Question about Singer 5050 Mechanical Sewing Machine
How do I fix a timing problem with my singer sewing machine? The needle thread will not pick up my bobbin thread.
  • 1 more comment
  • Anonymous May 12, 2008
    unable to get bobbin case back in
  • grazia_slick Jul 19, 2008
    the thread is not picking up to make a stitch. I dont know what to do
  • Anonymous Mar 23, 2014
    How to thread the sewing machine needle
  • 30 Answers
Here's how you set the timing od the Machine alright:
1. Take the side plate off, take the needle plate off.
2. Take the presser foot off, and put a new needle in the machine. 3. Make sure that the needle is in the lowest position and look at the needle bar for the two timing lines. Locate the top line.
4. Then, turn the handwheel toward you until the top line is where the bottom line was.
At this point, the tip of the hook should be directly in the scarf of the needle.
This should set the timing of the machine perfect....
Posted on Jan 05, 2009
How to set up 5050 sewing maching
Posted on Mar 20, 2011
I am having a problem with the needle staying threaded. As soon as I start to sew it comes unthreaded. I have never had this problem before. Does anyone know what it could be??? It is a singer 5050.
Posted on Jan 20, 2009
My singer zig zag model 737 keeps getting jamed wher the needle is actually that thing under the needle it works for like 5 seconds then makes this jjjjjjj sound can someone plz help thnx
Posted on Jul 02, 2008
I am having a fashion maker rotomatic Singer 974.it has developed a fault the bobbin shuttle is not operated .i checked &found that the teeth of bevel gear operating belt shaft is broken.how can i get it repaired.
Posted on May 04, 2008
3 Suggested Answers
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
  • 1788 Answers
SOURCE: I have an old singer sewing machine 401A. The top
You can download a manual for $10 at www.sewingmanuals.com and it should help you. A couple of suggestions though, is your needle inserted correctly? Flat side facing the rear of the machine, fresh needle? Threaded correctly on top and bobbin area? Is your thread good not too old and the same type in bobbin and top? Did you leave a long enough tail in the bobbin thread? 3-4 inches which you hold with your left hand. Is the thread in the bobbin unwinding the right way? Are you turning the handwheel towards you, not away from you at least two revolutions or until you see the thread loop? Try these suggestions, and I am sure one will work unless your timing is off and it needs professional service.
Posted on Sep 20, 2010
Please share the symptoms of a messed up timing on a Singer Confidence sewing machine. Thank you in advance
A timing issue is usually demonstrated by the needle thread failing to pick up the bobbin thread. First, try installing a brand new needle as a bent/damaged needle will sometimes also fail to pick up the bobbin thread. You can search the internet for sewing machine timing or take it for service.
Dec 07, 2016 | Singer Sewing Machines
The bobbin thread will not pick up. How do I fix it?
First, install a brand new needle and verify that it is facing the correct way and it is the proper needle for your machine.
Confirm the bobbin has been installed in the bobbin case so it is unwinding the bobbin the proper direction as you pull the bobbin thread.
Six Common Sewing Machine Problems Solved
If it still will not pick up the bobbin thread, open the bobbin area of the machine and watch the needle action as you hand-turn the handwheel. You may see why it is not picking up the thread because the needle could be arriving too soon or too late to intercept the bobbin thread. If this is happening, the needle/hook is out of time. Take it for service.
May 11, 2016 | Singer 4423 Heavy Duty Sewing Machine
On my Singer 6235 sewing machine, needle will not pick up bobbin thread. Any suggestions to fix the problem?
Doesn't pick up bobbin thread
1. The bobbin may be in backwards.
2. The bobbin thread & top thread need to be pulled to the back before starting the stitching
3. You need a ballpoint rather than universal needle to sew on t-shirt knits.
4. the needle is in the machine backwards
5. Make sure the needle is the correct one for the fabric being sewed
6. Needle inserted wrong in the needle holder
7. Warped needle
8. Warped bobbin
9. Also could be a timing problem
Mar 01, 2016 | Singer Sewing Machines
How do you time a hd110 singer sewing machine
Be sure to try a brand new needle first. If it still doesn't pick up the bobbin thread, then it possibly is out of time. Search for: sewing machine timing.
Jan 18, 2014 | Singer HD-110 Mechanical Sewing Machine
I own a Singer 258, the needle does not pick up the bobbin thread
is the needle the right one for the machine?
is the needle & thread correct for the fabric?
it's possible that the machine is out of time & would have to be retimed by a sewing machine shop
Apr 02, 2012 | Singer Sewing Machines
Threading bobbin for singer 8734
NEW MACHINE, THE NEEDLE WON'T PICK UP THE THREAD. WHAT WRONG?
Jan 11, 2007 | Singer Drop-In Bobbin 758B-28BH Mechanical...
Singer 5050 Mechanical Sewing Machine Logo
1,017 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
