Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Where can I find the model # on my Kenmore Quit Guard?
  • 4,323 Answers
Hi
To locate the model # for your dishwasher, you'll need to look at the following places---
You'll see a model tag number, on that you would see the model number--
Hope this helps....
Daniel
Posted on Aug 21, 2010
My hp Pavillion dv6 laptop can no longer use Constant Guard which Comcast supplies. Also Quattro Pro quit working midstream. How do I fix it?
More then likely running System Tuneup replaced critical files that Comcast Constant Guard and Quattro Pro uses... I recommend doing the following three steps but only if you have the Original or backup copies of the installation disc/media for both applications: 1) uninstalling the Comcast Constant Guard application 2) then do a normal shutdown and reboot once it has rebooted 3) install the Comcast Constant Guard once that's done and successfully do the same three steps but for the Quattro Pro application
Jan 02, 2015 | HP Pavilion Computers & Internet
Why is my kenmore ultra wash quiet guard blinking clean?
You can go to Kenmore's website, list your machine model and the
problem and you can get an answer. Usually you have to re-program
those machines every 400 hours. Hope this helps
Jul 06, 2014 | Kenmore 24 in. 17482 / 17484 / 17489...
Hi Ginko. I have a Kenmore dryer model 11086810100 that has some wires removed from inside. The only HOT I can find is the red wire. I have 2 wires that have femals push-on crimped terminals, but I have no...
Hi Robert.
Thanks for the pics. I operate in UK and color codes here are different.
From what I can see the wiring in your picture does not match the US standard either.
The thermal fuse for example should have two blue terminals, not red and blue. The thermal fuse wires goes on one side to start, and on the other to the drive motor through the broken belt switch (if present).
The wiring at the blower must be revised and done again.
Here a service manual covering Kenmore 70 series dryers.
http://www.applianceblog.com/mainforums/attachments/sears-kenmore/3298d1196129125-kenmore-dryer-model-110-86870100-wont-heat-ldrwp-checkpoints.jpg
There is a wiring diagram at page 25.
Here a picture showing correct wiring: http://www.applianceblog.com/mainforums/attachments/sears-kenmore/3298d1196129125-kenmore-dryer-model-110-86870100-wont-heat-ldrwp-checkpoints.jpg
See also the pictures in this blog:
http://www.satfix.net/showthread.php?931-How-Dryers-work.-Whirlpool-Inglis-Kitchen-Aid-Kenmore-Admiral-Roper
About the red and yellow cable, the only red yellow wire in the diagram operates the switch for the guard function. The wire becomes hot and powers the motor when the guard switch is closed.
Parts (including wiring harness and terminals) are available here:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11086810100/0582/0151200?pathTaken=&prst=0&shdMod=11086810100
Jan 02, 2012 | Kenmore Dryers
Trying to verify manufacture date for Kenmore Precision Quite Guard dishwasher with Model No 587.15262900 and serial No TH93845362
Niðurstöður 1 - 1 af 1 fyrir Kenmore Precision Quite Guard model no 587.15262900. (0,07 sekúndur)
Try that link Niðurstöður
  1. Trying to verify manufacture date for Kenmore - FixYa 16 Jun 2010 ... Trying to verify manufacture date for Kenmore Precision Quite Guard dishwasher with Model No 587.15262900 and serial No TH93845362 ...
    www.fixya.com/.../t5103865-trying_verify_manufacture_date_kenmore -
Jun 16, 2010 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Kenmore elite dryer - how do I turn on the wrinkle guard? if the light is steady - is that on? is the light for the wrinkle guard or the damp dry cycle. Why does the static guard light flash?
Head over to the manufacture's website.
Typically - they have a SUPPORT section that you enter your full model number in, and you can download the manual for free.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 16, 2010 | Kenmore Elite HE4 Electric Dryer
Suddenly stopped working - won't run on any cycle.
First check the electrical supply. I have seen dozens of dishwashers which did not have the hot wire connected tightly enough (inside the connection box behind the lower panel). Sometimes the loose wire caused the breaker to blow. If you have control lights but the dishwasher will not start it could be a bad door latch saftey switch. $10 part, cheap. Hope this helps, Ken
Apr 24, 2009 | Dishwashers
Air compressor won't build pressure
If this unit has what appears to be a pipe with fins on it , you may have a ruptured inter-cooler which will be leaking where you stated.
Mar 07, 2009 | Air Tools & Compressors
Kenmore built in dishwasher drain quit working
if it looks somewhat like a elongated and cropped figure 8 it is what we around here call a clutch drive. if it looks like a 6 point star, it is a torx drive.. Be aware, the screws holding the guard in place may also be holding the pump in place under the unit. if so removing the screws would allow the pump to fall off the bottom of the unit.
If the unit washes, the motor and pump are working (the same motor/pump that washes the dishes also drains the unit)
if the motor is not running during the drain cycle, it is most likely the timer or a connection to the timer
if the unit is not running at all, it could be the motor or timer
if the motor/pump is working, I would first ensure the drain line is not clogged (pump may be trying to drain the unit and forcing the water out were ever it can due to a blocked drain hose, this would explain the water on the floor. I have found that when a drain line is blocked, it is usually blocked where the drain hose connects to the drain pipe under the sink.
let me know what you find and we will Fix Ya.
clarkco
Feb 06, 2009 | Kenmore 15121 Built-in Dishwasher
Kenmore Ultra Wash Quiet Guard
That looks more like the serial number. Check again to confirm the model number.
Sep 09, 2007 | Kenmore 17252 Free-standing Dishwasher
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
91 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
