Question about Refrigerators
Smoking, burning wires - Refrigerators
  • 828 Answers
Pull the plug to shut off power to unit or shut off breaker. This condition indicate a bad short circuit.
Posted on May 03, 2008
Smoke came from under fridge
When you let the smoke out of the wires, they don't work as well afterward! Sounds like a short and what was burning was wire insulation. The main components are the compressor and the fans.
Look for misshapen wires as that will be the best indicator of what has overheated.
Jan 03, 2015 | Refrigerators
Dodge ram engine smokes when stated and skips
What color smoke? Black is emissions related, blue/black your burning oil and white your burning anti-freeze. With the "skip" your REF to, you probably have a bad spark plug, wire, or bad cylinder and burning some oil or coolant. CK plugs , wires & do a compression test. Pressure test Radiator for head gasket leak.
Jul 04, 2014 | 2004 Dodge Ram 1500
Why does ovenstove vent smokes if baking is over 350
There is probably some built up grease in the vent and when it gets hot enough it burns which would cause it to smoke.
Jun 11, 2014 | Computers & Internet
Smoke come from motor and now drill hardly moves .is new motor required or brushes
You will rarely get smoke from the brushes on electric tools. Smoke is usually a result of either the armature or field coils getting hot enough to melt or burn the varnish insulation off the wire which results in a loss of or no power because of shorting in the windings. You'll have to replace whichever part burned the windings and find out what caused the problem or you'll burn the new part the same way the original burned.
Mar 01, 2013 | Drills
The bearings have been replaced but now it is smoking (mostly seems from the inside) and smells like the belt is burning, but the belt isn't hot. HELP!! :)
i think this washer has a heater with doing the bearing probably wires crosed over or damaged [heater goes on and no water smokes then ] ceck your wiring on the element green is ground.
Jan 22, 2013 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune frontloader washer smoking last few minutes of spin cycle
I need more information can you tell me if the smoke smells like rubber burning or if it smells like electricity burning like the wires burning?
Oct 01, 2012 | Washing Machines
Today there was smoke coming from under the radio buttons. I shut off the radio and the air and the smoke quit. when I got stopped and checked under the hood, nothing was melted but when I turned on the...
It sounds like the AC controls or the Interior blower fan shorted and the smoke you saw was the insulation melting off the wires. You need to get into the wiring under there and locate the burned wires. It won't be hard to identify which ones are the problem because they will be brittle and the insulation will be burned away.
Aug 12, 2011 | 2010 Dodge Avenger
Wires leading into voltage regulator started burning and smoking when trying a different battery. I think the voltage regulator started smoking too. Now I don't get Any spark or buzz even when I turn the...
You may have gotten the +pos and -neg cables crossed, causing the fusable link wire to burn out.
Check for the burned link wire between the alternator and the battery side of the starter solenoid on
top of the right fender well, and splice in a new fusable link wire, any parts store should have this.
The fusable link is there to protect the charging system from damage when things like this happen.
But once it's running be sure to check the charging system. Hope this helps.
Nov 17, 2010 | 1981 Ford F 100
Smoke coming from the bottom of refrigerator and burning smell
Unplugged , take off the back cover and check for burned wires or if the coil is cover with alots of dust could burn it and smell smoke.
Aug 28, 2009 | Frigidaire Refrigerators
Refrigerators Logo
53 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
