Question about Kenmore 24 in. 15252 / 15254 / 15259 Built-in Dishwasher
Kenmore dishwasher makes grinding noise while draining
Model 665.15789300 with food disposal
I think something may have fallen into the food disposal as the sound is similar to a spoon in the sink garbage disposal and the drain pump seems to still work (the water gets pumped out).
How do I check the disposal for foreign objects? Thanks in advance
Ray
    Genius:
  • 1,073 Answers
Disassemble the top of the dishwasher pump, remove the bottom spray arm and remove the screws on the top of the pump housing this will get you started
Posted on May 03, 2008
Why won't dishwasher drain ?
Good Morning Friend, thank you for your post!
I see that your Frigidaire dishwasher is not draining properly; this can be caused by many reasons. First, I would suggest checking the drain hose to ensure it has not become twisted or kinked. Even if the hose is not kinked make sure it has not fallen behind your dishwasher either as this can prevent draining. Additionally, you could check the filter at the bottom of the tub to make sure no debris has clogged the filter or disposal. Other than that the drain pump could be the culprit. If so, I would recommend a local authorized technician to come out and properly diagnose your dishwasher. I hope this information helps -Z
Jul 18, 2014 | Frigidaire FPHD2491K Builtin Dishwasher
Amana dishwasher makes noise
something is probably down in the drain dish washer has a disposal like system at the drain
Sep 03, 2013 | Dishwashers
Dishwasher hose is hooked up separtely from garbage disposal but still dishwasher not draining
Hi - Is the unit making a grinding noise? If so, contact a professional because you may possibly have a defective drain motor/pump.
Oct 13, 2012 | Frigidaire 24 in. PLD2850 Built-in...
Water wont drain
If the water in your dishwasher does not spray or drain properly, there are a number of things you can do. Start by giving your dishwasher a thorough cleaning and see if that helps. See How to clean a dishwasher for step-by-step instructions.
Next, consult the owner's manual for simple instructions on how to access and clean your dishwasher's filter.
Look where the dishwasher drain hose snakes through from one cabinet to the other. Does the hose look flattened or kinked? Do you see any sharp bends? If so, straighten out the hose with your hands and manipulate it so that it regains its rounded shape.
If your dishwasher drains through the garbage disposal, try running the garbage disposal for a bit to process and clear any food.
Does your dishwasher spray your dishes, but it does not advance to the next stage and drain the dirty water? The timer controls the start of the draining process. You may need an entirely new timer or a new motor for the timer. Repair service is recommended.
If you hear a humming or grinding noise, that's an indication that bits of glass, broken dish pieces, beans or seeds may be caught in the pump impeller.
For more troubleshooting steps and solutions, see Dishwasher not draining. I hope this helps!
Sep 20, 2012 | Kenmore Dishwashers
After completing the wash & rinse cycle the dishwasher won't drain
In my experience, in this case it is likely that your dishwasher is not draining at any time throughout the wash or rinse cycles. The overflow float is preventing your machine from overflowing.
Here are a few things to check:
  1. If this is a new install, or the disposal has just been replaced, make sure the plug in the disposal has been removed. The nipple where the drain line from your dishwasher attaches has a plug on the inner wall of the grind chamber from the factory.
  2. Listen to the sound of the drain motor by starting a cycle and then canceling after a few seconds. Make sure the drain pump is actually running and not just making a loud humming noise as if it is seized, or something is binding it.
  3. Finally, check your drain line from your dishwasher to your disposal (most common drain connection), or where ever your drain line connects. Slight kinks and sharp bends have a tendancy to collect debris and create a plug-up. If this is the case, simply take the drain line loose from the drain pump and from the disposal and take it an outside water faucet. Place the disposal end against the faucet and slowly turn on the water. It will usually blow the plug right out.
Apr 16, 2011 | Dishwashers
Grinding noise when first starts running after filling with water
Do you know if your dishwasher has a built in disposal to grind up food particles that end up in the water? Could be a problem with that, or maybe with the pump.
Is water being moved about with the arms spinning.
I would call an appliance repair shop with your model # to find out what they think.
Feb 14, 2011 | GE 24 in. GLD5500L Built-in Dishwasher
The last couple of months, taller glasses are not getting clean, have a food-like residue. No problems with other types of dishes. Tested water temperature, seems ok.
if your drain is connected to a disposal make sure the drain hose has an air break, the hose should be raised higher than the disposal drain connection, if not it will syphon food from disposal back into dishwasher, also if you have never ran cleaner through dishwasher that also may be your problem, the best thing that I have found to use is muratic acid, just a cap full with the unit empty
Aug 24, 2010 | Kenmore Dishwashers
Dishwasher makes noise during drain cycle
This really isn't a solution, but I found info on Whirlpool's site that the noise could be caused by the disposer and food or something in it. They said to use it a few cycles and see if the noise goes away, so that's what I'm doing. I always rinse dishes before going into the dishwasher, so don't really think there could be food particles etc. causing the problem, but we'll see. Not anxious to pay for a possible solution unless through a repair person. Thanks for your reply.
Jun 19, 2009 | Whirlpool GU3600XTSY Stainless Steel...
Water will not drain
check for dirty filter it's inside under drying element
Jul 06, 2008 | Kenmore 24 in. 15252 / 15254 / 15259...
Kenmore dishwasher
Mine eventually "fixed itself". I think some debris got caught and eventually (5 cycles or so) got ground up and sent through the drain. The noise changed each time it got closer "flushing out"
Apr 01, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore 24 in. 15252 / 15254 / 15259 Built-in Dishwasher Logo
961 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
