Question about Sunfire TGA-7200 Amplifier
I have a Lexicon MC12 HD EQ connected to a sunfire TGA 7401. speakers: L\R sunfire CRS-3 Center CRS-3C Surround CRM-2BIP sound is low even on 0dB gain on the LExicon. and there is an electric static crackling noise coming out of the sunfire power amp (Not Speakers) and the crackling noise is related to the content that is played. what could be the main reason for that and how can i fix the volume problem.this doesnt feel like 400w/Ch at all!!! i have the lexicon connected to 220v and the sunfire to 110v. Sunfire sent me a replacement after damaging the first one. when i damaged the first one, i opened up the power amp to check the damage.and noticed that each output board had 4 fuses. on every board, the same two fuses were blown as well as two transistors. sunfire replied to me and said that the cause of the damage was a ground loop! if so, how can i prevent damage to my replacement amp?
  • 3 more comments
  • omar991 Aug 22, 2010
    thanks for the info but how do i ground my equipment in the way that prevents a ground loop?
  • omar991 Aug 23, 2010
    what is the best way to ground the system in order to avoid a ground loop?
  • omar991 Aug 24, 2010
    how do i check the speaker with an OHM meter amd possible continuity with ground? and what should the meter read??
    your quick response will be greatly appreciated.
    Yes I have tried the RCA connection. Same thing. If u have an email I can send you a detailed system diagram with the connections and everything. It will give u a very clear idea about the system.
    And please provide more details on how to test ground loop and voltage on amp chasis. As well as steps for testing the speakers with a multimeter. Because a I'm suspecting that the center speaker is damaged. Because sound is not clear from it and it's much lower volume than the other ones although all channel gains are the same
  • 10,865 Answers
Hi Omar. In an electrical system, a ground loop usually refers to a current, generally unwanted, in a conductor connecting two points that are supposed to be at the same potential, often ground, but are actually at different potentials. Ground loops created by improperly designed or improperly installed equipment are a major cause of noise and interference in audio and video systems. They can also create an electric shock hazard, since ostensibly "grounded" parts of the equipment, which are often accessible to users, are not at ground potential. Take a few minutes to inspect your entire system. If you are not really into the technical aspects of your system, call in a pro as this problem will continue to haunt you until it is found and fixed. J.
Posted on Aug 25, 2010
  • 5,807 Answers
Any updates on your connections?
Have you tried reconnecting the Sunfire using the RCA and
not the XLR , just for troubleshooting?
Please post to help you further.
Posted on Aug 24, 2010
  • 35 more comments
  • Rommel Cana
    Rommel Cana Aug 24, 2010
    talking about Ground Loop?
    Measure using Voltmeter , if you can read voltages on each amp chassis with respect to ground it
    is bad.
    • Speaker will be later, you have check on it already , but we will go there don't worry
    After multimeter reading in ohms, it should be done actual to find the right phasing.
  • Rommel Cana
    you will also need to post what " source " you are using at the moment
  • Rommel Cana
    Ground Loop is two folds,
    One from the grounding and one from your Input grounding and phasing.
    • Indicate what AC source are you using for 220V?
    and your regular power line AC , Is it Normally 220V or 110V.
    • Please also indicate how it is connected.
  • Rommel Cana
    here are scenario 1,
    If your Normal Line is 110V , you need a step up for the 220V unit.
    Scenario 2
    If your Normal Line is 220V , then you need a step down transformer to 110V unit.
    • Please indicate , if your Units have three ( 3 ) prong plugs ( ground included )
    Or you are just using 2 conductors on each.
  • Rommel Cana
    • You may need to check also your XLR connections later , if you can attain a good quality
    sound using the RCA ( basic ) connection.
  • Rommel Cana
    • RCA connection is just to confirm if your XLR connection is OK.
  • Rommel Cana
    • if there is a large difference using RCA and XLR then you may need to interchange wiring on the
    Balance connections.
    • You might need to do it , One channel at a time ,.on each to confirm
    To find which channel are producing noise like you mentioned before.
  • Rommel Cana
    there are devices that can be installed on your Unit for Ground loop,
    Most often you can find one on your Cable provider.
    It is just for the purpose of isolating the ground on each, I also believe Sunfire have also.
  • Rommel Cana
  • Rommel Cana
    here is your guide:
  • Rommel Cana
    here are additional info about Ground loops:
    http://en.wikipedia.org/wiki/Ground_loop...
  • omar991 Aug 25, 2010
    my cideo source is a Lexicon bluray player connected to the Lexicon preamp through an ACCELL HDMI extender.
    sunfire power amp has a 2-prong power cable. Lexicon has a 2-prong power cable. Liberty XLR interconnects.
    in our country, we have both 110v and 220v. i have dedicated a 110v 15amp power line to the sunfire. and the lexicon is connected to a different 110v socket.
    i have also tried lifting the grounds from all equipment and connecting all equipment chassis with a ground cable in parallel then connecting the cable directly to the ground of the wall power socket. (wall socket has ground by the way, i have tested it) but still same problem.
    question: what if one of the speaker was blown or damaged. could this cause this problem> and could this damage the amp?
  • Rommel Cana
    Rommel Cana Aug 25, 2010
    you can send the image to premiumexperts@fixya.com and instruct them to send to palaboy
    give also the details on your XLR connection ( balance )
  • Rommel Cana
    We may have to measure first, if there is substantial voltage on the chassis of the Sunfire
    Amp ( without anything first )
    • If there is none, proceed with connecting the Lexicon then measure again, as long as there is
    no substantial voltage , proceed with the 'Source ".
    While there is still no substantial voltage , then it would be safer electrically speaking.
    • Here is what I want you to do, try to locate and identify what channel ( Sunfire )
    is always producing a weak sound .and damaging your fuse .
    have a note on it , and temporarily substitute ( that channel ) it with other speaker .
    • Do not play the Amp loud, just for you to have a nice listening level.
    Monitor again , if that channel still producing a weak audio .
    If it does , we may have to :
    a ) exchange the XLR cable with other XLR cable.
    If problem still persist ,
    b ) we may have to modify ( just for that Lexicon Output only )
    the XLR phasing just to compensate for the missing good audio that is supposed to be
    producing on your Sunfire Amp.
    or try
    c ) using an RCA connection
    and post what you found.
  • Rommel Cana
    If it is on the Center Speaker, do what i have posted above ,
    • Locate where it is connected ( marked that channel , Sunfire ) and have a note on it.
    these would be called project 2 Center Channel
    • if project 1 Chassis Grounding seems OK
  • Rommel Cana
    • Please also be informed that Chassis Ground , differs from Signal Ground ( XLR or RCA )
    These works differently.
  • Rommel Cana
    Here are additional guides:
    Troubleshooting
    Measure also the Resistance between the chassis of the Sunfire and the Signal Ground .
    How to use a multimeter
    I have been testing the speakers with a multimeter to check for any damage. As you know I'm using a sun fire CRS-3C for center. The Speaker has 2 binding posts. 1 for the woofers and 1 for the ribbonhttp://sunfire.com/manuals/CINEMA RIBBON CRS3
  • Rommel Cana
    Rommel Cana Aug 26, 2010
    I hope the speaker are still OK,
    here are additional info :
  • Rommel Cana
    • After verifying the resistance ( actually it should be impedance ),
    you may need to check it on your other amplifier first.
  • omar991 Aug 28, 2010
    i was testing the sunfire speaker with the multimeter yesterday and noticed the following: the CRS-3C has a boundry switch at the back (Wall, Room). when switched to ROOM I get a reading of 3.3 Ohms, which i think is quite normal for a 6 Ohm speaker. but when the switch is turned to WALL, i get a reading of 42 Ohms which is very weird.
    do you think the wall setting damaged my power amp?
  • Rommel Cana
    Rommel Cana Aug 28, 2010
    from your comments:
    do you think the wall setting damaged my power amp? "
    Here are possible scenario:
    • Any amplifier can work for as long as impedance of the load is not below 4 ohms.
    Having 42 ohms is too way far from an impedance of 16 ohms ( max )
    Having 42 ohms will have low output ( as you can hear before )
    Driving it hard , would cause the amp to burst.
  • Rommel Cana
    • Having 3.3 ohms of 6 ohms is also far from Normal.( not good for amplifiers )
    these impedance ( speaker ) can also cause the Amp to work double time
    ( more current needed ) as used in a normal way.( may burst the amp also ).
  • Rommel Cana
    I will post more , while i search for specs and schematics for your speaker,
    if you have more details , pass it on , so we can work these out, a more
    interesting is the 42 ohms ? or have an image of wiring ( only if you can )
    to guide you further how to check in step by step ,details.
  • Rommel Cana
    from the binding post, ( 2 )
    you have a woofer and a tweeter.
    you can post impedance reading on:
    a ) reading for woofer only
    b ) reading for tweeter
    c ) reading for woofer and tweeter in parallel
  • Rommel Cana
    from the image here:
    Assuming each of speaker is 6 ohms impedance
    first two on the left in series = 12
    3rd and 4th in series = 12
    Having there ends in parallel
    would produce 6 ohms.
    • You may have to check four speakers individually
    3.3 ohms is very dangerous for your amp.
  • Rommel Cana
    you may have to get an image first or note , on it ( very important )
    on each of the speaker wiring.( speaker phasing )
    • you will need to disconnect either of the two terminal of each speaker.
    ( to test for impedance )
    • If all of it are OK ( impedance using the Multimeter ) then it could be on
    what you mentioned " Switch " ( could be bad )
    • Do not connect it to any amplifier until you got the right impedance ( total )
    on the four speaker ( in one box )
    i just want to know if a 6 ohm speaker reads 3.3 ohms on multimeter is normal or not. and the sunfire power amp can handle impadances down to zero.
  • Rommel Cana
    • about the ribbon tweeter it passes through a capacitor before it goes out
    might as well check on both.
  • Rommel Cana
    If it is a Fluke Digital Multimeter it is bad ( total speaker impedance )
    or you are referring to individual ?
  • Rommel Cana
    it can handle zero , but not for long .
    Impedance of speaker changes when it is being powered .
    Total impedence is 3.3. test was done on the binding posts of the speaker
  • Rommel Cana
    It also depends on how many power transistors are installed.
    MOSFET Power can endure , but not Discrete type ( but it depends also on the design )
  • Rommel Cana
    I would suggest take one woofer out and check , if it the same , post back
  • Rommel Cana
    Rommel Cana Sep 01, 2010
    • Impedance
    Speaker Impedance Explained - Ohms
    Speaker Impedance Matching
  • 15,935 Answers
Ground loop is caused by...
speaker wire hitting the basket of the woofer
grounded speaker wire
blown voicecoil
speaker leads (strands of wilre) touching opposite terminals at the amplifier.
Wire it all up EXCEPT the speakers - and check each speaker with an OHM meter for proper reistance and possible continuity with ground.
Thanks!!!!!!
Posted on Aug 23, 2010
  • 19,396 Answers
Hi.
Re:" the crackling noise is related to the content that is played.": That usually indicates that there is a fault in the preamp system, that would also explain the low dB in output but amp working (if it was the final, then no sound).
By the way, check grounding (earth on wallplug, bypass extension), and ensure there is no short in speakers connections (this must be done). If problem is an internal failure, as I suspect, then the unit must be tested at component level to find and repair the fault.
Posted on Aug 22, 2010
  • 12,061 Answers
This can happen for a couple of reasons, ground loops, can occur when the ground connection between components is removed before the other one, like say one unit was ON,and then another unit that was switched OFF was removed from the system, like removing the interconnecting Audio cable. ON should always turn BOTH units OFF before doing any work, this includes the Power Cable to which must be BOTH removed from the wall, to eliminate any chance of a "Potential Difference" between equipment,
Now in the old days... ALL The Component(s) were connected with an individual Earthing wire that was grounded to each and every unit, so in effect they were all Earthed together. More importantly they were all at the same Potential, and there could be NO current flow between units.This is used to prevent this from happening. However this still doesn't mean one can disconnect from each other without FIRST removing them ALL from the power, before doing so.
Now As to another thing you can do, is get yourself some things called "PollyFuses" these are used to protect the speaker, under normal use they are a short circuit, BUT when there is a short circuit, and over a certain current rating is exceeded, below the amps Max Power, the very quickly and spontaneously go OPEN CIRCUIT,and stay there until short is removed, and then reset themselves upon removal of the short. These are invaluable.
Below is all about pollyfuses.
http://docs.google.com/viewer?a=v&q=cache:ifxFg7gkZa0J:www.electronicsforu.com/EFYLinux/efyhome/cover/sep2004/PolyFuse.pdf+pollyfuses&hl=en&gl=nz&pid=bl&srcid=ADGEESjr8DrkcoewNOKqBk6KNvIUcD0pLbuUI-aQm-gIq6L7E2lzw94SxRATF0O29Y56skTYWXpWG-bLATlJBnxK2NVkAg_XIZG-XccMDcaccLbube_mTvYmHUA8WvBEEaoGXlG-ZZnz&sig=AHIEtbTsf6XU-PBdKSQYRxHeEKSZsaNGUQ
http://docs.google.com/viewer?a=v&q=cache:wBv51OQQSRoJ:www.audioxpress.com/magsdirx/voxcoil/addenda/media/seaandland.pdf+audio+speaker+protector+device&hl=en&gl=nz&pid=bl&srcid=ADGEESitCmB_73aTD49bnXcXXMPqABb1k-6244F8iItc6ypKyTofvpxKdp-58RK-tMr-1xFyzYh8ugNNu7qzpmajgPdc6-uExfiQvtLJSJ8qI3D9P5z9aCXnWWqLA_Ky4SVbuOnbeFf5&sig=AHIEtbQNS-mqIWMm5gBj32jHEXN6O4WFow
Posted on Aug 21, 2010
How come i can only adjust the volume levels on the center, surround sound left and right, and the sub, down but not up? is 0 max volume?
Some equipment use 0dB as the reference, and you can choose to decrease the volume from that point. If you need to "increase" beyond 0dB, you need to reduce volume on the main speakers so the volume is finally balanced between all speakers.
May 15, 2016 | Audio Players & Recorders
Trouble during the upgrad of lexicon MC-12
Try on a different computer , if it still get stuck at the same point bring the amp to sevice shop, they will reinstall the firmware
Mar 30, 2008 | Lexicon MC-12 Balanced Amplifier
Hey yesterday brought Samsung HT-550 home theater . my rear speaker voice is too low . i do settings & high the volume to +6 Db, but still same problem volume is too low . what is best EQ ? any...
The front speakers are the base against which you adjust everything else.
Adjust the front rear balance for 0dB.
Readjust the rest of the speakers using the test tones. Normal audio may not have a lot going on back there.
Mar 31, 2011 | Samsung HTC550 Theater System
Sony BDV-370 DVD/5.1 theater hooked to Sony Bravia TV and cable box. No sound comes from rear or center speakers with HD cable.
Three things can cause this:
1) not all HD is recorded in surround sound. You can very well watch an HD program that just has Left/Right stereo audio. Tombstone on bluray is even only in Dolby 2.0
2) wrong connection is used. If you only use red/white analog stereo cables you will only get sound out of the left/right mains.
3) setting on the cable box is set to stereo and not surround. Changing this varies by cable box manufacturer.
Mar 01, 2011 | Sony BDVE300 Theater System
Where can I find reliable, cost effective repair to my lexicon mc12 HD?
A place called "The Service Bench" located in Massachusetts is an authorized service center for Lexicon. Contact them.
Dan
Aug 21, 2010 | Lexicon MC-12 Balanced Amplifier
I cannot get 5:1 surround sound out of my PC
I am not quite sure if you are connecting the pc to a HD receiver or straight to a HD dvd player. IF you are connected to a HD dvd player only, you will need to connect your speaker to your PC to get the 5.1 sound. The sequences is Front speakers to the Lime port, Center and sub to the Orange port and rear speakers to the black port. Hope this helps you out. Good Luck
Franklin
C2Solutions
Jul 13, 2009 | Computers & Internet
Garbled / feedback sounds from powered subwoofer
The surround processing portion of the unit has a problem. In either stereo or direct mode, the digital procesing is bypassed. This could be just the surround processing IC, but that IC may not be available as a separate part. I would suggest that you bring this unit to an authorized Onkyo service center for an estimate.
Dan
Mar 18, 2009 | Onkyo TX-DS595 Receiver
Missing center speaker
Yes, you can connect all the other speakers and not have a center speaker. It will not damage the amplifier. But be aware, that many of the surround functions will not sound good without the center speaker. In just about every surround mode the center speaker gets more audio to it than any other speaker. It would sound better if you took one of the rear speakers and used it for a center speaker and have one rear speaker output no connected. The rear speakers get the least amount of sound going to them in all surround modes.
I hope this helps and a Fixya! rating would be appreciated. After all, it is the only reward we get for offering people like yourself free help. Most people never even bother to rate our free help here.
Thanks,
Dave
Nov 02, 2008 | JVC TH-M606 System
TX-SV525 Onkyo Receiver
NOOOOOOOOOOOOO!!! If you have the room for them to run free and loud, keep the 901's in service. Get them a good amplifier because any multichannel receiver can't deal with their special EQ needs and still drive conventional speakers for the other channels properly.
The good news. I have a setup similar to what I think you're trying to do and it works great! Get a receiver that has has 5.1 analog Outputs so you could drive up to 6 external amplifiers if you want to (I drive 4). Then you can draw off the Front L&R to a separate amp for the 901's and the 'other' (lesser) speakers can live on the receiver's native amplifiers.
A separate multi-channel amp for the 901's was my solution. Because I can run each channel independently to an external amp, I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers (DBX DB-SW 15's) and the Rear Surround channel (Bose 301), with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center (Kenwood 777's) and Surround speakers (Bose 301's) from its own amps.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Multi-CH Receiver L&R Audio Out ***) >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receiver's speaker level setup.
Any modern AV Receiver with the pre-requisite analog outputs should work. Since you have to buy a power amp for your 901 front channels anyway the receiver need not be a powerhouse. Look for features and lots of connections for digital and analog devices. I lean toward coaxial digital connectors because A) they take standard >> and cheap << audio cables; and B) they can be shared with Y-connectors if you're careful to have only one digital device turned on at a time. Optical SP/DIF is an expensive farce to get into your wallet.
For DVD/Cable Box/Blu-Ray look for multiple HDMI or component connections. Again, length and cable cost made me look at the component connections vs HDMI and I was pleased that I can't see the difference even with HD programming from my cable box. It's all great.
Feb 08, 2008 | Onkyo TX-DS595 Receiver
Poor voice track but great sound.
Unhook your center channel speaker and see if it still goes into protect.You might have bad center speaker
Sep 09, 2007 | Sony STR-V555ES Receiver
181 people viewed this question
Top Sunfire Audio Players & Recorders Experts
shaun taylor
woodzowl307
Are you a Sunfire Audio Player and Recorder Expert? Answer questions, earn points and help others
