Question about Sega Genesis Console
When everything is connected as should be and switched on the sega does not appear to make contact with the tv set. the tv set is analogue and ha allways been used with the sega
  • 47 Answers
Hi the cables are know to become faulty due to age and wear. try replacing the cable but make sure you have tried to tune it into your tv first. There are now new AV cables on the market which suits some segas see www.gameoz.com.au for a large range of accessories for these old consoles
Posted on Oct 14, 2010
Sega mega drive with av cable
if your screen is black and you unplug the cable from the megadrive , does the screen go blue ? if so the machine is sending out an a/v signal to the tv and your problem lies with the game cartridge contacts being dirty or the contacts in the slot on the console being dirty , try cleaning the contact strip with some electrical contact cleaner on a cotton bud or small paint brush , hope this helps ,its saved loads of my games
Aug 10, 2012 | Sega Megadrive Black Console
How can I hook my sega genesis console to my Direct tv box?
Don't plug your Genesis into your satellite box. Plug your Sega into the back of your TV set. Get a Sega Genesis composite video cable. Run that cable from the mini-DIN connector on the back of your Sega to the RCA (yellow, red white) connectors on the back of your TV set. If you don't have any spare RCA connectors on your TV set, try a composite video switch.
Aug 20, 2011 | Sega Genesis Console
Trying to connect a Sega Genesis. I know it's connected properly to the place where the cable wire goes and then that is connected to the connector. What channel do I go to to play the games?
The input from the Sega wont be on any channel number - you need to select the correct input for the Sega using the "INPUT SELECT" button on the Symphonic remote control supplied with the TV. Switch on the TV the Sega, then press this button repeatedly until you can see the picture from the Sega.
- If you are using the sockets on the BACK of the TV, the correct input is "VIDEO 1"
- If you are using the sockets on the FRONT of the TV, the correct input is "VIDEO 2". You can also switch to the "VIDEO 2" input by pressing the "GAME" button on the Symphonic remote - if you still have it.
If you don't have the Symphonic remote, look for a button marked "INPUT" or "SOURCE" if you are using a universal remote.
If you don't have any remote for the TV, you will only be able to use the sockets on the front of the TV. You will then need to switch to "GAME MODE" by using the buttons on the front of the TV:
1. Switch ON the TV and the Sega;
2. Press the MENU button;
3. Press the VOLUME UP button to open the PICTURE MENU;
4. Highlight GAME MODE using the CHANNEL UP/DOWN buttons;
5. Set GAME MODE to "ON" using the VOLUME UP/DOWN buttons;
6. Press MENU again to close the menu
You should now be able to see the picture from the Sega. If not, check you have correctly connected the Sega to the TV. When you have finished using the Sega you will need to use the method above to switch game mode off again.
Hopefully, I've covered every possible angle. If you have a different Symphonic TV model from the one listed above (ST420FF), the method should be similar, but if you have any difficulty, please post back for further assistance.
BElectric.
Jan 16, 2011 | Symphonic ST420FF 20" TV
Hi i have a sega megadrive 2 and have only just got it out, but now have a Bush digital TV and the Sega is on (power) but I can't either locate the channel or am confused on how it connects up to the Tv to...
I think those have the old style RF connectors.A coaxial cable with a grey or black box in the connection cable.Plug the coaxial cable from outside into the RF cable.Plug the RF cable into the TV coaxial input(regular cable input).On the back of the Sega,there should be a switch for CH3 or CH 4.Put the TV on the appropriate channel.If the signal looks bad,switch the selector on the Sega and change the TV channel.If you do not have the RF cable there is a place that still sells Sega accessories,but not Sega.They must have contracted with Sega.If you need the site let me know.
Aug 02, 2010 | Sega Megadrive Black Console
Video but no sound on sega megadrive 2
Nothing wrong with the tv or the cartages or even how you hooked it up
its the wire that connects the tv to the console, these some/a waire broken on the inside.
gotta get another one, or find the brake and twist it around till they meat then put some duck tape or something around it to keep it in place
Apr 20, 2010 | Sega Genesis Console
Have just bought a hardly used sega megasystem 2 console but it doesnt seem to work. does anyone know where all the leads etc should go? thanks
Hi, Sega master system 2 are connected to your TV via an RF cable. One end is RCA which connects to your console the other end is Pal which connects to you TV's antenna inlet if your using the sega RF switch then the RF switch connects to your antenna inlet on your TV and you should have a RCA to RCA cable which connects the console to the switch. Please note these cables and power adaptors can in some cases be faulty. These console are manually tune to VHF-1 frequency so make sure your TV has this frequency. some do tune to UHF but most tune to VHF-1 if you need parts www.gameoz.com.au stock the a huge range.
Mar 20, 2010 | Sega Master System Console
I need help setting up my Sega Master System, I am unable to attatch it to the tv.
Hi, Sega master system 2 are connected to your TV via an RF cable. One end is RCA which connects to your console the other end is Pal which connects to you TV's antenna inlet if your using the sega RF switch then the RF switch connects to your antenna inlet on your TV and you should have a RCA to RCA cable which connects the console to the switch. Please note these cables and power adaptors can in some cases be faulty. These console are manually tune to VHF-1 frequency so make sure your TV has this frequency. some do tune to UHF but most tune to VHF-1 if you need parts or want your console modified to connect to a modern TV via AV inlets or S-video visit www.gameoz.com.au they stock a huge range.
Jan 30, 2010 | Sega Master System Console
On my sega genesis the picture wont appear on my tv.
i have had this problem before, one pin on the part that goes into the sega is broken
Mar 21, 2009 | Sega Genesis Console
Hi, Sega master system 2 are connected to your TV via an RF cable. One end is RCA which connects to your console the other end is Pal which connects to you TV's antenna inlet if your using the sega RF switch then the RF switch connects to your antenna inlet on your TV and you should have a RCA to RCA cable which connects the console to the switch. Please note these cables and power adaptors can in some cases be faulty. These console are manually tune to VHF-1 frequency so make sure your TV has this frequency. some do tune to UHF but most tune to VHF-1 if you need parts or what your console modified to allow it to connect to your TV's AV inlet or S-Video visit www.gameoz.com.au as they stock a huge range of Retro gear.
Jul 27, 2008 | Sega Master System Console
Sega master system 2 setup - can't get picture
most likely problem is that your tv isn't tuned to the sega - you can fix this by going into the tv menu and tuning it manually
Mar 31, 2008 | Sega Master System Console
Sega Genesis Console Logo
69 people viewed this question
Top Sega Video Game Consoles & Games Experts
Josh Whitehead
Josh Whitehead
Reggie brown
Frank Zabroski
Frank Zabroski
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
