Question about McCulloch Garden
I have a 35cc 14in chain saw. It runs intermittenly. While running it's fine, but then stops and is difficult to restart
  • 260 Answers
Check the air filter for debris, and clean it. If the saw has been stored with fuel in it, the carberator may be gummed from old gas. You can try some carberator cleaner spray , or the carb may need to be dissassembled and further cleaned out.
Posted on Aug 21, 2010
What is the ratio for a 1635a 16" 35cc 2 cycle gas powered chainsaw
a really good guess would be 40-1 not knowing mak
of saw . he owners manualt
Oct 05, 2013 | McCulloch Mcc1635a 16-inch 35cc 2-cycle...
Have a mac 3516 35cc the carberator is way out of adjustment where do i set idle and gas adjustment screws at
I have always found that a good place to start was to close both completly shut then open 1 1/2 turns. On idle adjust to where it will idle good and chain is not moving. At run speed adjust slowly to where it runs the smoothest at max R.P.M.s. Hope this helps.Thank you.
Dec 21, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I have a McCulloch 35cc 14in chain saw. It has given good service but now runs intermittently. When it stops it is hard to restart.
in the gas tank is a filter. you can use a clothes hanger to fish it out, remove it blow it it out backwards with air . or replace it. if this don;t work buy new fuel lines ,carb kit,carb cleaner spray(parts master #1736 my fav) and a new spark plug. when doing the carb just replace gaskets and diaphragm .. don't worry about all the other stuff in the kit, you are just washing the carb to get gunk or dust out of it .. all back together and wa la.. ning ning niiing.. back in biz.. one other thing that goes bad is the crank shaft seal( the 1 next to the clutch) and it can be a pain to replace ! vote if'n i was of help.. remember BUY USA MADE PRODUCTS.. Jay
Aug 21, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I have a Mcculloch 16in maccat 35cc chain saw
Does the chain turn freely by hand? Is it being oiled properly? Check the fuel filter, air cleaner, and muffler for plugging. Does 'feathering' the choke make any difference? If it helps, try turning the H jet needle CCW about 1/4 turn which should make it run more rich and 4-stroke until you are cutting which should immediately cause the engine to 2-stroke. Hope some of this helps!
Jul 21, 2010 | McCulloch Garden
Chain saw chain stopped moving
Was it running and shut down and was froze or when you went to restart it was frozen? Two things I have seen cause this other than a seized engine. One - chain bound up. Remove side cover and inspect chain mechanism. Two- the pull cord is bound up. Remove the pull cord cover and inspect.
Jun 15, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I have a McCullough 3214 chain saw about 15 yrs old. Has started leaking bar chain oil...apparently oil is not getting to bar. Can this be fixed by just removing the bar and cleaning or should I expect a...
Very good advice from Drallim - it usually is. One more thought if the saw has separate "Guide Bar Plates", they can be installed incorrectly and cause this. I know because I have done it.
At first glance they appear the same, they are not. 430892 has a slot cut that aligns with the oil slot of the saw case. 430893 has no oil slot and fits against the clutch cover. There are some extra parts shown, please ignore these.
An IPL (exploded parts list) for your saw can be found here. I find them invaluable for assembly/dissemble. http://www.ordertree.com/modelinfo/MCC/Chainsaws-32cc-35cc/139.Chainsaws-32cc-35cc.1.59.1.html
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 21, 2010 | McCulloch Garden
What is the fuel mix ratio for a homelite chain saw 3300 14in.
50 to 1. try to find non ethanol fuel to run in it also.
May 15, 2010 | Garden
I NEED A ASSEMBLY DIAGRAM FOR A 3200 SERIES MAC CHAIN SAW.
I cannot find any 3200 series IPLs. Individual models can be found here:
McCulloch IPLs
http://www.ordertree.com/modelinfo/McCulloch/139.59.html
This isn't very detailed I'd use the individual drawing.
https://www.dixiesales.com/ipl/327/Chainsaws_32cc-35cc.pdfIf this is a Chinese Mac (MTD) they are very difficult to work on. Most saw shops will not repair one. GL
Lou
Oct 23, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Homelite chain saw difficult to restart after refueling.
Are you pumping the primer till it's full first?
Mar 09, 2009 | Homelite Garden
Husqvarna chain saw starts and runs for 20 minutes then stops.
two things could be happening.......first is vapor lock......make sure you breather tube is clear and working........next is ....it could have a bad ignition coil on it.....after the coil gets hot the spark can become irratic or just not work any more.....
Feb 21, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
48 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
