue box saying no DVI signal. if i use the VGA cable everything works fine.Does this mean the card...
Make sure your monitor is set up to recieve what ever signal you are wanting via the monitor's menu. There should be an input button on the monitor to select the signal type. The connection really doesn't matter as long as you are able to use the monitor. There could be something wrong with the connector on the video card. Also make sure you are using the card and are not using the onboard graphics connection by mistake. If the problem persists it is more than likely the card.
Oct 27, 2010 | ATI RADEON 9200 Graphic Card
Viewsonic vx2835wm monitor, in DVI mode connection, altough getting signal from the PC(Other monitor connected and tested for graphic card problem-No graphics card problem!!) , Prompts "No input-signal"...
Aug 21, 2010 | ViewSonic VX2835wm Monitor
VGA connection works, DVI does not
Everything seems perfectly normal...
When you connect the computer to the monitor via an analog VGA cable, you get signal on the analog input.
When you connect them via a DVI cable, you feed the monitor's DIGITAL input, so the monitor doesn't get any signal on it's analog input, and informs you about it.
You have to select the digital input from the monitor's On Screen Menu, and then start the computer up - you should see the picture OK.
Also remember to set the display resolution on your computer to match the optimum (native) resolution of your monitor - this will give you optimum picture quality. In case of VA712B it will be 1280x1024.
Good luck and please come back with a testimonial if helped.
Jan 24, 2010 | XFX GeForce4 Mx440 (64 MB) Graphic Card
"No signal detected" when LCD connected with DVI-D Cable
Thank you for providing your configuration details.
You have failed to specify wheather or not your LCD Display is under Warrenty.
Perhaps these simple trouble shooting procedures will get the job done.
1. use the DVI to VGA adaptor that came with your card
Plug in a regular CRT monitor to the Primary Display Output Port using the DVI to VGA adaptor
( either port can be designated as the primary by you )
I like to use the Port nearest to the motherboard as the Primary
2. plug in the your LCD monitor on Secondary Display port using your DVI cable
At this point you should be able to see your desktop on the Primary CRT Display
3. Go to the display properties and use the Nvidia Dual Display Setup Wizard
set both desktops to CLONED at a resolution of 1024x768 and set the refresh to 60Hz
which is default for most LCD displays , some have higher refresh rates , consult your user manuel
If the display resolution and refresh are set incorrectly for your CRT or LCD you will see
Signal Out of Range ( if the display has the ability to display that error message )
At this stage both displays should be showing a Windows Desktop
If you now see your desktop on both displays , you can now put the LCD on the Primary Port
No Signal Detected ( this means the display device is not receiving a signal )
If your LCD display is still displaying the error message
"No Signal Detected" after performing the trouble shooting proceedures
You may need to read the user manuel about how to enable DVI signal input.
If you are certan you have done everything correctly but still see only "No Signal Detected"
Your LCD Display may need replacement
Loch Hime :-)
Sep 14, 2008 | BenQ FP71E 17" LCD Monitor
DVI connection fault
I had the same problem, you must call Viewsonic to change your screen. The DVI input on the screen is dead.
Jul 08, 2008 | ViewSonic VX2255 Monitor
VG910s not recognizing DVI input
Graphics card need setting to DVI out put Check your manual
May 16, 2007 | ViewSonic VG900 19" Flat Panel LCD Monitor
Ati radeon 9600 video card
what you have the ATI card hooked up can you see the boot screen? If you can see that you might want to try going into safe mode and making sure your graphics settings aren't set beyond the capability of your monitor. If you can't see the boot screen then your card might be dead.
Apr 28, 2007 | ATI Radeon 9600 Pro 256MB DVI+CRT+TV 8X...
ViewSonic VX2835wm Monitor Logo
142 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
