Question about Samsung Office Equipment & Supplies
Samsung SF330 Fax machine, new cartridge fitted, display showing 1 new 2 used cartridges display stays on. I have tried power off and display returns have also tried taking cartridge out and display returns showing 1 new 2 used can you help please? Thanks Paul
  • 4 Answers
You need to presss 1 or 2 on the keypad to tell the fax machine whether the cartridge you've put in it was 1) brand new, or 2) Used
Posted on Jul 31, 2009
Fax machine Samsung Inkjet Fax SF-360. Ink was finished so ordered the correct ink cartridge and replaced it now on the screen it tells us to install ink cartridge. I have tried severeal times and i know...
If the Toner Low/Empty message does not automatically clear when a new cartridge is installed, use the following to clear the message manually:
1.Press MENU # 1 9 3 4. The machine should display TECH.
2.Press MENU, and ENTER. The machine should display TECH Mode.
3.Press the left arrow < once. The machine will show NEW CARTRIDGE.
4.Press ENTER, the machine will show YES.
5.Press ENTER, there should not be any Toner Low/Empty message.
6.Exit TECH MODE, press MENU # 1 9 3 4. The machine will no longer display TECH.
If Toner Low/Empty message continues, there may be a problem with the toner cartridge or the machine.
Jul 21, 2010 | Samsung SF-5100 Plain Paper Laser Fax
I replaced already new toner cartridge for my brother fax machine mfc-7220 but still the on screen message is appearing on the display "TONER LIFE END". Pls help me to solve this problem. Tnx and God bless...
I replaced already new toner cartridge for my brother fax machine mfc-2820 but still the on screen message is appearing on the display "TONER LIFE END".
Apr 12, 2010 | Panasonic KX-FL541 Plain Paper Laser Fax
Had toner life end message. Replaced toner and drum with oem,machine reset but now just making blank copies. Tried to print internal report that's blank too
To reset the sensor after installing a new toner cartridge follow these steps.
1. With unit powered On, open the front cover.
2. Press the "Options" key. Display will show "Replace Drum?"
3. Press "Start" key.
4. Press 1,0 .
5. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
6. Close cover and see if Toner Life End error message has gone.
Please note that this must be done with a new cartridge so the unit will see that there is toner in the cartridge.
Aug 01, 2009 | Brother IntelliFax-2820 Laser Fax
Prints only right 1/3 of page with new cartridge.
remove the cartridge and install it again
try to remove and putt back for three times if this not help return the cartridge from where you had both it
Jul 11, 2009 | Brother IntelliFAX 560 Plain Paper Fax
Fax saying no cartridge, but have just put new one in machine
That means that your fax machine is not recognising the cartridge. Either is not been put correctly or the cartridge suport is broken. Try with the old cartridge or with the new one use a bit of tape to old it against the contacts of suport cartridge. GOOD LUCK.
Nov 02, 2008 | Samsung SF-3200 Fax
Sf330 samsung won't print faxes
RX and TX are 2 different things.
start with the basics
1- is there toner in the machine
2-if it is ink the cartridges may be dry
Aug 11, 2008 | Samsung SF-330 Plain Paper Inkjet Fax
Change toner
most likely its a defective toner unit, they have a chip on them that tells the machine when it was installed, and how much life it has remaining. if the machine doesn't recognise that its a new toner cartridge its probably a defecive unit. you should return the cartridge from where you got it and try another.
Jun 08, 2008 | Brother IntelliFax-2820 Laser Fax
Nothing there
Did you try cleaning the print cartridge nozzles.
Press Function once and up arrow 2 times
Press the right arrow once and the up arrow once
Press Start/Memory button
It will print a test parttern page
Once you insert the new cartridge did the machine recognize the new cartridge? You had to press 1 for new
When 1 is selected you will get a prompt New Cart: OK?
OK press start.
If you selected NEW the display will show the alternating messages at right. Align Cartridge----1 Print 2 Set
Press 1 to print an alignment page
Hopefully, it will printed. Let me know one way or the other.
Mar 27, 2008 | Sharp INKJET FAX UX-A1000
"toner empty" problem
The samsung sf 5100 toner cartridge has a .05 Amps fuse in it. This gets blowed when you switch on the machine.This is used to reset the page counter and also to inform the machine that you have inserted a new toner. Now this recycled cartriges will not have this fuse and this is the reason why your machine shows TONER EMTY message! If you dont get the same rating fuse, put any fuse of the same size, insert the toner, close the door and just switch on the power and switch off immediately. Then take out the Toner cartridge and remove the fuse. Now your cartridge is ready for use.
Dec 06, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Samsung SF560.
Check if there is a fuse in place (usually fitted to the front edge of the cartridge) and always replace when refilling.
Aug 31, 2007 | Samsung SF-560 Plain Paper Laser Fax
82 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
