Question about Sirius Satellite Radio Receiver
Will not scan thru channels - when i hit the scan button it jumps to channel 159-161. The radio is installed in a 2008 Ford Edge
Push the aux button and move to sat1 or sat3 for full channel browsing.
Posted on Aug 31, 2010
  • 520rdl Dec 12, 2012
    I have same problem after battery replacement
    The web site said to run the diagnostics on the radio. They all pass and there was no change. I push seek and the channel jumps to 141 142 etc up to 147 then reverts to 141
While listening to my scanner every so often, does not seems to be a specific interval, maybe 3 or 4 seconds usually, I get a silent pause missing conversation. For instance the ambulance dispatcher might...
sounds like you have another channel set for priority and it is scanning back to check that channel. In the manual mode scroll thru channel's until you find one set with a "p" or "pri" on the screen. Hit the priority button and this should resolve the problem.
Sep 09, 2011 | Uniden SC230 Handheld Scanner
Oops, misplaced my manual for my Midland LXT walkie talkie radios. How do I get a specific channel to use. When I push the scan button it goes thru channels 1 thru 22 but how do I stop it on a specific...
bobduffy39,
Channels are selected by tapping the center button once then using the arrows. The next tap of the center takes you to the CTCSS, DCS, and other functions follow. When scanning simply tap the transmit button and it should stop on the selected channel. Channels 8-14 are FRS channels at 500mw. These are the preferred channels to use for most people. 1-7and 15-22 are considered GMRS and requires a FCC License. Many people have been known to use these channels without having the license. This form of pirating is not recommended. I have included these links which could be of help to you.
To find a PDF Manual for Midland LXT310:
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
To locate information on obtaining a GMRS license:
http://wireless.fcc.gov/services/index.htm?job=service_home&id=general_mobile
JTRadiojunkie
Aug 18, 2010 | Midland LXT310 2-Way Radio
Pro-96 Scanner: My pro 96 scanner says all channels locked and it ...
If there is no frequencies on your scanner it will lock all channels out. if all your frequencies are on one bank and you accidentally hit that bank number and turn it off it will lock out all channels. If that's the case just hit that bank no. back on and they will unlock.
May 17, 2010 | Radio Shack Pro-96 Scanner
How do i program my BC 55xlt uniden scanner?
To program:
Turn on radio.
It will be in scan mode. Press Manual (orange button) to stop scanning.
Press Manual button to step through channels to get to the one you want.
(Or press channel number and then manual button)
If "LockOut" is displayed it means this channel isn't being "Scanned."
Pressing Lockout will toggle the status.
To program:
Select channel. Use keypad to enter frequency. Use "E" for Enter
key. If the radio displays an E this means Error. Usually, the
frequency you typed in is outside of the capabilities of the scanner.
Once you hit the E you will immediately start hearing anything that's
out there on the frequency you entered.
Push the "Review" button and the scanner will display the frequency
that is programmed for the channel. A "-" will be displayed for the
decimal point.
Dec 04, 2009 | Uniden Radio Communications
Don't have a manual. i want to tune in the Fm radio. also how do you add video/movies to it.
to tune the radio you hit the play/pause button and scroll thru the channels with the toggle switch deally then to set the channel hold the play/pause button and it will bring up a list thing and you set it as a channel. to add videos ect. you have to do it thru your computer.
Apr 17, 2009 | Creative Labs ZEN V Plus MP3 Player
How to program a uniden bearcat bc 145xl 16 channel scanning radio
I'am having a problem. I do not have codes for a uniden bearcat 145 xl 16 channel, can someone help me please?
May 31, 2008 | Health & Beauty
Programming Bearcat BC 55XLT Scanner
Ok doc, I'll see if I can walk you thru this as there don't seem to be a manual available for download.
* Push manual button and bring it around to channel #1
Enter the freq including the decimal point. Push the E button to enter the freq into the first channel.
* Push manual again and move to channel #2 and repeat.
If you need some new freq's for your area, go here, click on your state, county, and it'll give you a complete rundown.
http://www.radioreference.com/apps/db/
If you need 10 codes for your area, go here and click on your state.
http://www.nat-com.org/radio.htm
If you need anything else, let us know,, Mechanic
Feb 19, 2008 | Radio Communications
Jumping channels
My best guess is that there is a priority channel or channels marked, and it is jumping to that priority channel as soon as someone keys up. Look on your readout for a channel marked with a P. You might have to step thru the channels manually to check them. Hope this helps,,, Mechanic
Oct 21, 2007 | Uniden BC72XLT Handheld Scanner
Question about setting up a scan
When you get to CB or whatever bank you want to search you must press the E/YES and then it should search. Also check your squelch. Hope this helps you out.
Sep 29, 2007 | Uniden BC246T Handheld Scanner
Sirius Satellite Radio Receiver Logo
222 people viewed this question
Top Sirius Audio Players & Recorders Experts
John
John
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
